#2339 | |
#2340 |
Drives: GT86
That is not an admission, that is just common sense. Just a tune and exhaust won't remove the dip either, with this header and a proper tune you get that in a civilised set-up that sounds better. If you don't like the limitations of a cat you're obviously looking at the wrong product.
#2341 |
Drives: '15 frs Halo. must scrape
I want to use a catted uel but California laws are so hardcore.
Invidia q300-cusco front strut tower with mbc and rear strut tower- buddy club tail lights
#2342 | |
SLO NO MO
As far as I know, this is the only aftermarket header designed and tested to work perfectly fine on a stock car without a tune. |
#2343 | |
Drives: 2015 BRZ Series.Blue
then again the ptuning crap is in a whole other league of prices, lol |
#2344 |
Drives: '13 Ultramarine FR-S M/T
you can get one. i have one in Cali. you just need to swap back to stock for smogg which you wont have to do for another 4 years or so. also if you are half way handy it only takes about 30-45 min to change out the header
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
#2345 | |
Drives: GT86
This is a local guy with similar mods to me. FT86speedfactory catted UEL headers Fiebruz 3" overpipe and resonated front pipe Fiebruz power blocks "IMRE" (Intake manifold spacers) Perrin 2.5" resonated exhaust Supertek pipe & drop-in filter HKS intake duct Ecutek tune (Puma93oct) Graph shows before and after tuning. ![]() As you can see... the stock header actually has a better tq curve past the dip... ![]() Here's my Dynojet run with a tune... Tune only gained 5hp. We did start with the OFT stg 2 UEL for BPB and got 4HP, then we started adjusting it to better suit the catted heated and managed to gain 1 more HP.
#2346 | |
SLO NO MO
#2347 |
Drives: GT86
Your own graphs look quite odd, something is off. Could be the header or the cat, but it could also be the spacers or just the whole combo of mods. Flow systems can behave unsuspected in certain combinations... |
#2348 |
Drives: GT86
#2349 | |
Drives: GT86
But his numbers are far more disappoiting than mine. Where mine did 170 peak HP with 91 octane and stock tune, vs his 93 tuned. Still have yet to remove the header from my car, but I've decided on just gutting the cat and see what happens. The cat might be as restricting or slightly more restricting than the OEM cat, since I lost power in most places compared to the stock header. |
#2350 | |
Drives: Yes
Nope, I don't have a dyno chart to back that statement, but I have a friend with a stock BRZ (axleback only, at the time); we switched cars one night and both immediately noticed the difference. Placebo? Maybe, but unlikely, and I am not one to lie to myself and others to justify money spent on mods. All I know is, I can just give it a bit more throttle in 6th while cruising 70-80mph (~3k RPM) on the freeway and it just pulls with no apparent "torque dip". Still not over how good it sounds either. Perhaps those who are unsatisfied are probably expecting too much from an N/A setup... there's only so much you can do without boosting it.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#2351 | |
Drives: Yes
#2352 | |
Drives: GT86
when I did my dynojet run with tune where I got 186WHP my setup was with the stock catback... basically my car goes from 3" to 2.13" Still have 6WHP over him on a dynojet. My current mods are: K&N Drop in, Fiebruz spacers, FT86SF header, 2.5" OP, 3" Perrin Catted Front pipe, stock CBE. I have less mods, and a less freeflowing exhaust. Another thing, I'm betting that if you put a tune on your friends car, the difference you feel will disappear. Hell... even I felt a huge difference between the stock tune and the tuned setup, of course I never ran a tune with the stock header, so tune vs tune is something I haven't tried yet, but I'm pretty confidence I'll feel the same difference I felt when I tuned this header. |
| Tags |
| catted uel header, ft86speedfactory header, is my order ready yet? |
| Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 10:48 AM |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
| P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 12:50 AM |
| Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 12:01 PM |
| ***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 10:12 PM |
