#15 |
Post pic of cg lock?
#16 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
http://cg-lock.com/
I have CG-Locks in my Miata and Mustang. Ran a long track day at Mid-Ohio earlier this year in the Mustang, which has much less supportive seats than the BRZ, and it held me in place very well. Never wished I had a 4-pt or 5-pt harness on track. I also have a Schroth 4-pt in my Mini, but for autocross only.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#17 |
Scrape Master
Drives: Goal: Oldest FRS State Side
Never EVER get a roll bar like this for a DD (http://www.autopowerindustries.com/I...g/DSC_2942.jpg). I have seen one bend in half from a rear collision. The bend ended where the front passenger was and he ended up cracking his head on it. Also never run a full cage on a DD unless you like to wear a helmet every time you drive.
#19 |
#20 | |
Drives: '13 BRZ Ltd WRB
Maybe there's a newer revision, mine is probably a few years old (given to me by a friend, so no idea).
#21 |
AutoX-10/10ths every run
I just got a new CG lock in the last couple of months and it came with 3 different sets of screws. Can't remember which I ended up using, but it works fine for DD and AutoX for me.
Picked it up here: http://www.theracersstore.com/
| The Following User Says Thank You to whataboutbob For This Useful Post: | 2point0 (11-30-2012) |
#22 | |
Senior Citizen
Drives: Scion FR-S
#23 |
Makes sense now. Mine was given to me so there were no extra screws. Home Depot to the rescue!
#24 | |
Drives: 2015 Scion FR-S
What is a DD? I was looking at these for my FR-S. Advice? |
#25 |
Scrape Master
Daily Driver, get a half cage if you really want a good mounting place for your harness, if you dont want a half cage then I would rather bolt the harness to the floor rather just a harness bar if it was me.
#26 |
Thanks. Was looking at that autopower one, but removing the harness bar, or even the whole thing when not on track.
#27 |
see above, and PS, just google half-cage, came up empty, what do you suggest?
#28 |
I installed a Schroth Rallye 4 (4-point harness) into my 2013 FR-S and love it. It uses an anti-submarine system which allows your upper shoulders to rotate slightly and keeps your hips planted in the seat. I have it mounted to the front seatbelt mounting points and the appropriate rear seat lower seatbelt mounting points with all original seat belts still in place.
After a full day on the track at Thunderhill, I have no complaints. I was held in place extremely well and was able to completely relax my body and listen to the car as I drove. I have been doing track and AX events for 7 years and I'm a PCA national instructor and I definitely recommend this particular 4-point harness. Between the length of the straps and some flex in the seat, a full harness attached to a roll bar is definitely more secure. However, I have a CG lock in my 911 and this 4-point harness is a HUGE improvement. |
| Harness Bar | diirk | Tracking / Autocross / HPDE / Drifting | 38 | 07-21-2017 01:15 PM |
| wiring harness | so26 | Electronics | Audio | NAV | Infotainment | 5 | 10-30-2013 03:19 AM |
| Race Harness with stock seats | Sccabrz192 | Tracking / Autocross / HPDE / Drifting | 20 | 04-06-2013 03:25 PM |
| WTT: My FRS seats for your BRZ Premium Seats | Hanakuso | Interior Parts (Incl. Lighting) | 17 | 03-04-2013 01:37 PM |
| Wiring harness | sastexan | Electronics | Audio | NAV | Infotainment | 0 | 06-16-2012 11:41 PM |
