Old 05-10-2012, 10:37 AM   #15
bneale
bneale's Avatar
Drives: Scion FR-S
I really hate how tirerack only shows you the current model wheel size and up! I'd love to see some 16inch wheels and what they look like on the car. We already know they fit because the GT86 has 16's stock in Japan.
I just hate how tirerack forces you into looking at the current size or higher. Why can't they just show you anything which fits?
To explain what I'm talking about, go look at a 2012 Fiesta SE and compare the results to a 2012 Fiesta SES. Same 4x100 bolt patten on both cars. The only difference is the SES model comes with 16's stock and the SE is 15's.
You can't see the 15's when veiwing the SES model and I hate that. I prefer smaller diameter due to obvious weight reasons.
bneale
bneale is offline   Reply With Quote
Old 05-10-2012, 11:11 AM   #16
OrbitalEllipses
Drives: Attitude
Originally Posted by pithy_logorrhea View Post
Wish there were some 17x9 options.
Ask Scooby_South what he's got, as I recall they are 17*9s popular on the WRX. Rota makes a lot of wheels in that fitment too.
Old 05-10-2012, 11:38 AM   #17
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Originally Posted by FoolCyclist View Post
I have been able to see 17 and 18 wheels and tires for the BRZ for about a week.
I've been checking the front page where wheels are still greyed out. Guess Tirerack's web folks are slacking.
MmmHamSandwich is offline   Reply With Quote
Old 05-10-2012, 02:52 PM   #18
FoolCyclist
Drives: SWP BRZ Limited, MT
I went through and put in 2013 BRZ and it shows wheels, tires, brakes, suspension items open. Only thing that isn't working is to see the wheels on your car.
FoolCyclist is offline   Reply With Quote
Old 05-10-2012, 03:11 PM   #19
pithy_logorrhea
Drives: 2007 STi
I wish they had those TR motorsport wheels that the miata has for STR class. $600 17x9 wheels? I'm there!
pithy_logorrhea is offline   Reply With Quote
Old 05-10-2012, 04:28 PM   #20
AX_FRS
Drives: 05 Ford Focus ZX4
Anybody click on the TPMS info? It says it will be about $400 just to add the TPMS sensor to 4 wheels! Ouch!
AX_FRS is offline   Reply With Quote
Old 05-10-2012, 05:01 PM   #21
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
I noticed they didn't have the WedsSport tc105n on the list.
18 x 8, 42 offset, 16.1 lbs
17 x 8, 42 offset, 14.9 lbs
Is there a problem with this offset?
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
Old 05-10-2012, 06:07 PM   #22
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Tire Rack won't list rims/offsets that are too far from the stock dimensions, even if you could probably get them to fit. If you're sure you want them, just call and order over the phone. They're just trying to keep returns to a minimum.
When I ordered a set of rims and tires for my spec.B I chose a combo that was right on the outside of what would fit. I actually got a call from someone at Tire Rack to verify my order and make sure I knew it wasn't a known combo that would fit. But I told them I was aware and they sold me what I wanted.
Old 05-10-2012, 07:59 PM   #23
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
bneale
This... where the 16" wheels Tire Rack?!?!!
Vracer111 is offline   Reply With Quote
Old 05-10-2012, 08:11 PM   #24
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Sounds perfect to me... Just have to call them.
uspspro is offline   Reply With Quote
Old 05-10-2012, 08:18 PM   #25
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
There was a vendor posting on here with self-programmable sensors. About the same price, but you can clone your factory id codes (this means you don't need the dealer to switch wheels!).
Khyron686 is offline   Reply With Quote
Old 05-12-2012, 01:55 PM   #26
Brian S
Drives: Hinda Civic
Anybody know a good place that sells those advan rg-d in a 5x100 pcd and are aware of the cost, weight and general specs.? Really sharp wheels and hoping they are flow cast fore weight reduction, but its hard to find good info on them.
Brian S is offline   Reply With Quote
Old 05-12-2012, 08:59 PM   #27
Slartibartfast
Klaatu barada nikto
[quote=LSxJunkie;209251]That's 3mm lower than this car (18x8 +45, 225). I think you should be fine, so long as you know where your towel is.
You must be a hoppy frood. Always have to know where your towel is.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
TireRack has big brake kits for FR-S. Cheddar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 04-17-2012 02:42 PM
has anyone else seen this wheels supramaster12 Scion FR-S / Toyota 86 GT86 General Forum 11 02-09-2012 08:40 PM
OEM wheels I haven't seen elsewhere bambbrose Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-14-2011 06:08 PM
BRZ added to tirerack for tire selection... mines13 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 12-05-2011 10:19 PM
