Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 01-15-2015, 12:33 AM   #155
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
What ever happened to the kit that would just allow for the turn signals to also be back up lights using switchbacks? That's what I was waiting to see.
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 01-15-2015, 06:51 PM   #156
DragonMugen
Drives: FRS
Anybody else jabs their switchback driving lights turn off while the brake is on and come back on when you let off the brake? I have another brand with hyper flash relay.. @Diode Dynamics any ideas?
Same issue here with mine. I took off the taillight mod and my switchbacks work perfectly normal. Some reason this adapter causes the switchbacks to turn off when I brake. I received the same response from Diode to put back the factory bulbs but I do not like the original amber look. Perhaps the adapters we received are defective. Do both your switchbacks go off? Or just on one side?
Does anyone else with switchbacks have this same issue with those taillight mod?
DragonMugen is offline   Reply With Quote
Old 01-19-2015, 12:23 PM   #157
buckseventysix
Has anyone ran this mod with tinted tails? I was thinking of eliminating the bottom 3rd brake/ reverse lights, but unsure what the light output would be using the turns as reverse lights if the tails are tinted.
Anyone?
buckseventysix is offline   Reply With Quote
Old 01-19-2015, 01:23 PM   #158
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Anyone?
Are they painted or have tint film on them?
Old 01-19-2015, 10:02 PM   #159
buckseventysix
Currently neither, but I was thinking of painting them with VHT plus some clearcoat.
Old 01-19-2015, 11:37 PM   #160
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Anyone?
Why not leave the back facing part over the turn signal area clear and red everything else... because you need white for reverse lights, cannot be a colored light. That's what I'm thinking of doing...
Just ordered the turn conversion/reverse LED's a few minutes ago since they are available for order on the site now...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-20-2015, 08:54 PM   #161
Diode Dynamics
Diode Dynamics's Avatar
The modules are not defective- we have analyzed this in detail in multiple vehicles in order to determine this.
Basically, when you hit your brakes, you drop a very small amount of power, less than .5V at extremely low current, on the running light circuit. This small amount of voltage does not normally affect anything in any way. The vehicle itself actually drops .2-.3V from the brake light circuit to the running light circuit when you hit your brakes. When dealing with a 12V system, this is minimal.
However, we have noticed that some cheaper switchback bulbs, those that draw very little power, will think that the turn signal is triggered when that very small amount of power hits them. The module works 100% fine with the factory bulbs, and most switchbacks, including our own. We have heard of the issue about a half-dozen times, and in each case, the customer was using very low-grade switchbacks, and it was easily resolved through the use of different switchback bulbs.
We will continue to make improvements to this product in order to limit any power from reaching the bulbs at all, however, while we try to design our products to work with everything out there, we cannot identify and resolve issues that exist with some switchback LED bulbs on the market when there are so many switchback designs out there.
The vast majority of customers are running this module very successfully, with absolutely no problems. Many are using switchbacks with it too, including us, on our FR-S! This problem only might happen if you use this module with low-grade switchback bulbs. This product therefore may not be compatible with very low-cost switchback LEDs. We recommend the use of higher-power switchback bulbs if you want to stick with that look, or factory bulbs. Thanks!
Paul
Product Development
John C.
Diode Dynamics
Old 01-25-2015, 12:38 AM   #162
Vracer111
Vracer111's Avatar
Got the kit in today and installed it... pretty easy overall. The hardest part was replacing the Flasher module... taking out the lower dash kick panel and chiseling out the factory mount proved to be the quickest route to do it, it just wasn't happening with me trying to wrestle with it cramped under the dash. Put the XP-80 bulbs in and tested it out - had to flip the passenger side one since it didn't light up on the first try. Nice and bright...I can see while backing up now!
Flashers have that weird ~1 second delay before blinking, but at least it lights up when you initiated it and then cycles like normal. Didn't do this with the factory Flasher module (but it did hyper-blink of course). Neatly zip tied the wiring runs and buttoned everything up then removed the useless factory backup light that I had temporarily mounted and protected and secured the factory harness for the back up light out of the way.
Since it was a very nice sunny and 'warm' day and it's been months since I've cleaned her, I put her on the lift and cleaned out the crud in the wheel wells, suspension and brakes and rotated the tires (6 months/~5k miles with this new set and already down to below the wear bars in the rear - rears wear twice as fast as the fronts....weeeee!) then washed and waxed her. Here's a picture I took with just the reverse lights on:
Really liking it - Thank you very much! Now, with the factory reverse light finally deleted, I can get on to the next task of figuring out the exhaust system!
Old 01-25-2015, 05:56 PM   #163
Vracer111
Vracer111's Avatar
And a daytime picture:
Old 02-09-2015, 11:47 PM   #164
Jdex420
Drives: 2014 FR-S
Just ordered my kit and can't wait to install. This should have come standard on these baby's.
Jdex420 is offline   Reply With Quote
Old 02-10-2015, 01:16 PM   #165
Diode Dynamics
I agree! It's a simple upgrade, but it looks 1000x better than the factory setup
Nick C.
John C.
Diode Dynamics
Old 03-12-2015, 05:37 AM   #166
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
Is there any way to turn signal light into brake light, instead of reverse light?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 04-15-2015, 01:04 PM   #167
Diode Dynamics
You can tap the yellow wire in the Tail-As-Turn™ module, however,
this will only function as brake though...not a running light. The turn signal bulb is single filament
Feel free to give us a call if you have any questions: (314) 205-3033
Thanks!
Nick C.
John C.
Diode Dynamics
Old 05-22-2015, 10:30 PM   #168
wildpandaz
Drives: Scion Frs 2013
Anyone have a video of the"turn signal" part? Havent been able to find one yet.
wildpandaz is offline   Reply With Quote
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
Adjustable TURN SIGNAL LEDs for FR-S & BRZ ~Choose color & brightness~ Plug-N-Play KI_ZN6 Exterior Parts - Lighting 685 02-18-2016 11:03 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-06-2014 11:24 PM
Quickets AND Cheapest Turn signal and DRL LEDs? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 06-17-2013 09:52 PM
