Old 12-29-2014, 02:59 PM   #113
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Originally Posted by Toyota John View Post
Is is possible to make your own plug in play with this? Splice the wires off a wideband sensor to the cut off plug of a secondary O2? Or do I need an external source of power and ground?
I recommend wiring a separate external power and ground. The secondary O2 plug shares a ground with the throttle body, which seems particularly sensitive to noise and voltage fluctuations.
FrX is offline   Reply With Quote
Old 12-29-2014, 03:27 PM   #114
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
This is why we do separate power/ground on our flex fuel.
FYI we have these available now: http://www.moto-east.com/store/moto-...ness-ft86.html
Includes the connector and pigtail as well.
Xero-Limit is offline   Reply With Quote
Old 12-29-2014, 03:27 PM   #115
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
There was a thread buy Shiv from OFT where he was saying he was going to make a pnp unit for this but I guess that are working on their turbo kit first.
Edit-just read your post mike would i need the optional power and ground +10?
Toyota John is offline   Reply With Quote
Old 12-29-2014, 07:33 PM   #116
Xero-Limit
Xero-Limit's Avatar
IF you wanted to wire the power and ground into the rear o2 plug. It's just pinning the other 3 pins vs leaving them blank so it is a little bit more time and materials. We do it in house now whenever possible because nothing like shipping a bunch of connectors overseas to only get RMAd because some clown did not crimp the pin properly.
But you should get the power from the fuse box, and ground it to the bolt right there or wherever else. We have the low pro fuse taps in the online store or you can get one wherever you'd like for that.
Old 12-29-2014, 08:30 PM   #117
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'll be ordering one of your plug harness thingy. Do you have a picture of how it looks?
Fizz is offline   Reply With Quote
Old 12-30-2014, 08:39 AM   #118
Xero-Limit
Xero-Limit's Avatar
Will get it updated when I get back to the shop today, we closed up for service for two weeks so we can get the accounting and remote tuning caught up.
Old 12-31-2014, 08:21 AM   #119
wowy
wowy's Avatar
Drives: 1990 Mazda Miata, ISO 2022+ BRZ...
I just got their flex fuel kit with the rear O2 sensor option and I've attached a picture of the cable I received with it. @moto-mike is this what folks can expect?
wowy is offline   Reply With Quote
Old 01-01-2015, 09:25 AM   #120
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@moto-mike So with that harness do we just remove the factory rear O2 harness altogether, plug the connector into the now vacant slot, then crimp the other end of that white wire to the analog signal wire from the wideband gauge......yes?
Old 01-01-2015, 10:31 AM   #121
Xero-Limit
Xero-Limit's Avatar
That's correct. Just make sure to disable rear o2 learning and codes as mentioned elsewhere in this thread.
Old 01-10-2015, 12:00 PM   #122
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Sorry about the duh question, but can I use a self-sealing butt connector to join the analog wire to the harness wire?
Old 01-10-2015, 08:17 PM   #123
Xero-Limit
Xero-Limit's Avatar
Sure, solder is best but the heat shrinking butt connectors work fine and we still use them on some versions of the flex fuel kits.
Old 01-10-2015, 09:39 PM   #124
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks. I wanted to use solder but www told it causes resistance and not recommended for AFR wires
Old 02-04-2015, 09:10 AM   #125
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
First thing, sorry for reviving such an old thread but this guy's full of info. I've noticed the process has evolved quite a bit from having to cut the ECU wires to plugging a harness. Just wanted to ge the correct and most current info. I have contacted @moto-mike so while wait for that, how's this thing installed. The guage is installed then wideband 02 bolts onto slot 2 replacing oem 02 and using its connector then wiring a power and ground to it? Is this power/ground for the gauge in general or for the 02wideband sensor aside from the guages power and ground? Whats the 02 extension that some are getting from Mike for? Thanks
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-04-2015, 10:57 AM   #126
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You will connect your O2 Wideband in the slot where the secondary O2 is palced from factory.
You will connect your Wideband gauge connection as normal, from the O2 harness into the Wideband gauge inside the car.
Now, you need a Wideband gauge that has a 0-5V output cable (example FAilsafe gauge). You will use the Wideband output 0-5V cable and connect it to Moto Mike's harness, and will plug said harness into the car's stock rear O2 electrical connection.
I wish I had that option available when I did mine, it looks very clean.
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
