Drives: 2013 FRS / 2013 427 Vert
Hoosier R7 ?????
Time to retire the 710's (past time actually which contributed to a minor incident T10 at Sebring)
I've never owned any Hoosiers but I'm considering R7's Thoughts regarding this choice as well as size selection for my 17x9 wheels?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#2 |
C-Street AutoX
They'll be a fuckton faster than V710's, but wear out quicker. Probably use less tire pressure too.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
#3 |
Drives: Nevermorange FRS
They're designed for competition of course and they will probably have the typical Hoosier life span: Good for 3-12 sessions (depending on car) and then 1-2 seconds slower after that.
Unless you're competing in a class where that's the 'tire to have', I would say that it is not the tire to have. If you're just lapping, your money will go further with something else.
PRO86 | WTCC | STL
#4 |
AutoX-10/10ths every run
I've been using the A7 for half a season in autocross. I had a set of BFG R1-S tires before them. The A7s are noticeably gripper than the R1-S. I've got about 50+ runs on the A7s and they are just now starting to fall off.
#5 |
The R7 is meant to last longer than the A7 but not that much longer. Like rice said, I would only use R7s if you are actually competing or if you are getting take-offs from teams for dirt cheap.
| The Following User Says Thank You to xwd For This Useful Post: | wparsons (12-28-2014) |
#6 |
Drives: '23 BRZ Limited
What these guys said.
If you're just doing HPDE, I'd go with NT-01 and call it good. |
#7 |
Drives: 2013 FR-S Series 10 and 2010 Camry
I'm considering the same tire for possibly next year. Based on tire rack a 225/45-17 is 9" wide. I'm thinking of using this on a 17x9 rpf1. After I use the 245/40-17 A048's I just ordered for autox. I have a co-driver so I'm sure they'll go quick, but having a co-driver will also help keep heat in the tires
The reason I'm looking at a 225 is that it'll keep me in the NXD class for NASA. No SCCA events here in Sioux Falls. Too many Miatas lol
| Hoosier R-6s | Lunatic | Wheels and Tires | 2 | 11-02-2014 01:28 AM |
| FS: Hoosier A6 245/40/17 tire | edj | Wheels and Tires | 0 | 04-17-2014 03:44 PM |
| Hoosier Street Tire! - Finally! | modernbeat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 04-01-2014 04:26 PM |
| FS/FT: Bronze RPF1's 17x8 +45 w/ Hoosier R6, South FL | bAS1c | Wheels and Tires | 11 | 07-12-2013 08:22 AM |
