Old 12-24-2014, 12:07 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Compressing coilover struts by hand - any danger in "bottoming out"?
Hi all,
I was testing coils (off of the car) today for how it responds to changes in damping adjustments by compressing the struts by hand with the springs off.
It occurred to me that the front struts (since no bump stop) have quite a bit of travel - is there any danger in compressing them by hand to essentially "bottom out"? Wanted to know as with springs in at full compression, I don't think the piston can retract as far as you can push it in by hand.
Weird question, I know.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 12-24-2014, 01:51 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No, unless your hands have the strength of the Hulk.
-alex
1Cor10:23 (12-24-2014)
Old 12-24-2014, 02:05 PM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
The last few sets of shocks I bought came with the shafts fully compressed and strapped down.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Old 12-24-2014, 02:40 PM   #4
1Cor10:23
1Cor10:23's Avatar
Both fronts and rears?
Old 12-24-2014, 03:15 PM   #5
murdoc
murdoc's Avatar
Yes. These were OEM style shocks from koni and tokico.
Don't slam them with a hammer or anything, but the way I've always tested low pressure shocks to see if they were good when they didnt have springs on them was to compress them and see if they extend themselves again smoothly.
Old 12-24-2014, 03:34 PM   #6
1Cor10:23
1Cor10:23's Avatar
@murdoc cool, thanks for sharing your experience just curious if it's the same with coilovers since it seems the potential travel length on my front strut (ohlins) far exceeds that of the rear (which has a bump stop)
Old 12-24-2014, 04:19 PM   #7
murdoc
murdoc's Avatar
That's a good question.
Manufacturers are usually pretty good about letting you know not to break things, e.g. every coil-over or shock I've bought has told me not to spin the shaft with an impact wrench, but none have said not to over-compress the shock.
I'm sure that without a severe impact force you won't damage it.
Old 12-24-2014, 04:25 PM   #8
mav1178
mav1178's Avatar
Don't flip out over this... the fronts are inverted struts so there won't be a traditional bumpstop.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
1Cor10:23 (12-24-2014), Racecomp Engineering (12-24-2014)
Old 12-24-2014, 04:31 PM   #9
1Cor10:23
1Cor10:23's Avatar
@murdoc I was actually a bit surprised at how light the reading material was with my Ohlins, probably what you get when they were originally written in a different language. Ironic though, that all the best brands (KW, Tein, Ohlins, etc.) are all foreign and suffer from the same issue.
The other problem that led me to compress my shocks by hand in the first place was the lack of explanation that the Ohlins technically only have 20 usable clicks of adjustment but the adjuster can actually keep on clicking WAY beyond the 20. I wasn't exactly counting and went from end-to-end. Afterward, freaked out a bit that it should only go 20 (instructions have a recommended for road use of ~10-20 clicks soft but no mention of limit) so I tried compressing by hand while varying the adjustments just to check that everything was still okay - hence this thread topic - after compressing front struts for what seemed to be way more travel than rear (due to bump stops) and "bottoming" them out when on a soft setting.
@mav1178 Thanks for the supportive words - I'm pretty OCD about this stuff...really should've done some more reading before fidgeting with everything, particularly the adjuster and going full soft. Would suck if broke it before even installing haha
Old 12-24-2014, 10:04 PM   #10
CSG Mike
CSG Mike's Avatar
Hi all,
Thanks!
By hand? No, but don't put too much force on it at the ends. It's a hard impact (such as hitting a large bump at speed, or a pothole) that will damage the dampers.
Old 12-24-2014, 11:32 PM   #11
1Cor10:23
1Cor10:23's Avatar
@CSG Mike thanks Mike - what do you mean by "at the ends"?
What's the hand signal for "You have your own lane idiot!"? Vracer111 Off-Topic Lounge [WARNING: NO POLITICS] 22 04-01-2014 03:54 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
