Old 11-21-2012, 05:09 PM   #15
gmookher
Post pic of cg lock?
Old 11-21-2012, 05:59 PM   #16
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
http://cg-lock.com/
I have CG-Locks in my Miata and Mustang. Ran a long track day at Mid-Ohio earlier this year in the Mustang, which has much less supportive seats than the BRZ, and it held me in place very well. Never wished I had a 4-pt or 5-pt harness on track. I also have a Schroth 4-pt in my Mini, but for autocross only.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 11-22-2012, 10:54 PM   #17
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Never EVER get a roll bar like this for a DD (http://www.autopowerindustries.com/I...g/DSC_2942.jpg). I have seen one bend in half from a rear collision. The bend ended where the front passenger was and he ended up cracking his head on it. Also never run a full cage on a DD unless you like to wear a helmet every time you drive.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 11-28-2012, 12:29 PM   #18
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by Surok View Post
anybody mount here for 4 point?
Way too low
mike2100 is offline   Reply With Quote
Old 11-28-2012, 02:29 PM   #19
celica73
Originally Posted by mike2100 View Post
Way too low
And, yet, if you actually read the instructions for a Schroth Rallye 4, that is EXACTLY where they tell you to mount it.
Old 11-30-2012, 01:43 AM   #20
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by 7thgear View Post
if you find you're sliding around get a CGLOCK or just brace with your foot
I can't comment on the rest, but I have A CGLock and it does not work in this car. The buckle is so fat that the jaws don't go around it. Maybe with some longer screws, it's doable.
Maybe there's a newer revision, mine is probably a few years old (given to me by a friend, so no idea).
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-30-2012, 01:59 AM   #21
whataboutbob
AutoX-10/10ths every run
I just got a new CG lock in the last couple of months and it came with 3 different sets of screws. Can't remember which I ended up using, but it works fine for DD and AutoX for me.
Picked it up here: http://www.theracersstore.com/
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
2point0 (11-30-2012)
Old 11-30-2012, 04:26 AM   #22
simpleisbest
Senior Citizen
Drives: Scion FR-S
CGLock works just fine. If you can't get it working, either your using the wrong screws or your doing it wrong. Mine works just fine and its almost 3yrs old.
simpleisbest is offline   Reply With Quote
Old 11-30-2012, 12:50 PM   #23
2point0
2point0's Avatar
Makes sense now. Mine was given to me so there were no extra screws. Home Depot to the rescue!
Old 01-18-2015, 06:40 PM   #24
sirwin
Drives: 2015 Scion FR-S
What is a DD? I was looking at these for my FR-S. Advice?
sirwin is offline   Reply With Quote
Old 01-18-2015, 06:44 PM   #25
WolfsFang
Scrape Master
WolfsFang's Avatar
Daily Driver, get a half cage if you really want a good mounting place for your harness, if you dont want a half cage then I would rather bolt the harness to the floor rather just a harness bar if it was me.
Old 01-18-2015, 09:06 PM   #26
sirwin
Thanks. Was looking at that autopower one, but removing the harness bar, or even the whole thing when not on track.
Old 01-18-2015, 09:16 PM   #27
sirwin
see above, and PS, just google half-cage, came up empty, what do you suggest?
Old 02-03-2015, 11:43 PM   #28
rgolom
I installed a Schroth Rallye 4 (4-point harness) into my 2013 FR-S and love it. It uses an anti-submarine system which allows your upper shoulders to rotate slightly and keeps your hips planted in the seat. I have it mounted to the front seatbelt mounting points and the appropriate rear seat lower seatbelt mounting points with all original seat belts still in place.
After a full day on the track at Thunderhill, I have no complaints. I was held in place extremely well and was able to completely relax my body and listen to the car as I drove. I have been doing track and AX events for 7 years and I'm a PCA national instructor and I definitely recommend this particular 4-point harness.
Between the length of the straps and some flex in the seat, a full harness attached to a roll bar is definitely more secure. However, I have a CG lock in my 911 and this 4-point harness is a HUGE improvement.
rgolom is offline   Reply With Quote
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 02:15 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 04:19 AM
Race Harness with stock seats Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-06-2013 04:25 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 02:37 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-17-2012 12:41 AM
