Old 01-15-2015, 04:42 PM   #15
steve99
Drives: FT86
Originally Posted by 2much View Post
This is a new topic for me.
I have been running oft stg1 91oct v2.06 tune as well... I have a K/N drop in panel filter, perrin inlet hose, and otherwise unmodified box and snorkel. Should I be paying attention to my MAF scaling? Car seems to be operating normally.
Maf scaling needed if you change the entire intake or part of the intake that changes the position or the diameter of the tube the maf sensor or the patern of air flowing past the maf sensor.
just an intake tube or filter doesnt require maf rescale.
2much (01-15-2015)
Old 01-15-2015, 04:48 PM   #16
2much
I wanna go fast
Drives: 2013 FR-S 6MT
thanks for the help guys. And now, to complete the thread hijack - am I still current in thinking there really isn't much gain by doing anything else to the intake (or implementing a full aftermarket solution)?
2much is offline   Reply With Quote
Old 01-15-2015, 07:08 PM   #17
Cop
Cop's Avatar
Drives: 2013 FRS
See below for some of Grimmspeed's research:
http://www.grimmspeed.com/grimmspeed...-2013-brz-frs/
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
2much (01-15-2015)
Old 01-15-2015, 07:43 PM   #18
steve99
Drives: FT86
On an NA car best bang for buck is catless header, tune and add for E85 (with appropiate tune)if you have it available. and maybe drop in filter
just good catless header,tune,E85, drop in filter will give you around 85% or more of the possible gains from bolt on mods NA , gets you arround 30-35 wheel hp.
can be done for about $1000
doing the rest of the exhaust and intakes, power blocks spacers ect is expensive and gains are not that much more on an NA car
if you want more just go FI or sell the car
The Following 2 Users Say Thank You to steve99 For This Useful Post:
2much (01-15-2015), diodelphi (01-15-2015)
Old 01-15-2015, 07:50 PM   #19
2much
I wanna go fast
doing the rest of the exhaust and intakes, power blocks spacers ect is expensive and gains are not that much more.
I have OFT and OFH... unfortunately e85 stations are [very] few and far between around these parts, so I stick with an 91oct tune.
I can see there's some gain to be had with the grimmspeed intake, but is that $350+ going to net me more than a couple horses over my current intake setup? I am guessing no.
Out of the remaining exhaust parts (over, front, mid, axle) am I correct in understanding replacing the overpipe is most critical for gains? And the rest is less critical?
I already have the urge for FI... waiting on oft350 and ft86sf info
Old 01-15-2015, 08:07 PM   #20
steve99
Drives: FT86
overpipe probably only worth doiung if your going fi, each exhaust part after catess header only worth a couple of hp NA. maybe hi flow or catless front pipe but gains not much and can be niosy\raspy when secondary cat changed.
turbos tend to be good at cutting noise and rasp though.
some fi guys have been destroying secondary cat due heat, so probably worth changing that or at least going to metalised hi flow that more durable with fi.
if you change muffler with catless header and hi flow cat or catless midpipe get a quiet one
2much (01-15-2015), EffaressNOOB (07-26-2016)
Old 01-15-2015, 08:15 PM   #21
2much
I wanna go fast
good to know, I wont bother dumping $300+ on an overpipe until it matters a lot more. thanks for the advice steve, as usual you are very helpful.
Old 01-15-2015, 10:14 PM   #22
Rescodna
Drives: 2013 Subaru BRZ (WRB)
Hello all - Where does Perrin publish a MAF scale for their 2.75" intake? I looked on their site and I thought the whole thing with that intake was that it didn't require any changes to tuning, unlike their 3" bigMAF intake.
I'm considering this intake and have an OFT so if there's already a good MAF scale available for it I'd love to know.
Thanks!
Rescodna is offline   Reply With Quote
Old 01-15-2015, 10:32 PM   #23
steve99
Drives: FT86
Thanks!
end of this post has perrin scaling
http://www.ft86club.com/forums/showthread.php?t=64790
you might need to touch it up using proceedure in that post and vgi utility but will get you started.
diodelphi (01-15-2015), Rescodna (01-17-2015)
Old 01-17-2015, 08:31 PM   #24
Rescodna
Awesome - thank you Steve.
Old 01-19-2015, 09:25 PM   #25
2much
I wanna go fast
do you think running stage 2 91 uel tune while only replacing the header and nothing else behind it is safe? I am reading about exhaust back pressure causing the car to run rich, and I'm not sure how serious it can be.
Old 01-19-2015, 09:58 PM   #26
phrosty
Stage 2 is intended for catless headers. The other stuff doesn't matter.
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
2much (01-20-2015), steve99 (01-20-2015)
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 05:59 PM
OpenFlash Tablet Stage 2 v1.33 Customer Datalog Rombinhood@OpenFlash Software Tuning 99 01-02-2014 09:17 PM
FS: Perrin headerback, Injen Intake and Perrin Pulley Boxer-86 Engine, Exhaust, Bolt-Ons 39 10-29-2013 10:32 PM
Will someone please send me a datalog? ATSAaron Forced Induction 48 09-10-2013 10:29 PM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
