Old 10-13-2014, 06:19 PM   #127
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by gutbomb View Post
I know this post is from several months ago but where does this chart come from? I believe the section for inspecting the rear diff oil has the miles and kilometers backwards. Same for the A/C filter.
http://www.ft86club.com/forums/showthread.php?t=8374
B-R-Z is offline   Reply With Quote
Old 10-24-2014, 08:16 PM   #128
zinithin
Drives: Scion frs, Manual, Hot lava
Just replaced my manual transmission fluid with amsoil synthetic Manual Transmission & Transaxle Gear Lube 75W-90. Made sure my car was level, filled the tranny from the top of the car with a polyvinyl tube and funnel. One of the things I noticed was that I had to put about 0.4L more than what I took out. My kms were 31600 (manual says to replace at 32000km) and the old fluid looked horrible.
My shifts are now much smoother and the car just generally feels nicer to drive. Highly recommend replacing your fluid, even just to fill it up to the correct level. My tranny took 2.7L instead of 2.3L like the manual states.
zinithin is offline   Reply With Quote
Old 12-25-2014, 12:02 PM   #129
slair
slair's Avatar
Drives: Scion FRS
quick question..anyone looking at their AT transmission...did you notice anything about the gasket? mine has crack marks at every bolt lactation. am hoping they arent all the way across. I checked the fluid and its super clear and there is no evidence of leaks anywhere, i took a rag and went across the entire pan, it was dirty but didn't come across any wet/shiny spots to indicate that i had a leak.
but those marks do have me a bit worried.
slair is offline   Reply With Quote
Old 12-25-2014, 12:28 PM   #130
FastWhite
Drives: Subaru BRZ Limited M/T
Doing my A/T fluid this wknd. Will let you know.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
slair (12-25-2014)
Old 12-25-2014, 04:32 PM   #131
JB86'd
JB86'd's Avatar
Drives: JAWS
I do lots of city driving, don't really beat on my car but do drive spirited and occasional autox. I already switched to motul 300 in the tranny and diff at 7400 miles. I plan on changing the diff fluid every 15k and tranny every 30k as proactive maintenance. I figure it's easy and cheap enough.
JB86'd is offline   Reply With Quote
Old 12-25-2014, 05:07 PM   #132
chas3wba0
chas3wba0's Avatar
Drives: Yes
Put in Motul 300 last weekend at 16k miles. Didn't feel a difference... 4th gear still "crunches" in at high RPM's but doesn't feel like anything is getting damaged per se.
Still felt good to get that smelly factory stuff out of there though :p
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 12-25-2014, 05:41 PM   #133
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Bonburner (05-03-2015), Koa (12-31-2014), NissanGuy (12-25-2014), NWFRS (06-04-2015)
Old 12-25-2014, 05:52 PM   #134
slair
slair's Avatar
Drives: Scion FRS
Redundancy....OOooops!!! Lol
Old 12-27-2014, 09:33 AM   #135
slair
slair's Avatar
Drives: Scion FRS
Gasket looks about the same at every bolt
https://docs.google.com/file/d/0B7Gc...p=docslist_api
Old 12-28-2014, 07:59 PM   #136
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Does anyone know the part numbers for the
+ Rear Differential Drain Crush Washer
+ Rear Differential Fill Crush Washer
+ 2 Crush Washers for the transmission
Kwisak is offline   Reply With Quote
Old 12-31-2014, 03:00 PM   #137
EWY
Becoming A Regular
EWY's Avatar
Drives: 2013 Raven FRS
Just ordered my Motul Gear 300 fluid from No Limit Motorsport
EWY is offline   Reply With Quote
Old 12-31-2014, 03:06 PM   #138
EWY
Becoming A Regular
EWY's Avatar
maybe OP can go ahead and post up these parts numbers for the crush gaskets in the original post -- can someone who's done this confirm these are the right part numbers?
Differential fill plug gasket: SU00300122 @$2.30 each
Differential drain plug gasket: TOY1215710010 @$1.50 each
Transmission fill/drain plug gasket: SU00303626 @>$11 each
I went to the Subaru dealer today and he said the Tranny fill/drain gaskets are $8 each so I ordered those, but he did not find any parts for the differential. If someone can confirm these are the right #s I will call him back and ask him to order these for me too. Will the TOY # work at Subaru?
Incase you missed it reading through the thread.
The Following User Says Thank You to EWY For This Useful Post:
Kwisak (01-14-2015)
Old 12-31-2014, 03:46 PM   #139
Koa
LAZY
The Following User Says Thank You to Koa For This Useful Post:
chas3wba0 (12-31-2014)
Old 01-05-2015, 08:24 AM   #140
chris912
chris912's Avatar
Drives: 2013 Firestorm 6MT FR-S
subbed for future ref
chris912 is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
