Old 11-21-2014, 02:09 AM   #57
CSG Mike
CSG Mike's Avatar
E85 is a "flat fee" because FI also factors in fueling limitations.
There are other points that simulate and accurate reflect additional power
There is a draft of the proposed 2015 rules floating around....
Old 11-21-2014, 03:21 AM   #58
BongMan
Red face Suspension Changes?
I noticed in the Chronoseries 2015 worksheet posted in the NorCal thread
http://www.chronoseries.com/classer.php?car=ft86
There were several suspension items that added points, or increased points for existing items:
camber plates and/or spherical top hats - .375 (was free)
rear lower control arm - .125 (was free)
aftermarket damper w/ aftermarket spring, or coilover suspension 2.00 (was 1.50)
My question is does getting coilovers with camber plates cost 2.375 (2.00 for coilover and .375 for plates)? I feel this might have been too many points assigned for a single mod. It costs nearly as much as say a HKS supercharger Rev 2 (2.50), which I can only imagine would give you a bigger edge on longer more powerful tracks.
As for the rear LCA, shouldn't that have similar cost to the camber bolts, i.e. free? I think most people are using them to dial out extra camber from lowering, rather than getting additional camber or track.
My last concern is the proposed 2015 rules would put me into the revised "unlimited" class by taking points for rear LCA and top hats. I can only imagine I would uncompetitive a total of 3.75 points (8" wide wheels, 245 tires, Coilovers, Catless FP, vs some of the FI cars like ImperiousRex or sw20kosh.
So if we could not inflate suspension points that would be swell.
Thanks for your consideration
BongMan is offline   Reply With Quote
Old 11-21-2014, 03:23 AM   #59
CSG Mike
CSG Mike's Avatar
The NCRC website is not 100% accurate right now.
At 3.75 points, with the proposed 2015 rules, you would still be in the Street class, which has a proposed cap of 4.0 points.
MyRx (11-21-2014)
Old 11-21-2014, 11:41 AM   #60
MyRx
MyRx's Avatar
@BongMan - the NCRC site is info-purposes only right now. It's database driven so it can change in an instant. We wanted up to make sure NCRC's end of work is prep'ed and completely early rather than later. They are going thru great lengths to make the 86cup easy for everyone. Not to mention, a similar calculator has been passed around offline. Online, more people can use it and use it quickly. Like stated, paper/email registration is so 2014. But I know that works for others, not really for NorCal - too many communications between I, NCRC, and registrant(s).
If anyone would like to see it differently, for your region/86Cup per say, let me know and I'll see if I can't ask for a different region/calculator.
Old 11-25-2014, 05:14 PM   #61
daywheniwaschillin
I noticed there are some DOT R-Comp tires missing from the list, not sure how many competitors are running R-Comps but could you add them for clarification? Or to help everyone see additional options? I list a few below along with where I believe they rank.
Toyo Proxes RR - Level 2
Hoosier R7 - Level 2
Hoosier A7 - Level 3
BFG R1-S - Level 3
Hankook Ventus Z214 C51 - Level 2
Hankook Ventus Z214 C71 - Level 3
Are non-DOT slick tires prohibited?
Also, have there been talks with any companies to offer contingency? This would be a great incentive to get more participants at events.
daywheniwaschillin is offline   Reply With Quote
Old 11-25-2014, 05:57 PM   #62
CSG Mike
CSG Mike's Avatar
BFG R1-S - Level 3
All in the works, and yes, the goal for 2015 is to have some contingency programs in place (although we're not talking to any racing tire companies *cough* due to nobody actually running them...)
Old 12-12-2014, 02:41 AM   #63
juliog
juliog's Avatar
Drives: 86
I'd like to try RC1s but I'm still waiting for a certain set of forgies...
Sent from my iPotato
juliog is offline   Reply With Quote
The Following 2 Users Say Thank You to juliog For This Useful Post:
CSG Mike (12-12-2014), retrosmiths (12-18-2014)
Old 01-04-2015, 10:24 PM   #64
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
Hey @CSG Mike, how many points would the new Moroso oil pan baffle count for or would it be a free mod seeing how it doesn't give any performance gains?
http://www.jegs.com/webapp/wcs/store...&storeId=10001
WillRacer1jz is offline   Reply With Quote
Old 01-05-2015, 03:10 AM   #65
CSG Mike
CSG Mike's Avatar
0 points. We used to have it in the rules, but it was "removed" for clarity.
WillRacer1jz (01-05-2015)
2014-2015 Winter Tire & Wheel Discussion Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 153 07-02-2016 10:45 PM
Discussion: Did the 2015 Subaru WRX get nudered because of numbers? FRSFrank Other Vehicles & General Automotive Discussions 27 05-28-2014 11:33 PM
2014 FT86CUP rules discussion CSG Mike Tracking / Autocross / HPDE / Drifting 34 11-18-2013 05:15 PM
Berk Technology FT86Cup Rules/Classing Discussion CSG Mike Southern California 3 02-22-2013 05:11 PM
