#2731 |
Drives: 2015 frs
The cold side charge pipe that comes through the passenger side frame rail into the engine bay is hitting the headlight and metal of the frame. Anyone else deal with this? Also seems like my bumper is hitting something. Won't clip all the way under the headlight
#2732 | |
Drives: 2013 Ultramarine FR-S
The spot under the headlight with the bumper is most likely the black clip that secures the bumper to the car. Shine a flashlight in there and check it out. I had the same thing happen to me on one of the many times I've taken my bumper off. It's got like a groove in it that is easy to push the tabs on the bumper over the groove causing the bumper to not sit right. |
| The Following User Says Thank You to Freeman For This Useful Post: | Derka (01-09-2015) |
#2733 |
I can attest that the Skunk2 will bolt up to the Tomei OP. Hope to have the car done in the next 3 weeks, but my job is getting in the way.
@KraftWerks are you seeing that 12-15hp on NA or boosted or both? |
| The Following User Says Thank You to FirestormFRS For This Useful Post: | KraftWerks (01-12-2015) |
#2734 |
Drives: 2018 Subaru BRZ
Thats likely when I'll be doing mine. We're close enough should make a weekend of it lol
On my fourth 86... and everything in between
#2735 | |
Lacking brains
Drives: frz
I'm at whatever the c30 is on stock pulley, and it's pretty much just right for actually driving the car in ways that don't involve a straight line, honking off and or light trees. |
#2736 |
Drives: 2013 Scion FRS in white out
I move to a new house in March, then have 2 weeks off at the end of the month and first week of April. I'll have a double car at this house so plan is to tackle it then.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
#2737 |
Professional Smartass
Drives: White Out FRS
Too late. Plus in houston it gets so hot idling in traffic. I just wanted some piece of mind.
#2738 |
Drives: '14 981CS, '99 NB1
You guys need to add a wastegate to one of your charge pipes so you can bleed boost in low gears... that's how you get traction back on these kits. I did it on my Si when I had a KW kit.
related info: http://becausehonda.com/articles/mor...-boost-control http://becausehonda.com/articles/boost-control
| The Following User Says Thank You to johan For This Useful Post: | Hyper4mance2k (06-09-2015) |
#2739 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
#2740 |
The torque curve is nuts. But, I think it doesn't put out as much power and heat soak may be an issue. Plus I think it's very expensive for the intercooled version.
| The Following User Says Thank You to post_break For This Useful Post: | Chad86 (01-11-2015) |
#2741 |
My understanding was down low it runs even with most superchargers, however loses in the top end. Not entirely sure on the physics as to why. Not too mention it costs nearly the same as other kits that produce more hp.
| The Following User Says Thank You to Triumphrider For This Useful Post: | Chad86 (01-11-2015) |
#2742 |
Positive displacement superchargers are "air pumps", whereas centrifugal superchargers are "air compressors".
#2743 |
My reason for buying kraftwerks was... The hp and tq numbers were good, I like the separate drive belt set up. I find the set up under the hood very clean looking.
| The Following 2 Users Say Thank You to Triumphrider For This Useful Post: | Chad86 (01-11-2015), KraftWerks (01-12-2015) |
#2744 |
I can't seem to find it again but what size spring clamps do I need to secure my hoses under the intake manifold?
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
