Old 12-20-2014, 06:34 PM   #85
Originally Posted by Calum View Post
Hey guys, I saw someone reference this thread the other day and came looking. I think I've read everything but I've got a couple questions.
First though, anyone looking for the part might want to check rockauto.com. The prices discussed here seem amazing, but they would be basically impossible where I'm at. So rockauto.com is for those in area like me, not you guys in the US.
My question is why not remove the bolts before you remove the line? Of course you'll have to loosen the bango bolt slightly before you remove the bolts, but you might save some mess and some fluid this way.
Agree but it's all part of trying to KISS for the noobs. I thought about it but wanted to use the least number of words and steps possible. Def. kept it in mind as plan-B until I saw how little it already leaks. Really, next to nothing.
I also figured there is less chance of spillage if the main port is plugged before moving it.
My other question was, has anyone tried bleeding the system by manually manipulating the piston on the slave... Yes I know how that sounds... But that's how I've bleed other clutch systems in the past, just hold it lower than the master and stroke it until you get all the air out.
I've done the same but don't recommend it for a first-timer. It's possible to give the master cylinder an air embolism with one quick dumbshit move. I think this would be just like running it dry.
Calum (12-20-2014), JB86'd (12-21-2014), jcw99 (12-23-2014)
Old 12-24-2014, 01:52 PM   #86
JB86'd
JB86'd's Avatar
Drives: JAWS
So a thought I had while performing this mod, was concerning the bolt that connects the banjo fitting to the cylinder. It has a hole running through the threads which presumably needs to line up perfectly once tightened down. Do the threads on the bolt itself ensure this? What if you were to over-torque the bolt? Or am I wrong in assuming it needs to line up perfectly?
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Ultramaroon (12-24-2014)
Old 12-24-2014, 01:56 PM   #87
Ozzman
Drives: old
No they don't need to line up perfectly, the banjo fitting has channels cut inside to make sure it doesn't matter.
Ozzman is offline   Reply With Quote
The Following 2 Users Say Thank You to Ozzman For This Useful Post:
JB86'd (12-24-2014), Ultramaroon (12-24-2014)
Old 12-24-2014, 03:51 PM   #88
That was a good question so I dug up an example. Sometimes the groove is cut into the bolt. I haven't seen much of that. Most fittings are like this, where there's a cavity cut inside the fitting.
JB86'd (12-24-2014)
Old 12-24-2014, 09:57 PM   #89
I want to do this mod but my car is an auto. Do I need any special parts?
Old 12-24-2014, 10:17 PM   #90
That depends. You should be ok if your car is at the stock ride height. If you're lowered and you drive on bad roads you will need special parts.
acetothermus (04-30-2015)
Old 01-12-2015, 11:41 AM   #91
Marx
Marx's Avatar
Drives: '13 Lava FR-S 6MT
Thanks for the guide, this was super easy to follow - I think the trip to Autozone to pick up the part took longer than the actual swap did. I took out the clutch return spring a little while ago but I got used to the additional stiffness from that within a day. I'm super pleased with how the pedal feels with both mods done.
Marx is offline   Reply With Quote
The Following 3 Users Say Thank You to Marx For This Useful Post:
Koa (01-22-2015), Tenament05 (01-12-2015), Ultramaroon (01-12-2015)
Old 01-22-2015, 12:13 AM   #92
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
All the Thanks goes to @Ultramaroon, for helping me do this to my car! The clutch is much more to my liking!
Jonesy86 is offline   Reply With Quote
The Following User Says Thank You to Jonesy86 For This Useful Post:
Koa (01-22-2015)
Old 01-27-2015, 01:08 AM   #93
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
what, no short guy tips? pft. some DIY thread. mods lets get this shut down, bein all tall-people biased n crap.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
Koa (01-27-2015), Ultramaroon (01-27-2015)
Old 01-27-2015, 03:17 AM   #94
JB86'd
JB86'd's Avatar
Drives: JAWS
I was thinking today, and when bleeding the clutch, the first couple releases clearly spit out some air that I could hear and see. After that, the next few releases were smooth and just solid fluid coming out. Does that mean there is no air left in the system, or is it possible for there to be air further down the line? Clutch operation feels fine but just want to be sure I bled it all the way.
Old 01-27-2015, 10:02 AM   #95
Koa
If it's solid fluid coming out, and the reservoir is between the low and full line, then the clutch is bled
The Following 2 Users Say Thank You to Koa For This Useful Post:
JB86'd (01-27-2015), Ultramaroon (01-27-2015)
Old 01-27-2015, 02:06 PM   #96
+1^ although it doesn't hurt to keep going as long as you watch the fluid level in the reservoir.
When we did @Jonesy86's last Tuesday I was amazed at how long it took to work out all the air. Definitely more than a few cycles but his clutch fluid looked contaminated. There may have been something else going on with his. I'll be checking it again this weekend.
Koa (01-27-2015)
Old 01-27-2015, 03:59 PM   #97
Oops, my bad. For the short folks
http://www.target.com/p/fantasy-fiel...prodSlot=_1_24
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Andrew025 (01-27-2015), cdrazic93 (01-27-2015), Koa (01-28-2015), Marx (01-28-2015)
Old 01-27-2015, 09:33 PM   #98
JB86'd
JB86'd's Avatar
Drives: JAWS
@Ultramaroon @Koa I wasn't sure so I actually bled it on two seperate days and the fluid was solid the second time around, probly did 6 cycles the first day then 4 more to be sure a few days later. Thanks for the reassurance!
The Following 2 Users Say Thank You to JB86'd For This Useful Post:
Koa (01-28-2015), Ultramaroon (01-27-2015)
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
