Old 10-18-2014, 06:38 PM   #127
lonborghini
lonborghini's Avatar
Drives: '15 red FR-S SSC
I did the five pin relay to four pin relay switch. It worked a treat. No more daytime running lights!
lonborghini is offline   Reply With Quote
Old 01-19-2015, 06:49 PM   #128
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Im curious if anyone knows how to make the the turn signals work as ONLY turn signals. I would like them to stay turned off while the lights are on, and only flash when I'm using the turn signals. Is this possible?
(I know this is a different issue, but figured someone here might have the same dislike as i do)
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 01-19-2015, 07:54 PM   #129
kingnba6
Drives: 2015
i havent looked at the turn signals but are they 3 wire or 2 wire system? if they are 3 wire then you can simply cut the "running" wire.
kingnba6 is offline   Reply With Quote
Old 01-19-2015, 08:20 PM   #130
Kuzuri
__(X)__
Kuzuri's Avatar
Ill have to take a look next time i have the bumper off. or maybe somewhere online is a diagram? ill do some googling
Edit: Found some photos online that show 3 wires. Red/black/green. Red + and black - right? So cut green?
Old 02-02-2015, 05:38 PM   #131
Mr.Scion
Drives: 2014 scion frs
take the bulb out and put a piece of electrical tape on the half of the bulbs bas so one of the filaments do not get power. or just purchase a 7440 single filament bulbto replace the 7443 you currently have
Mr.Scion is offline   Reply With Quote
Old 02-02-2015, 06:24 PM   #132
Kuzuri
__(X)__
Kuzuri's Avatar
I actually decided to go the 7440 bulb route already anyway after reading about that somewhere else! Figured thats better than permanently cutting wires. Thank you though!
Old 02-03-2015, 12:19 AM   #133
eldevil
eldevil's Avatar
Drives: 2013 FR-S 10 Series 477 of 2500
Originally Posted by Ishii Motors View Post
Ok, I hate DRL ( Day time running lights )
So let's turn them off.
It's very simple to do, Just remove the DRL Resistor. Makes the car just that much lighter as well! lol
1. So, access the Front Right Lower panel.
2. Undo the clips and bolt pictured.
(Peel back)
3. Locate DRL Resistor connector
Unplugg and tape up.
4. Remove DRL Resistor
5. Put back together.
Simple.
Ishii
how doesit look like and where DRL Resistor connector located
eldevil is offline   Reply With Quote
Old 02-03-2015, 03:58 AM   #134
D_Thissen
D_Thissen's Avatar
Originally Posted by crouchingpinoy View Post
Here you go! DRL is turned off but high beam function stays intact. Sorry for the poor iPhone 4 (not even an S!) pic.
@jeremy86 @Manic
Rick
There ya go. Takes less then a minute.
Old 05-09-2015, 12:30 AM   #135
trdsolara
Drives: 2014 scion FRS 6mt
Awesome fix to this ugly feature. It took me five min. Love this forum.
trdsolara is offline   Reply With Quote
Old 03-02-2017, 10:37 PM   #136
slowautoxr
Drives: Subaru 2.5RS
I hate DRLs. Thanks for the pics to help me disconnect them.
Charles
2013 FR-S
slowautoxr is offline   Reply With Quote
Old 03-02-2017, 11:02 PM   #137
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
I hate them for another reason. When you saw a headlight on in the daytime in the past it was almost always a motorcycle. Now they just get lost in the sea DRLs.
No rhyme or reason from Toyota -my 13 Corolla had DLRs and full auto lights, my 15 Corolla had selectable DLRs and lights.
SCQTT is offline   Reply With Quote
Old 02-20-2019, 10:34 AM   #138
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
I'm surprised that they implemented a resistor unit on the 86 to get DRL functionality. On most Toyotas, for DRL they simply run the high beam bulbs in series so that way each bulb gets around half of its nominal voltage (6-7V instead of 12-14V). I guess I find it surprising that they added a resistor unit on a car that's supposed to be lightweight (albeit the difference is negligible) instead of using Toyota's usual bulb-in-series design.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 02-20-2019, 01:18 PM   #139
Silverz
Drives: Black frs
So when i’m Running from the cops and want to turn off all light and pull off onto a side road I can do this now with this fix?
Silverz is offline   Reply With Quote
The Following User Says Thank You to Silverz For This Useful Post:
SuperTom (02-21-2019)
Old 02-20-2019, 02:02 PM   #140
ermax
ermax's Avatar
You can also disable the DRLs with Techstream or the Carista app.
