Old 01-11-2015, 10:37 PM   #2745
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Positive displacement superchargers are "air pumps", whereas centrifugal superchargers are "air compressors".
That's true with roots blowers, but not with twin screw superchargers. They're compressors that rival turbochargers for efficiency, but they take more power to turn than a roots blower does, typically.
Sellout is offline   Reply With Quote
Old 01-12-2015, 02:06 PM   #2746
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by FirestormFRS View Post
I can attest that the Skunk2 will bolt up to the Tomei OP. Hope to have the car done in the next 3 weeks, but my job is getting in the way.
@KraftWerks are you seeing that 12-15hp on NA or boosted or both?
The recent dyno reference from Vit Tuned was N/A which it picked up about 15whp and 12-15tq. Should see a bit more in terms of gains from F/I.
KraftWerks is offline   Reply With Quote
Old 01-14-2015, 05:36 AM   #2747
praneetn7
Drives: 2014 GTS - Pegasus White
Hey guys,
I'm looking to get this kit very soon but wanted to get all the supporting mods done before I install the kit. Is a 3in exhaust needed or will headers, 2.5in over pipe, 2.5in front pipe and 2.5in catback do? Looking to run the c38 at approximately 300whp on e85.
Thanks in advanced
praneetn7 is offline   Reply With Quote
Old 01-14-2015, 07:30 AM   #2748
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
Install Time-lapse
Hi all,
Here is a time lapse video I made as we installed my Kraftwerks kit over the last few days. this is one fo the first kits in Australia and I can't wait to get it tuned!
[ame="https://www.youtube.com/watch?v=XPJo4Wq3pt4"]Video 25 - Time Lapse - Kraftwerks Supercharger Install - YouTube[/ame]
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information.
The Sentinel is offline   Reply With Quote
The Following 4 Users Say Thank You to The Sentinel For This Useful Post:
Chad86 (01-16-2015), DAN_BRZ (01-14-2015), Rulin (01-14-2015), Scracho (01-14-2015)
Old 01-14-2015, 07:50 AM   #2749
Dream20b
Y u do dis?
Originally Posted by praneetn7 View Post
Hey guys,
Thanks in advanced
C30 kit may save you some $$ for that goal.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
Freeman (01-14-2015)
Old 01-14-2015, 08:26 AM   #2750
Sellout
Mr. Cranky Pants
Sellout's Avatar
And have a better powerband. There's no reason whatsoever to step up to a C38 if all you want is 300whp on E85.
The Following 3 Users Say Thank You to Sellout For This Useful Post:
86SPEED (01-14-2015), Dream20b (01-14-2015), Rulin (01-14-2015)
Old 01-14-2015, 11:16 AM   #2751
lucid215
Hey guys,
Thanks in advanced
you wont necessarily need a 3" exhaust. i would also look into bigger injectors if you plan on running e85 with the c38. with the right mods and tune you can get 300 on pump with the c38
lucid215 is offline   Reply With Quote
Old 01-14-2015, 01:17 PM   #2752
SPCorBUST
SPCorBUST's Avatar
Better powerband? How so?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 01-14-2015, 01:57 PM   #2753
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Not sure about the powerband claim, but if 300 is your goal on E85 then a C30 will more then do that. my C38 on E85 is 417. We recommend a C30 for most applications. Only those chasing the high HP numbers do we mention a C38. I believe a few pages back someone was at 360-380whp on a C30 on E85. A built engine is where this C38 would really shine..
-Thomas
86SPEED is offline   Reply With Quote
The Following 2 Users Say Thank You to 86SPEED For This Useful Post:
CSG Mike (01-14-2015), Dream20b (01-14-2015)
Old 01-14-2015, 03:54 PM   #2754
Derka
Drives: 2015 frs
I'm getting a vibration at about 1500 rpm. It's only under a load such as taking off or a/c and cold idle. It sounds to be coming from the supercharger/drive belt area. I've checked pulley tight bolt tightness, belt tension and every bolt imaginable. Any ideas?
Derka is offline   Reply With Quote
Old 01-14-2015, 04:34 PM   #2755
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Mine does this too. Haven't been able to figure it out. Thought it was my clutch for a while. Goes away when the car is warmed up.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
Derka (01-14-2015)
Old 01-14-2015, 05:05 PM   #2756
86SPEED
86SPEED's Avatar
Same here only when cold, 1500 or so very light throttle for me, like when I'm cruising through my neighborhood in the morning leaving for work. belt adjustment hasn't affected it at all, so i had the belt off, still did it. I've check all the bolts. everything it torqued properly, i just figured its the plate vibrating/resonating at that rpm when cold.. its only a few minutes and just barely noticeable on mine, so it doesn't bother me, something i haven't even thought of after i tried to locate the problem
-Thomas
Derka (01-14-2015), post_break (01-14-2015)
Old 01-14-2015, 05:09 PM   #2757
post_break
post_break's Avatar
-Thomas
Glad I'm not the only one. I was really worried it was my clutch chattering or the blower was fussy when cold. Your testing proves otherwise.
Old 01-14-2015, 06:11 PM   #2758
Derka
Drives: 2015 frs
I took my belt off. And the noise went away
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
