Drives: 2013 raven black fr-s
Help me understand the internal WG on EFR
So my experience with turbo has always been aftermarket, but all external wg with a spring. On my err turbo, it's internally gated and I'm trying to check what spring rate I need to have it rated at, but I'm confused.
What I'm seeing on the mid boost wg is that it can crack open as low as 8.8psi, but under full load would receive the 20.6psi. From what I'm seeing here, I think this means it will hold at 8.8psi as the turbo spools and will crack open at this pressure, but hold until 8.8psi (just like a traditional external wg). The 20.6 is just a reference for not trying to run more boost than this. Is this correct? I have my failsafe hooked up, and it's reading between 9-10psi of boost, which is a little high for where I want to be, but I wanted to see if it would even make sense to adjust the wg. http://www.full-race.com/store/image...-content-3.jpg Chart for reference |
#2 |
NASA SpecE30 Racer
If you want to run less than 9 psi, then you need to swap out to the low boost WG canister.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | bakerr6 (01-12-2015) |
#3 |
Coil that's what I was under the impression of. Ty sir
| Cosworth Internal Upgrades Confirmed | DanPO | Engine, Exhaust, Transmission | 60 | 05-26-2015 05:45 PM |
| Products to recommend to repair internal plastic scratch | impossible | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-10-2014 10:06 AM |
| I didn't like the AT and I'm trying to understand why | fiveoneoh | BRZ First-Gen (2012+) — General Topics | 97 | 06-11-2013 01:34 PM |
| internal lighting color debate. help? | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 02-21-2013 03:04 PM |
| What I just don't understand... | Liquidcell | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-30-2012 08:38 AM |
