#15 | |
Drives: 2015 Series.Blue
I honestly don't know if it can be done through ECUtek to be honest. |
#16 |
StreetKart
Drives: 2014 Scion FR-S Monogram
soooo... what you're saying is you DONT know of a cheaper alternative... everything else said is not relevant.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#17 | |
Drives: Firestorm 2013 FR-S
The thermostat just controls the MINIMUM temperature at which the engine operates and has no effect on a fully warmed engine under load. If the engine is constantly running too hot changing the thermostat will have no effect. It will give a greater "cushion" if the cooling system is stressed for a short period of time then unstressed, such as a car that is temporarily stuck in traffic then goes again. |
#18 |
Drives: Passat
Smokey Yunick is turning over in his grave at the ignorance displayed herein.
#19 | |
Drives: waiting on a 2021...
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#20 |
Drives: 2013 Scion FR-S Raven
Installed the Mishimoto thermostat from FT86speedfactory today. It runs a little cooler, tip in knock from multiple data logging did not occur as it typically does on the third pull. First time for everything. It's hot out tonight
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#21 |
Professional Smartass
Drives: White Out FRS
Got an update for the thermostat? Still working fine?
#22 |
Performance is Nominal
| FT-86 low temp THERMOSTAT | ft86-UAE | Engine, Exhaust, Transmission | 52 | 08-30-2016 03:46 PM |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| MD: Mishimoto Oil Cooler / Earls Oil Thermostat - NEW | BoostinIX | Engine, Exhaust, Bolt-Ons | 11 | 07-09-2014 08:59 PM |
| Mishimoto Releases In-Line Oil Thermostat! | Mishimoto | Engine, Exhaust, Bolt-Ons | 0 | 05-07-2014 01:21 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
