go_a_way1
Old 12-11-2014, 11:03 PM   #2283
enivid
enivid's Avatar
Drives: WRB JR BRZED
They'll start to click on load changes before they go completely. You'll know they're starting to fail if you look for the right signs.
The OSG is different, but I wouldn't necessarily class it better or worse. A properly set up differential will do exactly what you want, regardless of brand. The OSG, I believe is more forgiving to less optimal setups, but we prefer to get the best setup we can, not just "good enough". We're still testing one on our car.
Yeah on the rear drivers side, I hear a click every time I let off the gas.
enivid is offline   Reply With Quote
Old 12-11-2014, 11:40 PM   #2284
sw20kosh
Drives: 2013 Black FR-S
Yep your axles are going.
I had the same click for about 1 yr and then it finally turned into a CLUNK CLUNK CLUNK when accelerating in 1st gear from a stop. Driver's side bearing was demolished. DriveShaftShop axles installed and no more noises.
Old 12-12-2014, 04:39 AM   #2285
CSG Mike
CSG Mike's Avatar
You'll need to change it eventually...
Old 12-22-2014, 02:57 PM   #2286
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I come from the 2 wheel world and stuff myself into corners pretty hard dragging the rear wheel by being hard on the clutch coming in. Now I know this is NOT a car technique but with a 6 puck clutch and how light this car is I did it today not even thinking about it. With heavy front weight transfer on the brakes I can trail brake/drag the rear with good control over the rpms and grip with the clutch. Now there is no way the clutch would take the heat doing this corner after corner but has anyone experienced done this on purpose in the 4 wheel world? I was surprised it worked.
Old 12-22-2014, 03:00 PM   #2287
Reaper
Reaper's Avatar
Drives: violent
Damn that sounds stupid now that I read it. I really just need more low speed compression dampening in the front.
Old 12-23-2014, 01:26 AM   #2288
Campo
Campo's Avatar
Drives:
I come from the two wheel world too and it doesn't sound that dumb. But then again, I drive an auto FRS now, so stupid is as stupid does.
Sent from Tapatalk
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
The Following User Says Thank You to Campo For This Useful Post:
Reaper (12-23-2014)
Old 12-23-2014, 02:41 AM   #2289
CSG Mike
CSG Mike's Avatar
Clutch kick? Trail clutch? Totally legit.
Campo (12-23-2014)
Old 12-23-2014, 12:08 PM   #2290
OkieSnuffBox
Drives: '23 BRZ Limited
I tracked on 2 wheels a long time ago as well.
I'm guessing you had a newer bike with a slipper clutch?
Old 12-23-2014, 01:14 PM   #2291
Reaper
Reaper's Avatar
Drives: violent
I have a ducati with an adjustable slipper that I usually keep maxed out and a suzuki drag bike I took the slipper out of. I also have a RM125 2 stroke and if you know anything about little 2 strokes you beat the snot out of the clutch everytime you ride.
After showing my friend in the rain he showed me my technique seems to be popular in the RWD rally world. @CSG Mike I like the term "trail clutch"
The Following User Says Thank You to Reaper For This Useful Post:
OkieSnuffBox (12-23-2014)
Old 12-23-2014, 01:33 PM   #2292
CSG Mike
CSG Mike's Avatar
Trail clutch is the technically correct term for what I think you're doing, if I'm thinking the right thing :p
Reaper (12-23-2014)
Old 12-23-2014, 02:31 PM   #2293
OkieSnuffBox
Yeah I had an '04 R6 many years ago, and it didn't have a slipper clutch.
When I went to the track I was just trying to have fun, so I'd just let the rear get loose under braking and go with it. I suspect it's why I picked up driving on 4 wheels rather quickly.
Old 12-23-2014, 02:39 PM   #2294
Reaper
Reaper's Avatar
Drives: violent
My clutch/rear brake has long been my traction control. Valentino rossi used to STAND on his rear brake while wide open throttle exiting corners and then slowly let up on the brake to modulate wheelspin.
solidONE (12-30-2014)
Old 12-23-2014, 03:04 PM   #2295
OkieSnuffBox
Oh wow, I never knew that about his style.
I just always used my right hand, brake, turn-in, maintenance throttle to right before apex and roll back in the throttle as you're standing the bike up.
I was much more comfortable sliding the bike around on the throttle than using the brakes.
Old 12-30-2014, 01:31 AM   #2296
mdecoste
Drives: 2013 white FRS
This thread is awesome (although admittedly I'm only about halfway reading through). Thanks Mike and everyone else for sharing your time and knowledge! Couple questions:
You mentioned tracking without a tune being damaging to the car. Is this something I should be concerned about? I bought my car in may 2013. Started tracking this summer and I go about once per month.
Also, after my last track day, I noticed the cap of my brake fluid reservoir had a bunch of green gunk on it. I'm assuming that the fluid has absorbed some water and it's time for a flush. I'm using torque rt700 and it has been through about 7 months of daily driving and 5 track days. Is that about what to expect for longevity?
Lastly, here's a video from buttonwillow earlier this month. If you guys have a few min, any constructive criticism would be appreciated! I feel I could definitely improve on my braking and corner entry speed.
[ame="https://www.youtube.com/watch?v=w1Kx3KKBCFw"]FRS Buttonwillow Dec 2014 open track - YouTube[/ame]
mdecoste is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
