Old 01-11-2015, 01:39 AM   #29
My car has a steering wheel.
Old 01-11-2015, 01:42 AM   #30
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Ultramaroon and Tcoat meet again... Let the shenanigans begin!
Every time I see you two in a thread together, it never ceases to amuse me.
Bobblehead is offline   Reply With Quote
Old 01-11-2015, 01:44 AM   #31
Old 01-11-2015, 06:22 AM   #32
djmm
djmm's Avatar
Drives: toyota
I've put a few chewing gums on all 4 tires now to improve grippiness. Value for money mod.
djmm is offline   Reply With Quote
Old 01-11-2015, 06:25 AM   #33
djmm
djmm's Avatar
Drives: toyota
Thats embroidery you fool
Old 01-11-2015, 09:21 AM   #34
D_Thissen
D_Thissen's Avatar
@Tcoat so I tried that clutch thing you suggested.. Mind = Blown!
Now, if only I can get that center gauge to level 10! I can only get to 7.4. I must not be worthy of this car
Old 01-11-2015, 10:46 AM   #35
Old 01-11-2015, 11:34 AM   #36
tennisfreak
Drives: 2018 BMW M240i
Sweet OP your tires are doing exactly what they are supposed to do!
For a while I had decided to pick up some MPSS after the stocks wear out but I think I may pick up another set of the stock tires since they are so much damn fun sliding around everywhere. I think with the power this car has stock these tires are great for maximizing how much fun you can have.
Old 01-11-2015, 12:03 PM   #37
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
Try downshifting into first at 50, that should get it there
Edit: because math.
Tgionet is offline   Reply With Quote
Old 01-12-2015, 11:52 AM   #38
paulca
Drives: Toyota GT86 Coupe Red (UK)
0. They were NOT made for the Prius.
1. They are not Prius tyres, only the very top end Prius has them and I think that's only available in Japan and and has a 1.8 petrol engine.
2. They have a fairly poor rolling resistance in Euro tests
3. They have a very high grip rating in Euro dry and braking wet tests
As the OP...
In the dry you will get 100% grip, fine. You can go to 105% the limit and get a bit of tyre squeal. Go to 106% grip and the the level of grip available falls smoothly to about 85% and you slide.
In the wet you can go to 100% wet grip fine (probably about 80% the dry grip on a clean road), you can go a little more and get a tiny bit of float, but when you actually get a slide, the grip levels drop suddenly and unforgivably to about 60% or less. So if your not expecting that kind of grip drop off, you'll get a surprise. If you are expecting it, you get a load of fun at lower speeds.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 01-12-2015, 11:54 AM   #39
paulca
Originally Posted by Tgionet View Post
Edit: because math.
MATHS! Jeez... did you guys burn dictionaries when you parted company with the English?
It's Mathematics. Note the 'ing S on the end, it's plural. That makes the contracted, abbreviated version also a plural, thus mathS.
Old 01-12-2015, 12:30 PM   #40
lolS
Old 01-12-2015, 01:18 PM   #41
Tgionet
SPACESHIP
Tgionet's Avatar
'Murica.
Old 01-12-2015, 01:32 PM   #42
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
'Math' is just as acceptable an abbreviation as 'Maths'. While there's a bit of logic in using 'Maths' as an abbreviation, it boils down to regional preferences. 'Math' is the common abbreviation in North America while 'Maths' is the preferred abbreviation in the UK.
An alternative argument could be made that 'mathermatics' is just a mass noun that ends in 's' and therefore should still be correctly abbreviated as 'math'. It's all up to where you were born.
Our dictionaries remain intact.
Manic is offline   Reply With Quote
2015 BRZ paint easily stained einstein Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 05-12-2015 11:01 AM
Are BRZ .Blue Edition parts easily removable? Stang70Fastback BRZ First-Gen (2012+) — General Topics 18 10-20-2014 08:23 PM
SLIPS, the Last Step Protection of the future? LeftFootBrake Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-15-2012 01:30 AM
Handling a little weird? Pulls/slips while on freeway. kuma Scion FR-S / Toyota 86 GT86 General Forum 29 07-10-2012 05:18 PM
