Old 12-09-2014, 11:07 AM   #29
Mishimoto
Drives: 2013 Subaru BRZ
Originally Posted by Mad1723 View Post
/sub I need a new catch can and this seems like my next unit!
Awesome! Thanks for checking it out.
Mishimoto is offline   Reply With Quote
The Following User Says Thank You to Mishimoto For This Useful Post:
Mad1723 (12-09-2014)
Old 12-09-2014, 03:55 PM   #30
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
The PCV can with such hoses layout will be not easy to install on AT cars but manageble.
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
GIMMICK (09-19-2015)
Old 12-10-2014, 11:22 AM   #31
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
I'm curious to see if we do truly need both or if one will suffice once their testing is complete. I know two would make it easier but if I could add it later that would be ideal.
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back|
quicksilver30 is offline   Reply With Quote
The Following User Says Thank You to quicksilver30 For This Useful Post:
Rosticles (12-10-2014)
Old 12-11-2014, 11:41 AM   #32
Mishimoto
Luckily we actually have access to an automatic FR-S. We checked the located of the catch can, there should not be any fitment concerns with the can mounting location or the hose routing.
Exactly, this is the reasoning for our road testing. We want to ensure that both cans are necessary before launching this product. It may turn out that only one is truly necessary. We should have an update on this thread early next week with our results!
Thanks for following!
The Following 3 Users Say Thank You to Mishimoto For This Useful Post:
Cross (04-14-2015), Efferalgan (12-11-2014), quicksilver30 (12-11-2014)
Old 12-14-2014, 11:43 PM   #33
Pekingduck
Drives: 4 wheels
What the price point are you trying to hit?
Pekingduck is offline   Reply With Quote
Old 12-15-2014, 11:07 AM   #34
Mishimoto
As always, we will be offering the most value possible. At this time, our testing is not complete. We do not yet know if a single can or dual can setup will be necessary. We should have an update by the end of the week with some additional information!
Thanks for the interest.
DAEMANO (12-16-2014)
Old 12-16-2014, 12:41 PM   #35
DAEMANO
Time Traveller
very interested, please keep us posted.
Old 12-16-2014, 04:42 PM   #36
Mishimoto
Absolutely!
DAEMANO (12-19-2014)
Old 12-17-2014, 02:30 PM   #37
jay1989
Drives: 2014 Subaru BRZ
Absolutely!
any more updates besides the ones from last week? very interested in a dual can setup so long as it performs and looks decent.
jay1989 is offline   Reply With Quote
Old 12-18-2014, 10:32 AM   #38
Mishimoto
We should have a development update, with testing results, early next week.
Thanks for the interest and patience!
Old 12-22-2014, 04:24 PM   #39
Mishimoto
The results are in! Check it out.
Mishimoto 2013+ Subaru BRZ / Scion FR-S Direct-Fit Baffled Oil Catch Can System, Part 4: Testing Results and Project Completion
Ready for some interesting test results? After around 2,000 miles on a BRZ, this kit was ready to be inspected to see what kind of byproduct had accumulated in each can. The plan was to evaluate both systems to determine whether a single- or dual-can setup was necessary. If one of the lines did not collect any fluid, the need for a catch can would not be justified. So, we popped the hood and inspected the system to see if road abuse had a negative impact on the mounting brackets or lines.
Mishimoto prototype BRZ catch can kit installed
All our components held up just fine, as expected. All mounting brackets were still securely positioned, and the lines appeared to be in great shape (no rubbing). First, we popped off the can spliced into the PCV line of the BRZ. These images also show that we have provided plenty of room below the can to allow for easy removal of the base for fluid extraction.
PCV catch can removal
Immediately we can see some evidence that this can is functioning. This last shot proves a few things for us. One, the baffle is working to provide a surface for the fluid to condense, and second, the PCV line is definitely passing some oil into the intake system of the BRZ. Take a look below at the can itself.
PCV catch can accumulation
You can see that a thin layer of oil coats the entire can, and a bit of fluid accumulated in the base. Although not a substantial amount of fluid (we saw quite a bit more with our EcoBoost kit), we still wouldn’t want this ending up in our intake.
Next we removed the breather-side catch can base and examined it for fluid. We found it interesting that this can was bone dry. It smelled of fuel/oil, but there was no evidence of even a thin film on the inside of the catch can. These results were almost identical to what we saw on our 2.3L Mustang kit (developed around the same timeframe as this one).
What does this mean? Well, first of all, we would not be selling a component that you don’t need, so our kit for the FRS/BR-Z will include a catch can for only the PCV system. However, there is a possibility that some highly modified vehicles might necessitate a second can for the breather system. Because we already designed this system, it would be easy to release an additional kit for modified vehicles. For now, we are confident that the single-can system is the right application for BRZ owners. With our testing complete, we could now begin mass production of our kit. Check out a drawing of the bracket to be included.
Catch can bracket drawing
So, what do you get with our kit?
Mishimoto BRZ catch can kit final installation
Included Items in Mishimoto BRZ Baffled Oil Catch Can Kit
  • Mishimoto compact baffled oil catch can
  • Direct-fit, powder-coated steel mounting bracket
  • Direct-fit, molded silicone inlet/outlet hose (available in black, blue, and red)
  • Catch can hose fittings
  • Clamps for installation
  • All necessary hardware
  • Mishimoto Lifetime Warranty
The project is complete, and it’s a success! Thank you very much for following along with our development process. We are tossing around the idea of offering this kit at a discounted introductory price ($175) for members of the forum. If you would be interested in this presale offer, please let us know!
Thanks
The Following 7 Users Say Thank You to Mishimoto For This Useful Post:
akyp (12-23-2014), Cross (04-14-2015), DAEMANO (12-22-2014), Jeff-RS (09-07-2015), Rosticles (12-22-2014), WRB5titch (12-22-2014), zoth (01-05-2015)
Old 12-22-2014, 05:03 PM   #40
DAEMANO
Time Traveller
$175! Dooo eeeet man! I buy! AND I would love to have the breather side option because I am F.I. and have found blow by accumulation in the front as well. Please offer both!
Old 12-22-2014, 05:05 PM   #41
WRB5titch
Drives: WRBrz
Count me IN for 175! +1 on the breather side option as well.
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 12-22-2014, 05:16 PM   #42
jay1989
I'm in let's get this rolling
Mishimoto Compact Baffled Oil Catch Can Build Thread! Mishimoto Engine, Exhaust, Transmission 81 08-21-2019 08:05 PM
Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose Mishimoto Engine, Exhaust, Transmission 23 11-29-2018 11:35 AM
Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake Mishimoto Engine, Exhaust, Transmission 90 12-03-2016 06:22 PM
FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can glamcem Engine, Exhaust, Bolt-Ons 0 07-05-2014 07:15 PM
Win a Mishimoto Oil Catch Can! Mishimoto Announcements, Contests, Giveaways 68 10-23-2013 05:27 PM
