Old 10-17-2013, 12:09 AM   #43
ZZT86
ZZT86's Avatar
Drives: BR86
Coolant that doesn't need changing for 150K, that's flamn amazing
ZZT86 is offline   Reply With Quote
Old 10-19-2013, 03:20 AM   #44
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by SXE10 View Post
They do?? In the dealership I work in we use pink in all the late model stuff & read in older models. Blue is specifically for the 86 only. JDM/NZ part number is 08889-01203. The service schedule says to replace it at 150,000 km or 10 years then every 75,000 km/5yrs after that. I doubt anyone has hit 150K yet?
Sounds just like Canada/USA and other places.
Red long life coolant on models produced before 08/2003, pink super long life coolant on models produced after 08/2003, and blue super long life on 86/FR-S.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 11-29-2013, 11:05 PM   #45
ZZT86
ZZT86's Avatar
Drives: BR86
Hey there ! I just got one of these 4L cans of blue coolant - definitely Japanese but the cap appears sealed - have any idea how to open it ? Looks like i gotta pierce the metal cap but I'm not game to do that in case any sh1t finds its way in in the process ! Never seen one of these cans before - odd :/
Thanks bud
Old 11-29-2013, 11:14 PM   #46
ZZT86
ZZT86's Avatar
Drives: BR86
Never mind - just sussed it out - piece of piss - edge of screw driver pops if off.
Cheers.
Old 12-11-2013, 06:55 PM   #47
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Normally you push down in the middle of the cap & it pops off. Then you can use it again
SXE10 is offline   Reply With Quote
Old 04-28-2014, 02:44 AM   #48
supradoopra
Drives: frs
lol
supradoopra is offline   Reply With Quote
Old 01-18-2015, 03:47 AM   #49
kilohercas
Drives: Subaru BRZ (soon?)
Does any one try to use completely waterless coolant that outlast the car ?
I am thinking to get some when i get my car, so no rust or any other problems will be in my cooling system
http://www.evanscoolants.co.uk/
kilohercas is offline   Reply With Quote
Old 01-18-2015, 09:46 AM   #50
BRZnut
Drives: BRZ DGM Limited
Looks interesting but have not heard of anyone using it. If you do, let us know how it works. I did see that you have to make sure all the water is out of the system. Would have been great if something like this came from the factory
Old 01-18-2015, 11:01 AM   #51
kilohercas
Jay Leno use this stuff on his most expensive cars,if he does not use for long time.
it is multiple times more expensive, but you change it only once
go and look for Wheeler.Dealers.S09E12.Triumph.TR6
[ame="https://www.youtube.com/watch?v=t7PykrgzWPQ"]Waterless Engine Coolant - Jay Leno's Garage - YouTube[/ame]
Only problem is i can't get in Lithuania, i will need to try to ship it ( how much does BRZ use for cooling ? i was unable to find in service manual)
Old 01-19-2015, 12:58 PM   #52
Tenament05
Drives: fast
don't buy into this stuff. "lifetime" coolant is not advised under any serious car enthusiast. Just stick to super blue
(I wonder how Leno actually uses this stuff.. he's a smart guy, but $$$ and endorsements for his name play a factor here in discerning actual use and performance)
Tenament05 is offline   Reply With Quote
Old 01-19-2015, 01:26 PM   #53
kilohercas
OK, lets take simple example, simple engine oil. It can be used as coolant, but it does not have high specific heat capacity ( water is 4181.3 J/(kg·K)), while oil is around 2000J/(kg·K).
Question, how long simple oil can be used inside closed loop, where all it touches is aluminum ? ( lets just say head gasket works like it should). And oil will not do any damage to aluminum block, as well it will not allow electrolysis to happen if you have potential difference between two parts. Ignore what it will do for seals for a moment, since water seals can be damaged by other materials.
Basically time will be your enemy. So by physicist perspective, non conductive, waterless colant is what you need. I don't see any reason why it can't work as it should. And to have complete rust free cooling system is very compelling for me.
Again, i don't know reality, this is theory
Old 01-19-2015, 01:47 PM   #54
phrosty
The Toyota coolant is supposed to last for a damn long time.
phrosty is offline   Reply With Quote
Old 01-19-2015, 01:51 PM   #55
Tenament05
Drives: fast
don't think about it too hard, just know lifetime waterless coolant is unnecessary
Old 01-19-2015, 02:50 PM   #56
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Apparently Evans Waterless Coolant is glycol that has a much lower specific heat capacity than water. Here is an interesting analysis that I found with some searching:
Tests & Analysis of Evans Waterless Coolant by No-Rosion
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
GALAXY BLUE SILICA BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 595 12-08-2022 05:55 AM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 09:55 PM
Black, blue, or gray.. i may have a choice here Mykflo BRZ First-Gen (2012+) — General Topics 27 05-26-2012 11:26 AM
I want this edition... (blue modified 86 TRD) xantonin Scion FR-S / Toyota 86 GT86 General Forum 119 02-15-2012 01:02 AM
More pix of blue 86 w/aero+ rims Alfie FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-29-2011 08:17 PM
