Old 03-18-2014, 04:08 PM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by milhouse View Post
I am in the same boat with a two-day HPDE event coming up. First time, etc. Does anyone think upgrading to SS brake lines (Spiegler) are a worthwhile investment at this point? The car only has 4k miles on it, so I am leaning against it until there is an issue or I do more event, but I'd like some feedback.
Thanks.
I'd do pads and fluid at the minimum. Lines you can do later.
Old 03-18-2014, 04:11 PM   #30
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
Thanks.
If you're planning on flushing with DOT4 fluid anyways (you should be) and are planning on regularly tracking, its a good bang for buck upgrade that increases the durability of the braking system. They're pretty easy to install, just be careful not to allow so much brake fluid to drain that you allow air into the master cylinder.
This will also make bleeding the brakes after install a bit more of a chore than usual because there will be a LOT more air in the system. Get a bit more brake fluid than you would need just to flush the system and have a friend help by keeping an eye on the reservoir level. Add fluid as necessary.
GotMunchies? is offline   Reply With Quote
Old 03-18-2014, 09:20 PM   #31
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
I'm going to have a local shop do the brake flush. I have Project Mu HC+800s on the way, so I expect between the flush and the pads lines aren't necessary right now. And they seem like something I can tackle myself later.
Thanks for all the advice.
milhouse is offline   Reply With Quote
The Following User Says Thank You to milhouse For This Useful Post:
kavanagh (03-18-2014)
Old 01-11-2015, 04:44 AM   #32
CarlIvan
Drives: 2015 FRS
Brake fade
I felt no fade at the end of my first 1/2 hour session at Homestead Speedway. Then the instuctor took my car out for 4 laps. On the next session, which was almost 2 hours later, my brakes felt like sponges by the second lap. By the end of that session I was standing on the brakes and missing apexs. This was on Hawks pads and DOT 3-4 brake fluid(unfortunately I don't remember the specs on thoose pads. I'll check it out when I get home later this morning). Since then I've upgraded to SS lines, rims and tires. Eibach sportline springs (1.4" drop) are arriving this Monday. I'm giving the pads another chance as the instructor runs the same pads on his Miata. Next session is on February 22. I'll see if this helps.
CarlIvan is offline   Reply With Quote
Old 01-11-2015, 04:56 AM   #33
CarlIvan
Drives: 2015 FRS
From my experience last weekend, I wouldn't bother with it until you go test it stock and see how it is. I was blown away by the stock performance.
FWIW, I did put steel lines on my CBR1000RR and love the bite. I just prefer swapping bits after I've identified them as the weak link, and not my own ability.
Sharks?? You should get some ill tempered, mutated Sea Bass. More eco friendly.
The Following 2 Users Say Thank You to CarlIvan For This Useful Post:
CatDaddysBBQ (01-19-2015), Overdrive (09-04-2017)
Old 01-11-2015, 04:47 PM   #34
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I did 7 20 minute sessions at Blackhawk completely stock. I didn't experience any chunking from the tires. By 3/4 through the day though, the brakes were done and upon returning home and taking a pair of pads off; they were cooked pretty good. I think the term is as FRSfan111 mentioned; they were 'glazed'. I replaced them with some performance pads, and race fluid. Completely different car just from fluid/pads.
I did lots of Autocross stock, no problems at all (besides all the suckage while learning)
GeorgeJFrick is offline   Reply With Quote
The Following 2 Users Say Thank You to GeorgeJFrick For This Useful Post:
CatDaddysBBQ (01-19-2015), CSG Mike (01-11-2015)
Old 01-11-2015, 08:39 PM   #35
CSG Mike
CSG Mike's Avatar
Your car has more power, and weight, than a miata.
I can run 20 events on 1 set of Carbotech XP10/8 on a Miata, and still have pads left over. They will last me maybe 1 day in a FRS, if I were to run full sessions (after I feel them fading); they'd be fading after a few laps.
Old 01-17-2015, 05:28 PM   #36
jflogerzi
jflogerzi's Avatar
to be fair your skill and your shop BRZ has much more power then a stock car
Old 01-17-2015, 09:31 PM   #37
CSG Mike
CSG Mike's Avatar
I'm talking about a stock FRS
Old 01-19-2015, 01:20 AM   #38
ddeflyer
Yeah, you can get away with alot more in a Miata, my team's Lemons car is a NA Miata and we just use street pads in the race and it is fine. In my BRZ with DS1.11 (endurance pads so they don't have a crazy high temp range) pads and the essex sprint kit I can feel a slight hint of fading in two spots on that same track.
Now granted, a Lemons race is not as fast or hard on the brakes as a track day, but the feeling I got was that the street pads we were using would not fail a stock'ish weight/stock power miata until you were pulling some seriously fast/hard laps.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Safe to use DOT 5.1? mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-27-2015 03:32 AM
Going to track with stock setup good or bad idea? evasquez7 BRZ First-Gen (2012+) — General Topics 11 08-21-2012 02:33 PM
PacNW Track Day/HPDE/School thread rice_classic Northwest 12 07-10-2012 08:58 PM
Safe to wax new car paint? Nitro Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-09-2012 01:08 AM
HPDE Day video Dragonitti Other Vehicles & General Automotive Discussions 34 06-12-2011 10:11 PM
