Old 12-28-2014, 09:59 PM   #1
Shit Luck
Drives: red frs
ecutek issue. no response from obd?
Here is a screen shot of what I am getting...
also seem to have lost my 2 step. I have reloaded the tune.
Having idle issues and startup issues.
Shit Luck is offline   Reply With Quote
Old 12-28-2014, 11:02 PM   #2
steve99
Drives: FT86
Check the fuse for obd port
Check you obd socket/plug that no pins bent or pushed back into socket in car.
See if another obd device such as scanner will talk to obd port.
I gather the car starts and runs ??
Old 12-28-2014, 11:08 PM   #3
Shit Luck
Drives: red frs
Yeah it did tonight. It was giving me issues at start up the other day.
Almost like an old carbureted car would.
Old 12-28-2014, 11:23 PM   #4
steve99
Drives: FT86
Can you reflash a known working tune ??
If the previous tune was ok then it might be some other hardware issue.
If your boosted a few guys have had cats disintergrate and block exhaust causing weird issues.
Old 12-29-2014, 05:54 PM   #5
Shit Luck
Drives: red frs
I only have one tune...
I am boosted but straight piped.
I am gonna go put a fresh vacuum setup in it again and see if maybe that helps.
Old 12-30-2014, 03:34 PM   #6
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Do you have a good connection at the OBD-II port?
Also what version of windows are you running?
The Following User Says Thank You to DeliciousTuning For This Useful Post:
JOSEC (12-31-2014)
Old 12-30-2014, 04:42 PM   #7
Shit Luck
Drives: red frs
I believe I do.
As for windows I am running on my surface pro. I assume its windows 8
Old 12-30-2014, 05:28 PM   #8
steve99
Drives: FT86
I believe I do.
I wonder if the usb ports on those tablets can supply suffient current and stable voltages to drive the ecutek or any other flashing cable.
even when using a laptop i always have the ac power connected just to be sure when flashing.
Old 12-30-2014, 05:36 PM   #9
Shit Luck
Drives: red frs
No issues that I know of
Old 12-30-2014, 06:10 PM   #10
DeliciousTuning
Good thing to note, but we have a Dell Pro 8 Tablet and it works fine. But we will keep an eye on that, as it is a good point. But I believe the cable is powered by the OBD-II port itself anyways.
Can you connect and reprogram or even do live data connect?
Old 12-30-2014, 06:50 PM   #11
Shit Luck
Drives: red frs
Yeah I have done the reflash and datalogs with it.
Old 12-31-2014, 12:50 PM   #12
DeliciousTuning
Well I am speaking to EcuTeK about the DTC check, as I have had a couple other people have a connection issue with OBD-II DTC's.
You can also use the feature under programming ECU, as we have found this works a little better. Try that and see if that works better.
Cheers,
William Knose
JOSEC (12-31-2014)
Old 12-31-2014, 05:42 PM   #13
diodelphi
diodelphi's Avatar
Drives: 86
Cheers,
William Knose
please tell ecutek after flashing i have some DTC error ?!!!!
diodelphi is offline   Reply With Quote
Old 12-31-2014, 08:03 PM   #14
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
I get the same thing. My screen look like that one.
HI is offline   Reply With Quote
Possible EcuTek update issue? Dustin Software Tuning 43 05-19-2015 03:32 PM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Ecutek gas gauge issue fixed maj75 Engine, Exhaust, Transmission 1 03-23-2013 11:49 AM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
