#29 |
Drives: 2015 FR-S - Halo
#31 |
#32 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
@msugi07 here is the thing to keep in mind. Spring rates don't really determine how nice a set-up rides, its the dampening. Good dampners are expensive which is why suspension is one of those areas where you get what you pay for. You could spend $4K on JRZ or Tein SRC with 10k/12k setups and probably ride smoother than a set of $1K BCs with 7k/8k springs.
Ask around Friday at the Dublin meet as there will be plenty of different suspension pieces, and many wil be willing to give you a ride to see for yourself. The stock dampners are very good, which is why a proper spring setup in this car is fantastic and really all thats needed if you just want a drop for the street and get a little performance increase. Short list for your budget: Springs: Swift sport springs RCE Yellows Mann Engineering springs Coilovers: Tein Street Flex ST Bilstein PSS 14 Used RCE zero |
| The Following 3 Users Say Thank You to finch1750 For This Useful Post: |
#33 | ||
Drives: 2014 Subaru BRZ
| The Following User Says Thank You to PERRIN_Chris For This Useful Post: | Clott (01-06-2015) |
#34 |
Loading...████████] 99%
Drives: #0517
have been through a number of 'coilover'/spring/sleeve setups on my old cars and i realized that i never adjusted the height at all after i set it to where i wanted it... granted, i have never tracked my cars and thus never felt compelled to get them corner balanced (that would be where i could see coilovers being more beneficial). also always had to check the collars to make sure they were tight from time to time/had odd noises and whatnot...
for my own personal uses and in my own personal experiences, a set up with quality springs and quality dampers worked the best. comfortable street set up and never had to worry about checking for loose collars, didn't have to mess with damper settings... that's probably what i will end up going with when i modify the set up on my frs... for now, stock feels great and is plenty fun |
| The Following User Says Thank You to asdf For This Useful Post: | Sugi (01-06-2015) |
#35 | |
#36 |
Drives: 14 BRZ Crystal Black Silica Limited
#37 | |
In the $1k range.... If you really must have a bigger drop (more than around an inch), I'd recommend coilovers. You should get a set with quality valving...that's the biggest priority and unfortunately the hardest part to get good information about. Nothing around $1k is going to have great valving. ST and Bilstein PSS will be pretty good but won't work well for drops over 1.5 inches. For big drops, you should consider BC or whatever else...that's not my thing. For a primarily street driven car with a drop of 1 inch or less, springs are good. For $1k you can build a good handling set-up that still rides well and is functional. I would prefer this route over cheap coilovers but I don't need/want a big drop. If you do track days or auto-x, you should consider increasing your suspension budget. You can still have fun stock or with good springs, but coilovers or springs with at least a few toppings will go a long way. - Andy Last edited by Racecomp Engineering; 01-06-2015 at 03:12 PM. |
#38 |
Because compromise ®
Drives: Red Herring
You believe wrong.
BRZ 2.7k /3.4k FR-S 2.3k /3.7k
| The Following User Says Thank You to Captain Snooze For This Useful Post: | chas3wba0 (01-06-2015) |
#39 | |
Drives: Red Herring
http://www.tein.co.jp/e/special/ni_toryu/index.html "It is not a matter of which design is better than the other, but providing the most suitable design for the purpose is." Don't get caught up in This is better than That. Shades of gray.There are twin tube dampers that are better than cheap mono-tubes. Also don't get caught up in brand names. Tein's $700 dampers are not the same as their $14,000 dampers. Everything's a compromise. <- Remember that.
#40 |
I usually do, but the GF is sick so hopefully she gets over it in time. If I do go I'm on RCE yellows with stock sturta and can give you a ride along.
#41 | |
< I had to put that
#42 |
BOXER FR
Drives: WRB BRZ Limited
after driving many different set ups, I`ve learned that there are no comfortable coilovers for under $3000. if the maximum amount you can spend is a $1000, you should figure out what you want the most: comfort, drop, or performance. I don't think you can get all three for the $1k budget. and make sure to go for drives/rides in different set ups. what is comfortable for others may not be the best for you.
or, you can do what I did. take your gf/wife/significant other in a ride with a car set up with the Ohlins DFV kit. Now that she had a taste of a car that is way more comfortable and feels more planted (safer feeling), she is convinced that the more expensive kits are worth the investment
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
| The Following 2 Users Say Thank You to mokinbird87 For This Useful Post: | Captain Snooze (01-06-2015), Stevehan (01-07-2015) |
| WTB: Coils | _frs | Want-To-Buy Requests | 4 | 08-28-2014 07:40 PM |
| 08+ wrx coils on a brz? | bee_are_zee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-01-2014 07:26 PM |
| st coils vs stance | jdmblood | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 01-18-2014 04:39 PM |
| St coils vs BC BR? | motorsports3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-26-2013 06:01 PM |
| Need help picking coils | WolfsFang | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 03-11-2013 09:31 PM |
