Old 12-23-2014, 08:15 PM   #1
cslntuee
Drives: Subaru BRZ Limited
BBK fitment question
HI,
I plan to upgrade to 18” wheel in the near future.
I do not have budget now, but I also plan to upgrade the BBK when I have budget.
What’s the suggestion (or minimum requirement) for the width of the ET value for 18” wheel in order to fit BBK without using spacer? (I have STI pink spring, so it is around 15 mm drop)
I know that might also need to consider the shape of the wheel, but I just want to have a roughly idea to select my wheel now.
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 12-23-2014, 08:38 PM   #2
CSG Mike
CSG Mike's Avatar
It's wheel specific... there's no (common) generic measurement, unfortunately.
Old 12-23-2014, 09:00 PM   #3
mike the snake
My Enkei Raijins are 18x9.5 with -45 offset and with very wide 265 Michelin Pilot Super Sports (which run a bit wider than other brand tires I'm told) I have a perfect flush fit in the rear with no issues.
The 18x8.5 fronts with the same offset (-45) and 245 MPSS tires could use a 5 or 10mm spacer to be perfectly flush.
Others have run the 9.5's same offset in front, but you need coilovers to clear the springs and perches on the inside.
As already stated, it varies wheel to wheel, but these numbers can give you ballpark as to what you can stuff into the fenderwells.
Old 12-23-2014, 09:47 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Caliper clearance is entirely dictated by (in order of decreasing importance) 1) spoke design, 2) offset, and 3) wheel width.
An example:
http://www.workwheelsusa.com/media/w...IZING_1214.pdf
Another illustration would be this cross-section picture of the Volk Racing ZE40:
-alex
Old 12-24-2014, 07:46 PM   #5
cslntuee
Any idea for SSR GTV03 18'' wheel?
http://www.ssr-wheels.com/wheels/gtv03.asp
Thanks.
Old 12-24-2014, 08:18 PM   #6
mav1178
mav1178's Avatar
@cslntuee only way to know is to provide the template to SSR and see if they can measure for you.
http://www.apracing.com/Drawings/P16.315.pdf
-alex
cslntuee (12-25-2014)
Fitment question rj101592 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-22-2014 10:13 PM
fitment question aaguilar3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-07-2014 08:27 PM
fitment question x2board Electronics | Audio | NAV | Infotainment 2 01-26-2014 07:54 PM
fitment question DanoFA20 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-16-2013 01:25 PM
Fitment question for XXR 527 ooharloo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-04-2012 09:35 PM
