#5909 | |
Drives: 2013 Black FR-S
#5910 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#5911 | |
Senior Addict
Drives: 86 GT
#5912 |
The SquadWhisperer
Shoutout to @sw20kosh for taking this explanation on, great work. Those looking at which FI kit to use should have this thread as a mandatory reading :p
I know it is another variable, but in all my shopping around for kits, IAT has always been really important to me due to our engine's CR. The lower the IAT is, the more inherent knock resistance and with that comes the ability to run (slightly) more boost OR run more timing advance at the same level of boost. This is one aspect that lets kits like PTuning's run head and shoulders above the rest of the pack in terms of power output.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#5913 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
If you are running 12 degrees of ignition advance or more, you are not that close to the knock threshold. The closer to 0, the closer to "boom." You have to remember that valve timing, air fuel ratio, and other factors determine final ignition timing. So tuner A may end up running a 5 degree difference in timing over tuner B based on what those other parameters are. So to sum up my findings in the other thread, 19 psi leaves us running a high enough timing number without imminent disaster that I think the setup can work fine for some folks. With a bigger pulley, it will work really good on pump. What you describe otherwise is very accurate...for standard port injection motors with perhaps less efficient head designs. What we see with direct injection turns a lot of that stuff on its head. 5 years ago if someone told me you can run 12.5 CR at 9 psi or more on pump gas reliably I would have laughed. Today that's the default for most kits, and we're running 19 psi and still wondering where that ceiling is. What I'm starting to think here is that with this combo and the right tuning, the only limitations will be drivetrain, quality of the motor from subaru, and overall tensile strength of the rods and how much force the ring lands will take. Bearings are a concern as well since the harder you hammer them the greater the chance it will spin. But that you can see on both pump gas and e85, and there are several cars pushing 300 torque or more on stock motors. Some pop, some haven't (yet). I think this party is just getting started. |
#5914 | |
Just the tip
#5915 | |
Senior Addict
Drives: 86 GT
Alternatively you could try sticking with current belt and 75mm charger pulley, but go with a larger idler pulley. I tried the Nuline EP121 and it tightened up everything. But I still had some squeaks with this setup, although it wasn't as bad as before. |
#5916 | |
It would pretty much be a guaranteed 'no way in hell' on our terrible ACN91 octane here. You would have to retard SO much.
#5917 | |
What if you press the roll pin out of the tension arm only to install the belt? I don't think an extra 5 degrees would yield the spring. Should be ok as long as the tensioner is not operating at that angle, no?
#5918 | |
Drives: Subaru BRZ
#5919 | |
When it comes to E85 you have to completely change your way of thinking about this. E85 basically doesn't have knock threshold. You are not limited by knock with E85. The 210 unit maxes out at ~300 whp on E85 not because of knock, but because of the 210's flow limitations.
#5920 | |
Just the tip
The sound wasn't always there and didn't change anything when it started happening so hopefully nothing is wearing out.
#5921 | |
If you are tuned for 12 psi, then turning the boost down to 9 psi is fine. The ecu will see lower load and adjust accordingly. The issue comes when you increase the boost past what you are tuned for.
#5922 | |
Senior Addict
Drives: 86 GT
But I'm sure with the help of another pair of hands you can coax the belt on even with the 70mm pulley. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
