Old 12-24-2014, 08:24 PM   #141
10Stars
Drives: 14 Subaru BRZ Limited WRB
Question
Originally Posted by 10Stars View Post
Well I finally got my Tein Street Flex coilovers
@CSG David I really wanted to buy from you guys but I got a deal so good from @Gruppe-s that I just couldn't pass up. I will try to return the favor in the future.
One question though guys I just unboxed them yesterday and one of the rear coilovers has a small paint chip on the top hat . Should I be concerned? Will it rust? I know these type of things happen during shipping and I would prefer not to ship it back since I feel that I'm being a bit too paranoid. I already pm'd @Gruppe-s just to get their opinion on it but what do you guys think? Will I be ok? Thanks everyone.
Originally Posted by CSG David View Post
Start with stock sway bars first and go from there. I suggest you don't swap too many parts at the same time.
Hey David just wondering if I could get your opinion/suggestion from a respected/knowledgeable member.
A couple people said I should be fine but I just want to be sure since you have had experience with Tein in the past.
10Stars is offline   Reply With Quote
Old 12-24-2014, 08:37 PM   #142
CSG David
CSG David's Avatar
If you are concerned, just use touch-up paint. Otherwise it is fine.
Old 12-24-2014, 08:50 PM   #143
10Stars
Thumbs up
Cool thanks man! I figured it was just me being a bit too paranoid about it. I think I will save myself the hassle from finding something that will match the paint color since I might end up making it look worse lol.
I will post up my impressions later when it is eventually installed.
EDIT!!!
Forgot to ask will the rear suspension stick up through the rear carpeting? I heard about that somewhere with the Tein Mono Sport I think, something about it allowing easier on the fly damper adjustment.
Last edited by 10Stars; 12-25-2014 at 03:47 AM. Reason: Forgot to ask another question
Old 12-26-2014, 02:57 AM   #144
CSG David
CSG David's Avatar
EDIT!!!
Yes. Just fold the carpet back.
Old 12-26-2014, 04:09 AM   #145
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I thought I would have a play around with my dampers today. Much to my dismay I found that one of the rear adjusters had been bent off axis. No doubt it was the trolley jack on my way to the local track. Luckily for me the adjuster is still working. I purchased some 32mm diameter 1.6mm thick aluminium tubing to make a bit of protection. It is 40mm high. The tubing sits in there quite nicely.
These are not Tein Mono Sport but you get the idea.
Old 12-26-2014, 05:55 PM   #146
CSG David
CSG David's Avatar
This is not an issue for TEIN suspension.
Old 12-29-2014, 07:19 PM   #147
Gruppe-s
Drives: Time-attack Scion Race car
Sorry for the late response, I finally got an answer from Tein. Sorry that the item was damaged during shipping. The plate is zinc coated under the powdercoat so it shouldn't rust regardless. Thanks for your patience.
Gruppe-s is offline   Reply With Quote
Old 12-29-2014, 07:46 PM   #148
OkieSnuffBox
Drives: '23 BRZ Limited
Thoughts on the FT86SpeedFactory Spec RS*Rs?
Old 12-29-2014, 10:28 PM   #149
10Stars
MUCH APPRECIATED! That pretty much puts my worries to rest
Old 12-30-2014, 12:00 AM   #150
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Originally Posted by xero404 View Post
On the softest settings very similar to stock, i ride them with the rear a little stiffer but with spring rates 7/7 and the valving is very smooth i'm pretty happy with the comfort and performance they provide (TEIN has probably been making twin tube designs before i was born). Your welcome to drive the car the next Dublin meet, I think im the only one running teins and rocking a tein sticker there lol.
Hope to see you at the next meet. I am thinking of getting this setup and would like to check them out.
Sugi is offline   Reply With Quote
Old 12-30-2014, 02:31 AM   #151
Racecomp Engineering
I'd love to see a shock dyno plot of them, or any of the other RSR coilovers.
- Andy
Old 12-30-2014, 08:33 AM   #152
OkieSnuffBox
- Andy
Same here.
I'm stuck between those, the RCE Tarmac Zero + RCE Plates, or the complete Ground Control setup (had very good luck with them on past BMWs I've owned).
Basically I'm trying to stay around $2k-ish with camber plates and linear springs. If I had $3k it would Tarmac IIs + RCE camber plates.
Daily coilover reviews compilation thread. cdrazic93 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-09-2014 01:24 PM
Coilover Suspension Kits! TEIN | Tanabe | Cusco | KW & More! Lowest Prices + FREE S&H AJ@ECSMotorsports Brakes, Suspension, Chassis 23 03-09-2014 11:20 AM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
