Old 01-05-2015, 03:59 PM   #1
JARE_ee
Alaska Roll Lover
JARE_ee's Avatar
Drives: Blue.Series.Aozora
Pro-Kit Installed, but...
Hello,
this is my first car, and i am new to the whole car modification thing. Basically i lowered with Pro-Kit springs (very happy with the results, will post pictures later) I had it aligned right after install.
There are two issues that i am concerned with:
1. I am hearing its not so good to aligned your car right after installing them because it would be best to have the springs settled before aligning, is this true? do i need a realignement again in the near future?
2. Do i need any camber adjustments for these springs? it is only 1 inch drop, and the mechanic said it wasn't necessary. But i would like to ask the people here, rather than trusting the mechanic (first time @ that shop)
JARE_ee is offline   Reply With Quote
Old 01-05-2015, 04:02 PM   #2
Racecomp Engineering
1. It doesn't take much to let the springs "settle." Drive the car 50 miles, get an alignment, and you're good.
2. Need...no. There is the super cheap OEM camber bolt (less than 10 bucks) that will help you get a little camber up front for better handling. It's not a lot of camber so it won't cause excessive wear...just a little bit to help the car handle better.
- Andy
JARE_ee (01-05-2015), Wise (01-05-2015)
Old 01-05-2015, 05:46 PM   #3
2much
I wanna go fast
Drives: 2013 FR-S 6MT
- Andy
As a side note - is there an agreed upon front and rear camber that is optimal for daily driving and occasional track? I would guess something like -1.0F and -.5R but my camber tuning is limited to gran turismo
2much is offline   Reply With Quote
Old 01-06-2015, 06:19 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The rear gains natural camber, some camber bolts up front would be all thats needed, i havent memorized camber ranges for this car yet so i'll let Myles or Andy or @CSG Mike to answer those.
The Following User Says Thank You to cdrazic93 For This Useful Post:
2much (01-06-2015)
Old 01-06-2015, 06:31 PM   #5
CSG Mike
CSG Mike's Avatar
Around -1 to -1.5 rear is good for most cars, with a hair of toe-in.
Toe changes with height change, and that's the REAL reason you want to get an alignment after dropping the car. Drive the car for 50-100 miles to let everything settle in place, and then get an alignment. Bad toe can make the car behave erratically, massively increase tire wear, etc.
2much (01-06-2015)
Old 01-06-2015, 06:41 PM   #6
2much
I wanna go fast
Thanks for sharing Mike. I am trying to get a good estimate because I will be tracking for the first time in a month or two and want to be at least vaguely "dialed in."
I will be installing RCE springs soon and installing wheels/brake upgrades/and alignment no earlier than a week after the springs. I imagine a 20mm lower will not affect camber/toe very much, is this correct?
When the alignment is performed, should I specify the need for slight toe in? Or is this some sort of golden rule that works on all cars and all shops know to do it?
muchos gracias
edit - holy shit your shop is in OC? I might have to come by
Old 01-06-2015, 07:21 PM   #7
CSG Mike
CSG Mike's Avatar
muchos gracias
I live in OC.... CSG is in Santa Fe Springs... and I'm not a CSG employee, just the test driver. Go to West End for an alignment, and they'll get you squared away.
http://www.yelp.com/biz/west-end-alignment-gardena
You should join us for 86CUP and meet all the FRS/BRZ track regulars
http://www.ft86club.com/forums/showthread.php?t=80202
2much (01-06-2015)
Old 01-06-2015, 07:33 PM   #8
2much
I wanna go fast
I was going to go to evasive... you both seem to be in the same place... now I have a headache
Old 01-06-2015, 07:36 PM   #9
Panman
Panman's Avatar
Drives: 86 GTS
@CSG Mike - If you have 3.0 Neg camber at the front, What would you recommend at the rear? I'm at 1.5 at the rear now. Toe is Zero all round.
Panman is offline   Reply With Quote
Old 01-06-2015, 08:17 PM   #10
CSG Mike
CSG Mike's Avatar
Track or stance setup? What kind of tires?
Old 01-06-2015, 08:35 PM   #11
Panman
Panman's Avatar
Drives: 86 GTS
Track, 18x8 OZ Ultraleggeras with (currently) 595RS-R going to Hankook RS-3
Old 01-08-2015, 02:43 AM   #12
Panman
Panman's Avatar
Drives: 86 GTS
Sorry @CSG Mike should have tagged you.
Old 01-08-2015, 03:38 AM   #13
CSG Mike
CSG Mike's Avatar
I'd go maybe -2.6 front -2.25 rear.
Panman (01-08-2015)
Old 01-08-2015, 05:08 AM   #14
Panman
Panman's Avatar
Drives: 86 GTS
Thanks @CSG Mike
Scion installed vs dealer installed fog lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 10 02-16-2014 12:55 PM
Does anyone have a JR SC installed? Venator Forced Induction 55 02-15-2014 02:36 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 12:09 AM
Just Installed RS-3 Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-27-2012 09:41 AM
