Old 11-19-2014, 01:47 PM   #1
acj47
acj47's Avatar
OFT datalog with Perrin intake
Hi, so I recently purchased the OFT and wow, what a great tool! I've read the various posts about MAF scaling, and was hoping to get some feedback on my recent datalog. The car has the Perrin intake (2.75" version, not the large 3" one) and muffler delete pipe. The map is the OFT v2.06 stage 1 91 oct. I followed the instructions to keep the car in closed loop mode, and logged the STFT and LTFT.
Any comments/feedback would be appreciated, thank you!
http://www.datazap.me/u/acj47/19nov2...0&data=1-10-11
acj47 is offline   Reply With Quote
Old 11-19-2014, 02:24 PM   #2
phrosty
Your LTFT indicates your MAF scale is off by 4-8%. Updating your tune to use Perrin's scale would fix that right up. There's not much need to do your own scaling, Perrin's is quite accurate.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
acj47 (11-19-2014)
Old 11-19-2014, 04:49 PM   #3
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Also log command afr to get a better idea of how far you're off. (or at least it helps me) Looks like you're running rich due to MAF scale having too high of numbers on the "mass flow g/s" part of the scale.
I don't even log closed loop. lol I went straight to open loop 2k-7.6k pulls.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
The Following User Says Thank You to BuBlake For This Useful Post:
acj47 (11-21-2014)
Old 11-21-2014, 05:33 PM   #4
acj47
acj47's Avatar
Update: used the MAF scaling values for the 2.75" Perrin intake and reflashed. Will log again in a few days. Thanks for your help phrosty and BuBlake!
Old 11-29-2014, 12:20 AM   #5
kchar
Because Racecar
kchar's Avatar
Drives: 2014 Scion FR-S
Any update?
I just installed a 2.75" as well and I'm sitting at -12.50 lt trim on idle/cruising in neutral. I believe the trims look good when driving around, didn't get the chance to do long pulls. Anyone know what the problem may be?
http://www.datazap.me/u/donkeyrage/p...3578-5494-4774
kchar is offline   Reply With Quote
Old 11-29-2014, 07:20 AM   #6
steve99
Drives: FT86
Originally Posted by kchar View Post
Any update?
did you put the perrin maf scale values in your tune ?
if you did and ltft still that far off check for intake leaks and gasket at maf sensor
check for exhaust leaks near or before o2 sensors
if still no good you will need to manually scale maf and insert values into tune
see links below on maf scalling, perrin intake scales at end of maf scaling post
Old 11-29-2014, 02:14 PM   #7
kchar
Because Racecar
kchar's Avatar
Yup I used the 2.75 scale.
My trims were < 6% on the stock air box so I don't think I have an exhaust leak but I'll have to check.
I'll take a look at the intake connections again and tighten down the sensor.
I'm just confused as to why the trims look good when I'm on throttle (any amount) but as soon as I let off the lt trim goes rich.
Thanks Steve
Old 11-29-2014, 03:16 PM   #8
acj47
acj47's Avatar
Any update?
Update: I drove around for a bit with the Perrin MAF values, and the trims were much closer to zero. I was too eager to install the E85 map, so I didn't get any logs before switching to the E...
Old 11-29-2014, 07:12 PM   #9
steve99
Drives: FT86
you probably should transfer the perrin maf values to the e85 tune if they were ok on petrol
acj47 (11-29-2014)
Old 11-29-2014, 07:39 PM   #10
acj47
acj47's Avatar
Yup, that's exactly what I did. Ran the 91 octane map with Perrin MAF values, made sure the trims were ok, then edited the E85 map for Perrin MAF and filled up on the E & loaded the map.
The Following User Says Thank You to acj47 For This Useful Post:
steve99 (11-30-2014)
Old 01-14-2015, 02:29 AM   #11
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I am looking at doing the 3" system, yet I just read in a previous post that @steve99 , you said not to scale the MAF while running OFT e85 maps. Does that still true? or should I scale them when I get it?
The Following User Says Thank You to DustinS For This Useful Post:
EffaressNOOB (07-26-2016)
Old 01-14-2015, 06:47 AM   #12
steve99
Drives: FT86
The problem with maf scaling on e85 is the ethanol content varies. this throws off your trims.
shiv,s E85 tune like others likely has the maf scaling done on the average E85 content.
he likely also used the maf scaling to make it run on the rich side for safety.
the varing ethanol content is another variable to need to consider , as is making sure your new maf scaling does not make your tune run too rich or too lean as ethanol content varies. between about E60 and E90.
luckly in OZ we have a pump E85 that is guaranteed 85% ethanol so it makes life easier.
The maf reading are also an input into the engine load calculation which is used to set timing and fueling to engine , Shifting the maf scale can shift you to diferent load cells in the timing and fueling tables. so log your new tune carefully checking for knock, afr and fuel trims.
Old 01-15-2015, 03:49 PM   #13
2much
I wanna go fast
Drives: 2013 FR-S 6MT
This is a new topic for me.
I have been running oft stg1 91oct v2.06 tune as well... I have a K/N drop in panel filter, perrin inlet hose, and otherwise unmodified box and snorkel. Should I be paying attention to my MAF scaling? Car seems to be operating normally.
2much is offline   Reply With Quote
Old 01-15-2015, 04:36 PM   #14
Cop
Cop's Avatar
Drives: 2013 FRS
I don't believe you need to with just the filter.
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
2much (01-15-2015)
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 05:59 PM
OpenFlash Tablet Stage 2 v1.33 Customer Datalog Rombinhood@OpenFlash Software Tuning 99 01-02-2014 09:17 PM
FS: Perrin headerback, Injen Intake and Perrin Pulley Boxer-86 Engine, Exhaust, Bolt-Ons 39 10-29-2013 10:32 PM
Will someone please send me a datalog? ATSAaron Forced Induction 48 09-10-2013 10:29 PM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
