Old 12-26-2014, 12:33 PM   #169
Shit Luck
Drives: red frs
Originally Posted by DeliciousTuning View Post
Not usually the one we recommend, just because we have seen them fail 10% of the time. Not good quality in our eyes. But they do work when they work and when they fail it is usually pretty obvious, basically the car will not run at all.
Cheers,
William Knose
Any idea what codes it throws... I am showing a massive vac leak I can not find. The car doesn't want to idle.
Shit Luck is offline   Reply With Quote
Old 12-26-2014, 12:49 PM   #170
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
It wouldn't be the purge control solenoid under the manifold?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 12-26-2014, 02:48 PM   #171
Shit Luck
Drives: red frs
I don't have one anymore
Old 12-26-2014, 02:49 PM   #172
yomny
yomny's Avatar
Just wondering, as im getting ready to install a kit and this is one of the to do's.
Old 12-26-2014, 03:40 PM   #173
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
And definitely get the e85 tune!
texasbound972 is offline   Reply With Quote
Old 12-26-2014, 03:52 PM   #174
Shit Luck
Drives: red frs
My bov is hanging open at idle and doesn't seem to close when I apply throttle.
Old 12-26-2014, 05:19 PM   #175
yomny
yomny's Avatar
BOV spring too weak?
Old 12-27-2014, 05:49 PM   #176
Shit Luck
Drives: red frs
I am having a ton of issues at start up. It won't start without me holding the throttle. It dies at lights too.
Runs great when running but man is idle sketchy at best.
Old 12-27-2014, 06:10 PM   #177
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
@DeliciousTuning What psi would you say is needed to achieve ~300whp in stock fuel system using JDL's base kit with the precision 4854 turbo. This is with 93oct. Would this be achievable with your F'n'G tunes? Not necessarily the whp goal as I know that's not entirely up to the tune.
Usually about 7-10 PSI is all that is needed to reach 300+whp if you run E85. This is also the limit of the stock fuel system wtih E85 / FlexFuel.
On 93 octane you would get to about 10 PSI is about as high as you can go before becomes the point of diminishing returns. This would be very close to 300whp.
Old 12-27-2014, 06:12 PM   #178
DeliciousTuning
Disconnect the vacuum line to the BOV. I bet the spring is too weak and we have seen if these are too weak, play havoc on the idle.
If your spring pressure is 11 PSI or less it will open at idle. Usually we recommend a minimum of 13 PSI to make sure your have s steady idle.
Cheers,
William Knose
Old 12-27-2014, 06:17 PM   #179
yomny
yomny's Avatar
What wastegate spring do you recommend I use given 10psi or lower? Thanks.
Old 12-27-2014, 06:35 PM   #180
DeliciousTuning
I would suggest a 7 PSI springs, as it works well on all fuels from 91-94 octane and we can always up the boost with a boost controller.
Cheers,
William Knose
Old 12-27-2014, 06:54 PM   #181
yomny
yomny's Avatar
Cheers,
William Knose
Another question I had posted above referring to the comment you made about the map sensors. Which do you recommend using since you mentioned the omni power failing? I've looked around but can't really find any other company that makes a plug and play one for us. Thanks.
Old 12-27-2014, 08:29 PM   #182
texasbound972
USMC
I don't know what website to buy it off of either. Thought I ordered the hondata but it ended up being an omni.
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
