Old 01-03-2015, 02:07 AM   #1
wootwoot
Drives: FRS
Rear upper control arm ball joint?
Trying to get the part number for the ball joint that is on the rear upper control arm. Searched but can't locate it.....
Old 01-03-2015, 02:22 AM   #2
wootwoot
Drives: FRS
Both toyota and subaru only show the entire rear upper arm being for sale..... You have to be able to buy just the ball joint right?
Old 01-03-2015, 03:30 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Buy a salvage one?
Old 01-03-2015, 02:47 PM   #4
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
I wish this were true!! When we originally designed the upper control arms we wanted to offer them with an OEM ball joint, however Toyota has considered it a non-serviceable item and you have to replace the whole arm!! Thanks Toyota!!
I also recently discovered that the front lower control arms have gone the same route late in 2014. We were purchasing 20 to 30 OEM front lower control arm ball joints, but apparently the part number does not exist anymore and according to some dealerships never existed!! The front lower control arm ball joint is now considered non-servicable as well.
Jeff@Racer X Fab is offline   Reply With Quote
Old 01-03-2015, 02:55 PM   #5
wootwoot
Drives: FRS
Sweet....
I destroyed my ball joint dust boot taking the arm out. Any idea where I can get a new boot? Aftermarket?
Old 01-03-2015, 07:12 PM   #6
Jeff@Racer X Fab
Sweet....
I know that energy suspension makes aftermarket dust boots, I do not know how well they fit or how effective they are. I also know ebay has several universal dust boot kits, again now sure how good they truly are.
QA1 may also have universal dust boots as well. Hope that helps some.
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
finch1750 (01-04-2015)
Old 01-05-2015, 08:44 PM   #7
Poodles
Drives: 2015 Series.Blue
Not a first for Toyota. For example, the upper ball joints on a MKIII Supra are non serviceable as well.
Old 01-05-2015, 10:54 PM   #8
wparsons
wparsons's Avatar
Audi S4's are the same, and they have like 8 arms per end of the car!
flickr
Old 01-06-2015, 08:17 AM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
I did a search to see if MOOG offered something, typically they'll having one of their "problem solvers" for these situations. I didn't find anythign there either.
They do have adjustable toe arms
http://www.moog-suspension-parts.com...d=MOOG-K100124
and adjustable lower control arms though.
http://www.moog-suspension-parts.com...d=MOOG-K100136
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 04:04 AM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 05:40 AM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 10:17 AM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 10:01 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 02:16 PM
