Old 12-31-2014, 09:06 PM   #211
styl3z
styl3z's Avatar
Drives: 2013 Scion FRS Whiteout
Originally Posted by Sojhinn View Post
Is there a a little gap between your nexus 7 and the bezel?
For some reason when I have the same setup I can see a bit of gap at the bottom between the nexus 7 and the bezel just like in the picture. And what torque widget is that?
styl3z is offline   Reply With Quote
Old 12-31-2014, 09:08 PM   #212
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Tiny gap for me. Not noticeable. Regular torque widget.
Installed Mods:
Old 01-02-2015, 05:05 AM   #213
CIAGDDS
Drives: BRZ-L
What do you connect the Brown Factory Amp Turn On wire (From the 10 pin connector) to?
- I think this is how it goes, let me know if this is correct; Brown wire from the car harness goes to the blue wire on the metra harness, then that blue wire connects to the blue/white remote amp turn on wire from the JVC harness along with the blue wire from the antenna adapter. ?
CIAGDDS is offline   Reply With Quote
Old 01-02-2015, 11:17 AM   #214
Sojhinn
Sojhinn's Avatar
Not sure about the brown wire. Only 1 wire wasn't used for me. As for the antenna power on the metra antenna harness there's a blue wire that needs to be connected to the other harness (with a lot of wires) power antenna line.
Installed Mods:
Old 01-02-2015, 05:31 PM   #215
styl3z
styl3z's Avatar
When I turn on the car, for first five seconds I get a small whine/white noise sound when using the aux. After that everything is clear, is this normal?
Old 01-02-2015, 05:32 PM   #216
Sojhinn
Sojhinn's Avatar
Another Nexus 7 install: Clean and Easy
Same setup as me? If so no.
Installed Mods:
Old 01-03-2015, 01:28 AM   #217
CIAGDDS
Drives: BRZ-L
Got it all setup today. The DAC is definitely worth it, couldn't believe the sound difference. Last question, is there a way to have the Nexus automatically start playing music when it wakes from deep sleep?
Old 01-03-2015, 01:31 AM   #218
Sojhinn
Sojhinn's Avatar
Use a program called tasker. Should help you set that up.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
CIAGDDS (01-03-2015)
Old 01-05-2015, 02:10 AM   #219
Sojhinn
Sojhinn's Avatar
@CIAGDDS how's it working? How's auto droid?
Installed Mods:
Old 01-05-2015, 06:15 PM   #220
CIAGDDS
Drives: BRZ-L
Well, I've only used t a couple days now, but so far it's working great and I'm very excited about the install. I've yet to use taskr to set up the auto play music because I'm waiting for my weekend to start. I have Torque setup and working along with the JVC Smart Control App to change sources on the JVC KDX310BT deck so I retain my AM/FM stations. Both the OBD bluetooth and bluetooth from the Nexus to the JVC receiver connect at the same time without issue. I'll post a couple pics in a couple days.
The Following User Says Thank You to CIAGDDS For This Useful Post:
Sojhinn (01-05-2015)
Old 01-05-2015, 06:29 PM   #221
Sojhinn
Sojhinn's Avatar
Thanks for the heads up. Keep us informed. Sounds like the 310bt may be a better unit now.
Installed Mods:
Old 01-08-2015, 02:17 PM   #222
CIAGDDS
Drives: BRZ-L
I got Tasker up and running. I have it set to open my music player (DoubleTwist) as soon as the screen turns on, it then selects the now playing tab and starts the music. Pretty sweet.
Sojhinn (01-08-2015)
Old 01-08-2015, 02:24 PM   #223
Sojhinn
Sojhinn's Avatar
Nice! Im glad I could help. Do you mind running down your purchase list? I think I will update the first post.
Installed Mods:
Old 01-08-2015, 04:07 PM   #224
CIAGDDS
Drives: BRZ-L
I pretty much bought what you had listed in your post. I just shopped around for the best prices.
(1) Nexus 7 (2012) with 4G Cellular (Craigslist) - $150.00 unopened
(2) JVC KDX310BT (Best Buy) - $90
(3) Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker (Ebay) - $3.75
(4) Metra 40-LX11 Antenna Adaptor (Amazon) - $11.50
(5) Sabrent USB 2.0 Virtual External 7.1 Surround Sound Adapter (Amazon) - $5.99
(6) Micro USB Host OTG cable (Ebay) - $3.69
(7) BAFX Products - Bluetooth OBD2 scan tool (Amazon) - $23.99
(8) AX-ToyUSB Adapter (Ebay) - Didn’t use because I ended up using the JVC USB port to power the Nexus - $8.99
Android Apps:
Autodroid 1.2 Rom - Free
Media Utilities - Free
Nova Launcher - Free
DoubleTwist Music - Free
Tasker - $2.99
Torque - $4.95
Total - 305.85
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 08:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 03:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 10:17 PM
