Old 12-22-2014, 09:12 PM   #1
zcasto
Drives: 2013 brz,1972 skylark
engine whine
A
zcasto is offline   Reply With Quote
Old 12-22-2014, 09:34 PM   #2
Koa
bro we need a vid
The Following 2 Users Say Thank You to Koa For This Useful Post:
Tcoat (12-22-2014), Ultramaroon (12-22-2014)
Old 12-23-2014, 12:39 AM   #3
Originally Posted by zcasto View Post
My brz has had a really bad engine noise around 2000rpm and higher. It does it with clutch engaged and disengaged. It's really noticeable in 1st through 3rd. Really want to get some thoughts before I take it back to the dealer. It didn't start doing this until I installed a header back exhaust system and mtec shift springs and perrin shift bushing which shouldn't be affected
I hope you have a good relationship with your dealer ......
Can you tell if the "whine" is coming from the engine or drivetrain .. ??
Does the whine vary with the engine speed ...... or the gear speed .. ??
(well, that question made sense when I first typed it ..... )
Old 12-23-2014, 01:57 AM   #4
JOSEC
Drives: 2014 Subaru BRZ WRB
[ame]http://youtu.be/gW6CHGpaRfw[/ame]
If it sounds like this, then you're all good. I suspect it's the sifter bushing. I installed Whiteline transmission insert, Perrin rear shifter bushing and MTEC shift spring Kit and noticed the whine.
JOSEC is offline   Reply With Quote
Old 12-23-2014, 02:38 AM   #5
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
I love hearing gear box whine for some reason..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 12-23-2014, 04:13 AM   #6
JOSEC
It makes it sound like you have a twin screw supercharger under the hood.
Old 12-23-2014, 04:16 AM   #7
edeekeos
edeekeos's Avatar
While that is true, that's not why "I" like it. I just think it makes the car feel more 'racecar.' I would do those mods JUST to get that sound..
..which makes me wonder, after those mods, why is it whining? Most gear boxes that whine that loud use spur gears right? The 86 boxes have helical gears right? Someone please shed some light on this for me..
Old 12-23-2014, 08:03 AM   #8
kevman_101
Drives: 2013 Scion FRS
Could it be a bad bearing in the transmission? As much as I like the sound too, it is not normal to be that loud. I would take it to the dealer. I'm thinking a new transmission is going to be the solution.
kevman_101 is offline   Reply With Quote
Old 12-23-2014, 05:20 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The race car whine comes from straight cut gears, however in our case I think it has something to do with sound transfer into the cabin from the gearbox
Old 12-23-2014, 05:24 PM   #10
Koa
This- spur/straight gears whine a shit ton, helical gears don't whine as much
Old 12-23-2014, 05:26 PM   #11
FRSBRZGT86FAN
Also of you want to hear spur gear whine on a normal car most Hondas in reverse use a spur gear and make a cool whine lol
Old 12-23-2014, 05:27 PM   #12
Koa
Most cars do ours is no different. My '02 WRX whines like a som'bitch
Vortech SC - Leak & Loud Whine after Track (<6k) SonnyBRZ Forced Induction 37 05-14-2015 04:42 PM
Diff whine with clutch engaged + axle seepage Laika Issues | Warranty | Recalls / TSB 33 10-11-2014 08:16 PM
2013 FR-S A/T whine.... Tromatic Engine, Exhaust, Transmission 6 01-20-2014 12:57 PM
AT trans whine? Anyone else? Hardrock4445 Engine, Exhaust, Transmission 1 05-30-2013 06:46 PM
Turbo Whistle v. Blower Whine SupraLove Forced Induction 34 11-21-2012 08:56 PM
