Old 12-27-2014, 08:58 PM   #5811
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by Fizz View Post
LoL I'm glad I asked....all the while I thought it was the factory idler pulleys that were failing
I actually did have a noise coming from the factory idle pullies - I ended up replacing both with pulleys from Raceseng - I still have the additional pulley that came from the kit and it's not making noise for me (yet...)
mikalem is offline   Reply With Quote
Old 12-27-2014, 09:08 PM   #5812
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by xxscaxx View Post
the rear O2 only monitors the cat...you wouldn't need to adjust the tune but he would have to turn off the code that would be associated with unplugging the rear o2 sensor.
So yes you can just install it and run it, but you will have a CEL.
regarding the pulleys, honestly I have a squeak and I have replaced that idler pulley. I'm fairly certain its coming from the alternator but it comes and goes so I haven't bothered really examining it lol
Thanks. But curious...if we connect the sensor analog output wire to the blue wire that runs to the ECU, would it still throw a CEL code? I'd like to be able to datalog my AFR via ecutek.
Do you know what's the size/spec for the alternator pulley?
Fizz is offline   Reply With Quote
Old 12-27-2014, 09:11 PM   #5813
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Looks like raceseng no longer sells just the idler pulleys on its own. It only comes with the full pulley kit.
Could you also do me a favour and take measurements (ID, OD, Width) of the factory idler pulleys that you removed? I'll try and find a replacement part from Nuline as well.
Old 12-27-2014, 09:15 PM   #5814
mikalem
mikalem's Avatar
That sucks - I got the set from FT86SpeedFactory in October but I know they waited a little while for them straight from raceseng - if they aren't selling them anymore by themselves that sucks because they are really well made pieces.
Old 12-28-2014, 04:31 PM   #5815
Kodename47
Kodename47's Avatar
Drives: UK GT86
You need to disable the rear O2 sensor CEL codes, remove the rear O2 sensor adjustment range and then configure a custom map to give you an AFR from the WBO2 voltage. Essentially it'll need a remap.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-29-2014, 11:57 AM   #5816
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
So I just replaced the idler pulley with Nuline EP075, but still getting the squeaking noises.
Also removed one of the two factory metal idler pulleys (the top one directly under charger pulley) to inspect but as far as I could tell it seemed fine and spun smoothly. No play on the bearings too. I'd assume the lower idler pulley would be fine as well.
Don't really know what else to check. Anyways the noise disappears entirely after about 10mins driving once the engine is fully warmed up.
Old 12-29-2014, 12:12 PM   #5817
TemeCal
Drives: 86
Replacing that pulley did absolutely nothing for my squeaking. Mine used to squeak for 30secs, then it'd go away. Now, it's a few mins...then the squeaking is gone. Someone else in this thread, said it was the alternator pulley that appears to be the culprit.
TemeCal is offline   Reply With Quote
Old 12-29-2014, 08:23 PM   #5818
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
But I don't see how the alternator pulley could be the culprit....it doesn't have any bearings (that could fail) it's simply bolted to the alternator shaft and spins with the shaft.
Old 12-29-2014, 08:58 PM   #5819
The more current the alternator pushes, the greater the load on it.
The more the battery has been discharged, the more the alternator resists spinning.
Old 12-29-2014, 09:20 PM   #5820
whataboutbob
AutoX-10/10ths every run
If you want to monitor your AFRs using a wideband, you could also just weld in another sensor bung and mount the wideband in it.That's what I've done.
Build thread:Here
Old 12-29-2014, 09:53 PM   #5821
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Sorry but I still don't understand how the alternator pulley itself could be causing the squeaks....that's what I was trying to say.
Old 12-29-2014, 10:12 PM   #5822
If truly the alternator, it drags and the belt squeaks over it until the battery charges up enough.
Old 12-29-2014, 10:13 PM   #5823
TemeCal
Drives: 86
I don't quite understand how it could be the culprit either. However, some have claimed that they have removed the belt and spun the alternator pulley and it was squeaking for them.
I'm a bit frustrated with the squeak (just really annoyed by it). I'd LOVE to get to the bottom of it and fix it once and for all. It's obviously a very common issue, as many of us with the Innovate kit seem to have it.
Old 12-29-2014, 10:15 PM   #5824
TemeCal
Drives: 86
Any idea why it would only happen the first minute, then go away?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
