Doborder, orthojoe
Old 01-10-2015, 01:35 AM   #141
Originally Posted by slair View Post
quick question..anyone looking at their AT transmission...did you notice anything about the gasket? mine has crack marks at every bolt lactation. am hoping they arent all the way across. I checked the fluid and its super clear and there is no evidence of leaks anywhere, i took a rag and went across the entire pan, it was dirty but didn't come across any wet/shiny spots to indicate that i had a leak.
but those marks do have me a bit worried.
I was looking for something else when I came across here and noticed no one answered your question.
It's fine. The part of the gasket you can see is not actually doing anything. It's outside the perimeter of the mating surfaces. It cracks because the excess is literally squeezed out a bit. Pretty common.
slair (01-10-2015)
Old 01-14-2015, 01:40 PM   #142
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Originally Posted by Koa View Post
LAZY
not lazy, went through the whole thread and was looking for different verbiage. Ended up going in with out the part numbers and just talking with the Toyota parts guy. I do not have the most extensive history mechanically and thought the part would be referred to as crush washer not gasket so I assumed this was not the part I was looking for or else I would not have asked. P
Kwisak is offline   Reply With Quote
Old 01-14-2015, 01:44 PM   #143
Kwisak
Kwisak's Avatar
Originally Posted by EWY View Post
Incase you missed it reading through the thread.
Thank you for the heads up, I saw that at the start and assumed it was not what I was looking for as in the thread most posters referred to it as a crush washer and not a gasket. That and when referring to a gasket my only experience was with a head gasket, so I assumed this was not the part I needed. I ended up going in and talking with them about what I was doing what I might need.
Old 02-04-2015, 05:24 AM   #144
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Question:
Is using a crush washer really important? Or it's also possible to use a normal m18 washer to seal the plug?
Thanks!
Brzerker is offline   Reply With Quote
Old 02-04-2015, 01:55 PM   #145
Originally Posted by Brzerker View Post
Question:
Thanks!
Critical not only for sealing but also to prevent damaging the mating surfaces between the bolt flange and the seat. That's why, in the biz, they've gotten away from calling them washers. They really are (should be) one-time-use gaskets.
ddevl_86 (04-02-2021)
Old 02-05-2015, 03:12 AM   #146
Brzerker
Brzerker's Avatar
Ah I see.
However, what is the difference between the small thin kind and the thicker ones? Ala the drain plug "washer" and the filler plug "washer"
Old 02-05-2015, 01:57 PM   #147
Ah I see.
Hmmm... I don't know. Thicker ones like those on a spark plug are able to fill in the gaps due to looser tolerances but we would have to ask the manufacturer why those choices are made.
Honestly, sometimes it's just "We buy lots of these because we already use them on that other thing so it's cheaper by $0.02/1000 units."
Old 02-09-2015, 03:51 PM   #148
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
just swapped trans fluid this weekend, purchased the 4L kit from Modbargains.
Shifts were good before, but now its ultra smooth!
The Following User Says Thank You to continuecrushing For This Useful Post:
JB86'd (02-09-2015)
Old 02-21-2015, 06:08 PM   #149
haimichaeltran
Drives: 2015 Scion FR-S Halo
Amazing
Just changed the transmission and differential oil with Motul 300 and what a difference it's made. I feel more confident going into 2nd gear from 1st now that it's smoother.
haimichaeltran is offline   Reply With Quote
Old 02-21-2015, 07:12 PM   #150
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by FastWhite View Post
Doing my A/T fluid this wknd. Will let you know.
So, what fluid did you use and how do you like it?
aegisdrgn is offline   Reply With Quote
Old 02-21-2015, 10:05 PM   #151
slair
slair's Avatar
Drives: Scion FRS
i used Redline d6 atf
slair is offline   Reply With Quote
Old 03-13-2015, 07:44 PM   #152
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Ok, so I have a really dumb question about filling the trans fluid. I drained it, and have put nearly 3qts in. It finally started seeping out of the hole, and it just keeps on coming out. I can fit my pinky finger in there, but can't feel the fluid at all. It HAS to be full by now, using nearly 3qts. I've cleaned the threads multiple times and the area where it's leaking and it's definitely still seeping out. However...still can't feel the oil level with my finger.
I'm sure I'm making this more difficult than it really is, but I'm worried that if I call it good and button it up...I may find out the hard way that there isn't enough fluid in there. It's a little disconcerting when I can't seem to feel the oil AT ALL inside the hole with my finger. Car is absolutely level.
Thoughts? I'm just about out of oil...
Apex_BRZ is offline   Reply With Quote
Old 03-13-2015, 08:10 PM   #153
continuecrushing
Is the car level? If the car is level, just keep putting oil in until it flows out of the hole. When it stops flowing out, put the plug back in.
If its leaking out and then stopping, the oil is right at the level of the hole.
If oil keeps seeping out, then the oil level is higher than the hole.
Maybe you can't feel with the tip of your finger?
I think you're just over thinking/complicating it.
Its only supposed to take 2.2L.
You are working on an frs or brz, right? jkjk
Old 03-13-2015, 08:31 PM   #154
JB86'd
JB86'd's Avatar
Drives: JAWS
@Apex_BRZ I suspect your car isn't perfectly level. You may be slightly overfilled if you've actually put in that much fluid. I'd let it seep until it stops completely, definitely don't add more fluid.
JB86'd is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 06:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
