Old 12-31-2014, 10:07 PM   #15
JOSEC
Drives: 2014 Subaru BRZ WRB
I'have the same thing. I checked my car for DTC using the ECUTEK software. And I get the same error for the "TCM" check. I'm running Delicious Stage 2 NA and have spoken to Bill about it. He said he's bugging ECUTEK about it.
JOSEC is offline   Reply With Quote
Old 01-01-2015, 12:07 AM   #16
steve99
Drives: FT86
if everything else is ok and its just reading obd codes that is problem then try using a cheap obd scan tool elm327 or similar to read codes.
if scantool works then the software bug is in ecutek software on the laptop if the scantool wont read codes then the bug is in the rom code flashed to your car not responding to obd requests.
alternativly see if your ecutek cable and software will read obd codes from another brz or frs without an ecutek tune flashed or it should probably read obd codes from any vehicle less than 5 years old as they are standard requests.
Old 01-01-2015, 11:11 AM   #17
Shit Luck
Drives: red frs
Originally Posted by HI View Post
I get the same thing. My screen look like that one.
Do you guys have launch control issues? Mine is non existent. Also having idle issues.
What revision number is your tune?
Shit Luck is offline   Reply With Quote
Old 01-01-2015, 12:00 PM   #18
DJCarbine
Thupercharged
DJCarbine's Avatar
I always get the "No response to ODB request" on the AT TCM, I doubt you will get a response from that unless you have an automatic
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 01-01-2015, 12:05 PM   #19
Shit Luck
Drives: red frs
Yeah I screen shot the wrong one... lol
More importantly I am showing not dtc codes but the car doesn't want to idle or warm start.
Old 01-01-2015, 05:16 PM   #20
JOSEC
I still have launch control and my idle is fine. As for revision, I have the most current one. But I'm having the same issue where codes aren't showing using ECUTEK but shows up on a $10 Bluetooth OBD code reader. I've been having code P0507 for while. Bill asked me to check the EVAP lines under the intake manifold. I've clamped all the EVAP lines.
Old 01-07-2015, 01:05 PM   #21
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Yeah the DTC's not showing is odd. I have been speaking to EcuTeK about that to see what might be causing this.
As for the idle being poor, and no launch control, which tune did you flash into the car. Is it one of our Delicious Tuning tunes or another tuners, please email if so. Sorry I have an incredibly hard time linking username to customers so bear with me.
Cheers,
William Knose
Old 01-12-2015, 12:05 PM   #22
Shit Luck
Drives: red frs
Cheers,
William Knose
I did email you about a week or two ago. Its your tune as that's the only tune I have. Its the flash and go tune.
My name is Keith Keller
Old 01-22-2015, 07:39 PM   #23
Shit Luck
Drives: red frs
Still no response to my emails or resolution to my warm start and idle issues....
Parking the car till spring at this point when I can get a real tune...
Possible EcuTek update issue? Dustin Software Tuning 43 05-19-2015 03:32 PM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Ecutek gas gauge issue fixed maj75 Engine, Exhaust, Transmission 1 03-23-2013 11:49 AM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
