Old 01-02-2015, 08:09 PM   #2325
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
Originally Posted by chriskory View Post
How do these brake pads look? EBC yellow
Egads, man!
Hoosier Daddy is offline   Reply With Quote
Old 01-02-2015, 09:17 PM   #2326
chriskory
Drives: 1991 honda civic si
NA. Completely stock drivetrain, down to the (bad) factory tune (that cost us multiple engines).
I have an early build BRZ 04/12, but when I called the dealer about getting a reflash they said there are no open recalls. Is the factory tune separate from that?
chriskory is offline   Reply With Quote
Old 01-02-2015, 09:26 PM   #2327
CSG Mike
CSG Mike's Avatar
There is no factory "fix" for it that is retroactive. Having a fix would also mean that Toyota/Subaru is admitting that there is fault.
Old 01-05-2015, 12:00 AM   #2328
M23
Drives: 86
Just SRCs. Zero other suspension components, except camber bolts (which are moot since the SRCs already have camber/caster plates).
I haven't attempted any record laps with the JRSC on.
Well...you better get to it!
M23 is offline   Reply With Quote
Old 01-05-2015, 01:54 AM   #2329
ZionsWrath
Thanks
ZionsWrath's Avatar
I've just swapped the street pads back on after a track day, but these left some grooving on the rotors. Should I still do the same bedding process on an imperfect rotor? Also, any noticeable difference in pedal quality between two person bleeding and using a motive pressure bleeder?
Thanks
I had EBC Yellow on my Accord that is only a DD and I thought they were trash.
Try something else IMO
Old 01-05-2015, 02:10 AM   #2330
CSG Mike
CSG Mike's Avatar
Are you funding the attempt??!?
Old 01-05-2015, 02:15 AM   #2331
ZionsWrath
Thanks
ZionsWrath's Avatar
@CSG Mike
Saw the Super Lap Battle vid
Old 01-05-2015, 03:03 PM   #2332
M23
Drives: 86
Haha ...if I was rich or owned some big parts company, I'd def be your sponsor
What are everyone else's times at SOWS CW?? Please state if NA or SC/FI.
...I am sure there's a lot of really talented drivers here, especially from all the vids/discussions out there
Old 01-07-2015, 08:10 PM   #2333
redlined600
redlined600's Avatar
Drives: Fr-s
For an early car that falls into the affected di seal range would an updated flash from toyota(scion) be ok on track or is an aftermarket tune the safer route?
Also, roughly what's the fuel consumption per 20 min. session with 91 tune and e85?
Thanks
Thanks
redlined600 is offline   Reply With Quote
Old 01-07-2015, 09:01 PM   #2334
juliog
juliog's Avatar
Drives: 86
Fuel consumption is track dependent, can be anywhere from 15% to 25% of the total fuel capacity per session. You will use more fuel on tracks where you spend more time at WoT.
juliog is offline   Reply With Quote
Old 01-07-2015, 10:40 PM   #2335
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
Will the stock pads hold up for one HPDE weekend? I don't expect to have them much after that but I was curious about whether or not it will be a necessity to have my track pads before the event.
VADERR is offline   Reply With Quote
Old 01-08-2015, 12:43 AM   #2336
Jonsey
Jonsey's Avatar
I think they will survive the weekend, but you will likely have fade issues. I was able to fade them by the middle of each session on my first track weekend ever.
On another note, I see you are local. What event are you doing?
Jonsey is offline   Reply With Quote
Old 01-08-2015, 01:43 AM   #2337
CSG Mike
CSG Mike's Avatar
@CSG Mike
Old 01-08-2015, 01:44 AM   #2338
CSG Mike
CSG Mike's Avatar
Thanks
Thanks
Even if you get an updated tune, you may have latent damage. With fresh seals and an updated tune, you should be okay.
Fuel consumption is driver and track dependent. We observe about 3.5-4MPG on track. With E85, expect that to be lower by 30% or so.
We ALWAYS recommend mixing in some 100 unleaded if you are tracking. It is cheap insurance.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
