#1597 | |
Drives: FT86
you guys are on G rom man and I rom auto same as here in australia but openflash tablet wont auto generate for some g and i roms however if your A00I A01I A01G A00G D00G you are supported already, but you will have to download tunes v2.062 from openflash site unzip and upload tune via openflash manager software. if you have an A02G rom or an I rom not supported i would like a copy of the rom thanks |
| The Following User Says Thank You to steve99 For This Useful Post: | coeurdencre (01-02-2015) |
#1598 |
Drives: FT86
do you get the windows beep when you connect to usb and does screen on oft light up if nt might be hardware problem try new cable , does it work when connected to car
#1599 |
#1600 | |
Drives: 2014 x ZC6 x 37J
I can see the ROM Stg1 700G/A00G/A01G/D00G.bin in "OFT OTS v2.062\BINs\ZA1J___G ROMS (EU 6MT)\Stage 1" folder 700G ROM is the one I need to use with OpenFlash Manager ? These ROM are for 91 or 93 ? We got 95/98/100 fuel here... |
#1601 | |
Drives: FT86
with the european and australian g roms its basicy the 91 tune only offered. if your going to run 100 ron fuel all the time you could copy the base timing b table from a usa rom to your g rom. but for now just load up the 700G tune and all will be ok have a read of the oft tips link below |
#1602 | |
I'll try the 700G, I was not sure about it. Thanks for information
#1603 |
Drives: Toyota 86
stage 1 vs stage 2 oft
can someone please tell me the difference between stage 1 and stage 2 tunes?
thanks |
#1604 |
Stage 1 is stock header. Stage 2 is aftermarket catless header. If I'm not mistaken.
#1605 |
Drives: Surbaru WRB BRZ
Hey guys,
I recently upgraded to the OF Header and the tune for it, but that removed my ability to choose to show what gear I'm in on the dash. Has anyone else had a similar problem and is there a way of easily rectifying it in an editor or something? |
#1606 |
Drives: 2014 SWP BRZ, MT
That's turned on from the dash and unrelated to what you can change in an ECU map. The settings usually get lost if the battery is disconnected. Press the odo button multiple times while the car is completely off or in ACC and you should be able to get to G-off, change it to G-on.
The answer is racecar. Always.
| The Following User Says Thank You to zkv476 For This Useful Post: | Shiv@Openflash (02-18-2015) |
#1607 | |
SLO NO MO
It resets every battery disconnect. Edit: zkv476 beat me to it. Sent from my Nexus 5 using Tapatalk |
#1608 |
Drives: Toyota 86
#1609 | |
Drives: FT86
If by chance you get the P0420 cel code for cat efficiency thrown (its not disabled in stage 1 tunes, just disable it using romraider. If you get no knock on that tune you could try the stage 2 EL tune, but it runs more timing advance (and more fuel) than stage 1 tune, you will also need to monitor your AFR. Its unlikely on our 98 ron fuel you will be able to run the stage 2 tune with a catted header without encountering considerable knock. You could run the stage 2 EL E85 tune if you wanted to switch to E85 fuel and the E85 tune. |
#1610 | |
Drives: Toyota 86
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
