Old 01-15-2015, 11:36 PM   #8219
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
So after doing a few runs today my black wire to the compressor came out. Yesterday the blue one came out too. Is anyone else having this issue? Can I use electrical tape to keep the connections together or would it just melt?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 01-15-2015, 11:48 PM   #8220
DAEMANO
Time Traveller
You may have to gently adjust the bullet connectors with a small needle nose plier. Also try to make just a tad of slack in the cable. If you feel like they could still separate, then a bit of tape wont hurt but shouldn't be necessary.
Old 01-15-2015, 11:50 PM   #8221
DAEMANO
Time Traveller
Originally Posted by Shiv@Openflash View Post
Yes, it will require our Procede piggyback computer. I'm first developing the Mazda MX5 application. After that, I'll work on the GT86 application. It basically wires into your ECU harness (tap into 4-5 wires). Download free Procede mapping software from our site, connect your laptop to the Procede and map your own throttle/rpm ESC activation table. We would also provide a pre-loaded off-the-shelf map if you don't want to map anything yourself. The Procede would replace the throttle switch entirely.
Downside? Cost. I don't know exact pricing yet but it will be more expensive than the throttle switch
Version 2.5 or 3?
Keep us posted. It feels like we are on our way to something big.
Old 01-16-2015, 12:10 AM   #8222
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
So if you need someone to test it.....
Btw- freaking bad ass
Installed Mods:
Old 01-16-2015, 07:33 AM   #8223
WNDSRFR
Drives: FR-S,GTI
This just keeps getting better and better. I dream of the day when I rig up 2 of these in parallel with a way to control the boost. Wouldn't that be something.
Old 01-16-2015, 01:43 PM   #8224
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Badass @Shiv@Openflash
Old 01-16-2015, 02:27 PM   #8225
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by DAEMANO View Post
Version 2.5 or 3?
Either v2, 2.5 or 3 will work for this application. It's really overkill as the Procede was designed to offer control of BMW single turbo conversions running flexfuel on top of methanol injection. For this application, we are only using 1 of 10 available outputs. But it does leave A LOT of room for potential upgrades/new functions.
Shiv@Openflash is offline   Reply With Quote
Old 01-16-2015, 02:29 PM   #8226
Robftss
Drives: VW
Wow, just wow! Finite motor control. "Upgrades and integrations", phew!!! There are some seriously beautiful things in our future. Please keep it up @Shiv@Openflash @Robftss @fenton
Yeah, Shiv cracked the code!
Early still....but the jack can be connected to a 'NOS' switch, a part/WOT switch or Shiv's logic device.
Robftss is offline   Reply With Quote
Old 01-16-2015, 03:49 PM   #8227
phrosty
iirc Procede is pretty expensive; hopefully a cheaper solution is discovered.
phrosty is offline   Reply With Quote
Old 01-16-2015, 03:56 PM   #8228
Shiv@Openflash
Drives: 2013 FRS
The elaborate plug and play harness used in original Procede kits were actually more expensive to manufacture than the Procede itself, which led to the high cost ($750) of the kit. In this case, the harness costs next to nothing to manufacture so the price of the Procede will be substantially lower than it ever was in any other application.
Old 01-16-2015, 04:39 PM   #8229
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I am game whenever its ready. The cost to me is worth it. Linear power delivery with this setup would be perfect and add confidence when AXing with the ESC on.
Assuming that this would allow for true linear power, but I cant imagine why it wouldn't.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 01-16-2015, 04:43 PM   #8230
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I am installing my kit this weekend. It is the version 1 kit, but with the upgraded batteries and battery block components.
Will a version 2 (upgraded control box, turbine) be needed to add procede boost control?
Daily: Audi TT RS
Old 01-16-2015, 09:08 PM   #8231
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
my question is, how long will the boost last under constant use, even at lower levels. I would assume you would want boost to start building at about 30% to 40% throttle. Much lower and you would be draining the batteries every time you took off from a stop sign or redlight. Second, I guess is what type of tune would we need? Our current tune relies on Open loop. I guess shiv has worked out boost for turbo kits (sbd?) with the OFT, so he should be fine for this, but it doesn't seem like it will be as easy of a tune as with the original setup.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 01-16-2015, 10:12 PM   #8232
fenton
The motor and controller are not meant for constant boost....you need complex boost control tables to make this work in open loop. Think of all the wastegate tables in a modern turbo car.
None the less I hope shiv figures it out....would be a great option for those looking for a bit more control.
fenton is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
