Old 01-18-2015, 08:58 PM   #2423
jvincent
jvincent's Avatar
Engine oil:
You are at 6 months, so you are due on time. As far as mileage goes, if you are tracking frequently, change it at 3K miles tops or every 3 or 4 track days, whichever comes first.
Transmission/differential:
Unless you are tracking really often, once a year is probably fine.
Old 01-18-2015, 09:47 PM   #2424
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by troek View Post
project mu hc-cs, yes to pedal dance. and hks coil overs. do it at home alignment, and zero signs of any uneven toe wear, but thats not to say my alignment is perfect, its just not eating tires. hankook rs3 205/55r16 on 7" rim.
Left foot braking? That has been known to confuse the stability control, but I haven't heard of it being an issue in a straight line.
If the rears lock first, it will squirm. Those are more dual-purpose pads than track pads.
How good are your home alignment skills? I would get that checked.
I think the rears are locking first if it's only happening when you really, really, really brake hard.
Old 01-18-2015, 10:35 PM   #2425
CSG Mike
CSG Mike's Avatar
last time at the track i was testing my brakes/bravery and braking later and later each lap from about 220kph to about 60-70kph. when i started really pushing it and really standing on the brakes, i started to notice some wiggle. it was definitely discomforting. is this normal under severe braking, or is there an issue? brake pads and rotors all look fine, tires almost new. alignment problems?
Are you ABS braking or just threshold? Pedal dance active? VSC?
CSG Mike is online now   Reply With Quote
Old 01-18-2015, 10:57 PM   #2426
troek
troek's Avatar
Drives: 2012 Toyota 86
Threshold braking, pedal dance.
troek is offline   Reply With Quote
Old 01-18-2015, 11:13 PM   #2427
CSG Mike
CSG Mike's Avatar
Perhaps the pads are heating up unevenly front/rear, causing a bias shift as the sessions runs? HC-CS is pretty consistent until it gets toward the upper end of the heat range (600C+)
Old 01-18-2015, 11:14 PM   #2428
troek
troek's Avatar
Yeah im trying to avoid the crazy high price of alignments here lol. I feel 0 abs intervention, so that leads me to believe the rears arnt locking first
Old 01-18-2015, 11:17 PM   #2429
troek
troek's Avatar
My fronts seem to get significantly hotter judging by the burnt color on the back of the pad. The rear are still legible
Old 01-18-2015, 11:28 PM   #2430
EAGLE5
Dismember
EAGLE5's Avatar
Bad alignment, bad caliper, bad suspension component, or improper suspension install/setup?
Old 01-19-2015, 01:12 AM   #2431
ddeflyer
Originally Posted by jvincent View Post
Engine oil:
I would add that you should get a used oil analysis too. When the oil costs $100 a change the $25 that black stone charges can be worth alot. Also it can let you know if you have something unusual happening in the engine before it grenades.
I was changing more frequently than I needed to, UOA is saying 8-10 track days and 5K miles on my car with 300V 0w20 (and of course that is going to be different for different people! don't assume your oil will last the same as mine).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 01-19-2015, 01:24 PM   #2432
CSG Mike
CSG Mike's Avatar
I would recommend installing front brake ducts, or try HC+ in the rear so that the rear temp goes up faster.
Old 01-19-2015, 01:44 PM   #2433
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
That sounds like a LOT of track abuse and miles for oil. How often are people generally changing oil when tracking their cars?
Apex_BRZ is offline   Reply With Quote
Old 01-19-2015, 01:52 PM   #2434
jvincent
jvincent's Avatar
Sorry for the slight off topic here.
I've been struggling with the validity of data from a UOA for the track. As I understand the process, they measure for wear metals and the current viscosity. I don't believe they address viscosity at high temps. So, while a really bad number can be a sign of wear, it's probably too late at that point and a "good" wear report may not be indicative of degraded high-temp viscosity, which is what we care about.
Personally I'd rather change the oil more frequently, a change only costs me ~$60, for the peace of mind.
Old 01-19-2015, 01:59 PM   #2435
Pat
Pat's Avatar
Drives: 2023 BRZ
That was my thought, also. My car has no power modifications. I drive it at it's limit on the track, and typically get in four 15 minute sessions each day. I don't have an oil cooler, and am concerned about getting it too hot, so I don't drive the full 20 minutes. I change the oil after ever track weekend (two days). I have never done a UOA, so I don't know if that's good or bad. It's just what I do.
Which brings up another question. How long does it take for oil to get too hot? I know this can be a gray area, but am I helping to protect the car at all by cutting my sessions a little short? I have not measured temps.
Old 01-19-2015, 02:11 PM   #2436
ddeflyer
These cars heat up their oil really fast and even on stock power they get it pretty scary hot (unless you've added an oil cooler).
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
