Old 01-08-2015, 05:27 PM   #225
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
What's nova launcher?
Installed Mods:
Old 01-08-2015, 05:31 PM   #226
CIAGDDS
Drives: BRZ-L
Let's you move around the app folder or hide it and get rid of the Dock. I didn't like the Dock being locked down to the right side of the screen.
CIAGDDS is offline   Reply With Quote
Old 03-25-2015, 06:05 AM   #227
graeme02
Drives: Gt 86
Would it be possible to do this build with the Stock double din player instead of purchasing a new front loader?
I know space might be an issue but are there any other reasons this may not work?
graeme02 is offline   Reply With Quote
Old 03-25-2015, 10:03 AM   #228
scarfo
Drives: gts 86
other then being able to switch sources I don't see why it wouldn't
scarfo is offline   Reply With Quote
Old 03-25-2015, 10:23 AM   #229
Sojhinn
Sojhinn's Avatar
The space is there I believe. The problem would be aux input and how to modify the stock brackets. Honestly sell your stock unit and use the funds to purchase what you need.
Installed Mods:
Old 03-25-2015, 10:25 AM   #230
Sojhinn
Sojhinn's Avatar
Also I used the auto rom for a little bit on my 2012 nexus 7. It worked well but not as smoothly as timurs rom. I still recommend timurs rom.
Also I recently got a steal of a deal on a nexus 7 2013. So I'll be installing that this week.
Installed Mods:
Old 04-04-2015, 02:32 PM   #231
Dylan2015Aozora
Drives: 2015 Subaru Aozora World Rally Blue
hi was just wondering.
1.how do you connect to the odb if your phone is connected can you have multible connections going at once??
2. i dont care about the antena. im only gonna play music through apps or the music player on the tablet. so can i just skip that step entirely?
3. if i dont set up a microphone and just use the head unit harness for the set up will the stock mic still function?
4. why do you need to use the v otb cord? can you not just connect the aux on the head unit to the nexus aux port? then run a regular otb cable(which is 100000 times easier to get)
im eager to hear your input! if it wasnt for you i would have never been able to figure out how this all works. so THANK YOU! i pulled an all nighter last night to figure it out now all my parts are ordered and the head unit bought (i got the one that has the app for your phone and bluetooth)
Dylan2015Aozora is offline   Reply With Quote
Old 04-04-2015, 02:36 PM   #232
Dylan2015Aozora
CAN THIS BE USED INSTEAD OF THE OTB LISTED???? then you dont need a port to connect the usb harness??? someone give your input
Old 04-04-2015, 02:50 PM   #233
Dylan2015Aozora
how can i get timur rom for 1st gen nexus 7? i looked online its gone
Old 04-04-2015, 02:50 PM   #234
Sojhinn
Sojhinn's Avatar
1. My phone is connected to the Bluetooth of the head unit, not the nexus.
2. If I remember correctly you need to have the antenna adapter so that the stock amp starts up properly.
3. No, unfortunately, the stock mic doesn't work.
4. Timurs kernel requires a Y OTG cable for the fixed installation mode. If you search on Amazon they are pretty easy to find. For a future upgrade path, definitely get the Y cable. As for the auxiliary input, a USB DAC has MUCH higher quality sound. It's like night and day.
I can't see your picture.
Installed Mods:
Old 04-04-2015, 03:04 PM   #235
Sojhinn
Sojhinn's Avatar
Unfortunately you can't get the rom any longer for the first gen nexus. Nor do I have it. If you have a first gen nexus 7 I would get auto rom.
Installed Mods:
Old 04-06-2015, 08:33 PM   #236
Dylan2015Aozora
I FOUND THE TIMUR ROM! ANYONE WHO WANTS THE ZIP send me your email through dm
The Following User Says Thank You to Dylan2015Aozora For This Useful Post:
Sojhinn (04-06-2015)
Old 04-23-2015, 02:50 PM   #237
ghost911
Drives: 2012 wrx
Yeah I was trying to avoid that. Figured 12 bucks was worth a shot and it came out great.
Ill be getting the gen 2 and donate to timur for the new 27$
So how do i control the volume through speakers?
Will my subs and amps work juat the same?
Is there no Bluetooth?
I really wanna do this prodject but need to make sure everythi g works like a after market head unit but better.
And wifi of course works.. Would usb teather work?
The entire tablet works through aux to single din behind it correct?
ghost911 is offline   Reply With Quote
Old 04-23-2015, 03:29 PM   #238
Sojhinn
Sojhinn's Avatar
If you follow my instructions above the head units runs your speakers.
As for volume for the speakers... Set a volume that's too high to listen to normally then back off the nexus 7s volume. Or use a remote or an app for the head unit (Sony and jvc) to control the volume through the nexus 7.
My head unit has Bluetooth and it switches to my phone when receiving calls or starting calls.
Recently I installed new speakers, a sub and an amp. These are all connected through the head unit and would work as they normally do.
Remember you still need a head unit with above method but it just needs to have whatever features you want. I would lean towards a sony unit right now.
Installed Mods:
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 12:04 PM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 09:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 04:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 11:17 PM
