#2283 | |
Drives: WRB JR BRZED
#2284 | |
Drives: 2013 Black FR-S
I had the same click for about 1 yr and then it finally turned into a CLUNK CLUNK CLUNK when accelerating in 1st gear from a stop. Driver's side bearing was demolished. DriveShaftShop axles installed and no more noises.
#2285 |
#2286 |
in orbe terrum non visi
Drives: violent
I come from the 2 wheel world and stuff myself into corners pretty hard dragging the rear wheel by being hard on the clutch coming in. Now I know this is NOT a car technique but with a 6 puck clutch and how light this car is I did it today not even thinking about it. With heavy front weight transfer on the brakes I can trail brake/drag the rear with good control over the rpms and grip with the clutch. Now there is no way the clutch would take the heat doing this corner after corner but has anyone experienced done this on purpose in the 4 wheel world? I was surprised it worked.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#2287 |
Drives: violent
Damn that sounds stupid now that I read it. I really just need more low speed compression dampening in the front.
#2288 |
Drives:
I come from the two wheel world too and it doesn't sound that dumb. But then again, I drive an auto FRS now, so stupid is as stupid does.
![]() Sent from Tapatalk
"Fuck, you've gone completely sideways, man."
~Raoul Duke Gas is pretty cheap considering you're buying liquid explosive dinosaurs. ![]() |
| The Following User Says Thank You to Campo For This Useful Post: | Reaper (12-23-2014) |
#2289 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Campo (12-23-2014) |
#2290 | |
Drives: '23 BRZ Limited
I tracked on 2 wheels a long time ago as well. I'm guessing you had a newer bike with a slipper clutch? |
#2291 | |
Drives: violent
After showing my friend in the rain he showed me my technique seems to be popular in the RWD rally world. @CSG Mike I like the term "trail clutch"
| The Following User Says Thank You to Reaper For This Useful Post: | OkieSnuffBox (12-23-2014) |
#2292 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Reaper (12-23-2014) |
#2293 | |
Yeah I had an '04 R6 many years ago, and it didn't have a slipper clutch. When I went to the track I was just trying to have fun, so I'd just let the rear get loose under braking and go with it. I suspect it's why I picked up driving on 4 wheels rather quickly. |
#2294 |
Drives: violent
My clutch/rear brake has long been my traction control. Valentino rossi used to STAND on his rear brake while wide open throttle exiting corners and then slowly let up on the brake to modulate wheelspin.
| The Following User Says Thank You to Reaper For This Useful Post: | solidONE (12-30-2014) |
#2295 | |
Oh wow, I never knew that about his style. I just always used my right hand, brake, turn-in, maintenance throttle to right before apex and roll back in the throttle as you're standing the bike up. I was much more comfortable sliding the bike around on the throttle than using the brakes. |
#2296 |
Drives: 2013 white FRS
This thread is awesome (although admittedly I'm only about halfway reading through). Thanks Mike and everyone else for sharing your time and knowledge! Couple questions:
You mentioned tracking without a tune being damaging to the car. Is this something I should be concerned about? I bought my car in may 2013. Started tracking this summer and I go about once per month. Also, after my last track day, I noticed the cap of my brake fluid reservoir had a bunch of green gunk on it. I'm assuming that the fluid has absorbed some water and it's time for a flush. I'm using torque rt700 and it has been through about 7 months of daily driving and 5 track days. Is that about what to expect for longevity? Lastly, here's a video from buttonwillow earlier this month. If you guys have a few min, any constructive criticism would be appreciated! I feel I could definitely improve on my braking and corner entry speed. [ame="https://www.youtube.com/watch?v=w1Kx3KKBCFw"]FRS Buttonwillow Dec 2014 open track - YouTube[/ame] |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
