Old 12-31-2014, 08:31 AM   #2339
s2d4
s2d4's Avatar
Originally Posted by Foobar View Post
That's essentially what the FT86SF Catted UEL Header was designed for - people were asking for a UEL catted header that wouldn't need a tune.
By FT86SF's own admission, as soon as you introduce any other mods to the intake/exhaust, all bets are off and you'll need a tune to avoid issues.
True, people just had different ideas/interpretation that was all.
s2d4 is offline
Old 12-31-2014, 08:35 AM   #2340
Trettiosjuan
Drives: GT86
That is not an admission, that is just common sense. Just a tune and exhaust won't remove the dip either, with this header and a proper tune you get that in a civilised set-up that sounds better. If you don't like the limitations of a cat you're obviously looking at the wrong product.
Trettiosjuan is offline
Old 12-31-2014, 08:37 AM   #2341
Drewfellas
Drives: '15 frs Halo. must scrape
I want to use a catted uel but California laws are so hardcore.
Invidia q300-cusco front strut tower with mbc and rear strut tower- buddy club tail lights
Drewfellas is offline
Old 12-31-2014, 10:00 AM   #2342
Foobar
SLO NO MO
Foobar's Avatar
I'm not referring to performance or torque dip. Jeremy stated in this very thread that the community asked for a catted UEL that worked with a stock car with no tune, and that's what they developed. As soon as you add additional mods, you run into CEL's and codes being thrown. At that point, you'll need to tune specifically for that configuration, and not use a generic stage 2 tune for an uncatted header.
As far as I know, this is the only aftermarket header designed and tested to work perfectly fine on a stock car without a tune.
Foobar is offline
Old 12-31-2014, 10:08 AM   #2343
s30series
Drives: 2015 BRZ Series.Blue
Thats not entirely true....love the guys at speedfactory, but the ptuning headers also work perfectly on stock tune. I put over 1500 miles on mine with no issues what-so-ever before I finally started tuning with ecutek
then again the ptuning crap is in a whole other league of prices, lol
s30series is offline
Old 12-31-2014, 10:10 AM   #2344
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
you can get one. i have one in Cali. you just need to swap back to stock for smogg which you wont have to do for another 4 years or so. also if you are half way handy it only takes about 30-45 min to change out the header
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline
Old 12-31-2014, 11:04 AM   #2345
Cartman
Cartman's Avatar
Drives: GT86
What I keep seeing here is that people like Cartman spend quite some money on several harware mods that each of them by themselves warrant a proper tune (spacers, header, full exhaust) or at least in combination with one of the before (intake). But you run them all together without any(!) tune or without getting a proper one, yet still seem it worthwhile to do several dynos. And then if it doesn't work out as expected you blame the header?
I would at first hand blame the lack of a proper tune, there is NO way a stock tune can accomodate for all those mods AND give more power for each of them. It just doesn't exist. And a stage 2 generic tune isn't suitable either if you did any research and problems are to be expected. This isn't new, it has been stated over and again in this thread.
So, please explain how you can spend thousands on hardware and several dynos, and then not spend a few hundreds on a suitable tune?? It's like buying a sniper rifle and not buying scopes and complaining you keep missing your target...
Sorry if I misunderstood your situation but as of now, I really don't understand what you expected.
I'm just gonna post this.
This is a local guy with similar mods to me.
FT86speedfactory catted UEL headers
Fiebruz 3" overpipe and resonated front pipe
Fiebruz power blocks "IMRE" (Intake manifold spacers)
Perrin 2.5" resonated exhaust
Supertek pipe & drop-in filter
HKS intake duct
Ecutek tune (Puma93oct)
Graph shows before and after tuning.
As you can see... the stock header actually has a better tq curve past the dip...
Here's my Dynojet run with a tune... Tune only gained 5hp. We did start with the OFT stg 2 UEL for BPB and got 4HP, then we started adjusting it to better suit the catted heated and managed to gain 1 more HP.
Cartman is offline
Old 12-31-2014, 12:22 PM   #2346
Foobar
SLO NO MO
Foobar's Avatar
I thought the ptuning headers were non-catted? How can you run that on a stock tune without getting any codes thrown?
Foobar is offline
Old 12-31-2014, 12:30 PM   #2347
Trettiosjuan
Drives: GT86
HKS intake duct
What is what? Solid with the ft86sf catted header, dashed without? If so, seems the header does as advertised. As for the generally seemingly low numbers with all those mods, don't know what is up there.
Your own graphs look quite odd, something is off. Could be the header or the cat, but it could also be the spacers or just the whole combo of mods. Flow systems can behave unsuspected in certain combinations...
Old 12-31-2014, 12:38 PM   #2348
Trettiosjuan
Drives: GT86
From what I saw before launch, the second O2 sensor sits on one of the runners, similar effect as a spacer.
It's a nice header but leaves the dip.
Old 12-31-2014, 01:51 PM   #2349
Cartman
Cartman's Avatar
Drives: GT86
Untuned vs tunned. He never did a before dyno with the stock header, sadly. But the dip is clearly there with this header untunned.
But his numbers are far more disappoiting than mine. Where mine did 170 peak HP with 91 octane and stock tune, vs his 93 tuned.
Still have yet to remove the header from my car, but I've decided on just gutting the cat and see what happens. The cat might be as restricting or slightly more restricting than the OEM cat, since I lost power in most places compared to the stock header.
Cartman is offline
Old 12-31-2014, 06:36 PM   #2350
chas3wba0
chas3wba0's Avatar
Drives: Yes
I have a full 2.5" exhaust after the ft86sf header, stock intake, with OFT Stage 1, and I am 100% certain that performance is improved--even if just slightly--over stock.
Nope, I don't have a dyno chart to back that statement, but I have a friend with a stock BRZ (axleback only, at the time); we switched cars one night and both immediately noticed the difference.
Placebo? Maybe, but unlikely, and I am not one to lie to myself and others to justify money spent on mods. All I know is, I can just give it a bit more throttle in 6th while cruising 70-80mph (~3k RPM) on the freeway and it just pulls with no apparent "torque dip".
Still not over how good it sounds either. Perhaps those who are unsatisfied are probably expecting too much from an N/A setup... there's only so much you can do without boosting it.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
Old 12-31-2014, 06:42 PM   #2351
chas3wba0
chas3wba0's Avatar
Drives: Yes
HKS intake duct
My internet forum degree in automotive tuning tells me that going from 2.5" to 3" and then back to 2.5" is bad for flow, and would explain his less-than-impressive torque numbers... myth or fact?
Old 12-31-2014, 07:05 PM   #2352
Cartman
Cartman's Avatar
Drives: GT86
Myth
when I did my dynojet run with tune where I got 186WHP my setup was with the stock catback... basically my car goes from 3" to 2.13"
Still have 6WHP over him on a dynojet.
My current mods are:
K&N Drop in, Fiebruz spacers, FT86SF header, 2.5" OP, 3" Perrin Catted Front pipe, stock CBE.
I have less mods, and a less freeflowing exhaust.
Another thing, I'm betting that if you put a tune on your friends car, the difference you feel will disappear. Hell... even I felt a huge difference between the stock tune and the tuned setup, of course I never ran a tune with the stock header, so tune vs tune is something I haven't tried yet, but I'm pretty confidence I'll feel the same difference I felt when I tuned this header.
Cartman is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
