Old 01-02-2015, 08:45 AM   #1
mynameis940
mynameis940's Avatar
Drives: WRX
My battery keeps dying
My battery has been dying if I leave the car for 50 hours. The only mod I have is the winjet fog lights. The power to the lights is straight from the battery but the power to the switch is from a power source that doesn't have power unless the car is running. Is it possible that there is a slow power drain even when the car isn't running or did I mess something up?
mynameis940 is offline   Reply With Quote
Old 01-02-2015, 09:43 AM   #2
Koa
Some more Q's to give people a better idea on how to help:
- Is it normal for you to leave the car uncranked for 2+ days before the Winjet fogs?
- Who installed the foglights?
- Have you had the car in for maintenance recently?
- Have you disconnected the fogs from the battery to try and determine if that is the source of the draw?
I'm shooting in the dark without these answers, but part of best practice for any electrical troubleshooting involves (1) checking the circuit as a whole with a multimeter to try and find a draw that isn't supposed to be on car 'off' mode, and (2) having the battery tested.
Old 01-02-2015, 09:58 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
How To Perform a Parasitic Draw Test - EricTheCar…: [ame]http://youtu.be/KF1gijj03_0[/ame]
For your case the first thing to disconnect rather than going to the fuse box should be the wiring on the winjet foglights then move onto the box.
Old 01-02-2015, 01:01 PM   #4
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have had battery issues a few times this year. both times was leaving the car in auxiliary mode while working on it. Had to jump it both times. I felt it was strange that it happened while only being in that mode maybe 30 minutes at most.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 01-02-2015, 01:11 PM   #5
Imrac
Drives: 13 SWP BRZ Prem
If you have it in Aux, make sure your HVAC fan settings are turned off. It can be a pretty hard drain on the system. (no idea if that is actually the cause, but throwing it out there as something I noticed)
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 01-02-2015, 02:18 PM   #6
mynameis940
Drives: WRX
I had left it before and it was fine, I installed them myself. I'm going to take It off The battery next time I leave my car for two days. I was planning on doing that but I'm not sure why it would cause it to drain when the switch is connected to aux power inside the car. It shouldn't be draining the battery but I don't know.
Old 01-02-2015, 02:48 PM   #7
Foobar
SLO NO MO
Foobar's Avatar
Panasonic usually makes pretty strong batteries, but in my experience with our OEM model, once I accidentally ran the battery down leaving my dome light on, it never retained a strong charge thereafter.
I've swapped out for the Optima YellowTop Dual-Purpose Battery, Group 75/25, 620 CCA - Model # D35, no problems since, even after accidental run downs.
Old 01-02-2015, 04:25 PM   #8
mynameis940
Drives: WRX
That might be the cause I left my dome light on 2 weeks ago and now it dies after then often. I'll try removing the fog lights off the battery and if it still dies that may be the cause.
Old 01-02-2015, 08:07 PM   #9
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Uhh...that really doesn't make sense.
Correct switched power circuit:
Source>switch>load device.
How can you have "power to the lights straight from the battery" if you have a switch to control the power to the light lights?
If you actually have "power to lights straight from the battery", then then the lights are energized continously and the switch plays no role.
billwot is offline   Reply With Quote
Old 01-02-2015, 08:09 PM   #10
mynameis940
Drives: WRX
I thought it was weird as well but look up the winjet fog lights. The lights turn off when the switch or car is off. It goes power > lights > ground but then the switch also has power and a ground. The switch is connected to an aux power and the headlights are connected to the battery. The winjet how-to video shows it.
Old 01-03-2015, 06:56 PM   #11
billwot
Ahh...OK. They're using a switched ground to make and break the circuit.
Old 01-03-2015, 06:57 PM   #12
mynameis940
Drives: WRX
No theres a ground next to the lights and another one for the switch.
Old 01-03-2015, 09:31 PM   #13
fritzburg
fritzburg's Avatar
Drives: 2015 Scion FR-S
^this
fritzburg is offline   Reply With Quote
Old 02-14-2015, 05:39 PM   #14
mynameis940
Drives: WRX
Alright so it's still happening and I bought a multimeter and when the car is off it's drawing .68 amps. I pulled the dcc fuse and it dropped down to .2, so then I unplugged my ca-fi dashlinq head unit inside the car and put the dcc back in and it was at .2. Why is this head unit drawing so much power when its off? I haven't seen anyone have a problem with this
Is there a DIY/FAQ on re-dying the interior stitching? Michael Blue Cosmetic Modification (Interior/Exterior/Lighting) 29 08-29-2014 12:34 PM
Aftermarket Header Dying Cricket Noise Squido3J Engine, Exhaust, Transmission 6 03-31-2014 06:07 AM
Dying to hear this!!! sweetfrs Engine, Exhaust, Transmission 8 09-19-2013 09:17 PM
I'm dying over here! coastertrav Scion FR-S / Toyota 86 GT86 General Forum 18 04-15-2013 06:41 PM
Forum is Dying #87 Scion FR-S / Toyota 86 GT86 General Forum 49 06-08-2010 11:36 PM
