Old 12-19-2014, 01:40 PM   #1
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Anyone tried a Fidanza Clutch and flywheel set
I'm curious to see if anyone has tried this clutch setup before, its
2013 SCION FR S Fidanza Qwik-Rev Clutch Combos 710102
Here is the link
http://www.summitracing.com/parts/fi...ion/model/fr-s
I can get this shipped for a good deal with our wholesale summit dealer account, but I'm hoping someone has tried it and has some opinions on it.
20k overall miles with the last 10k boosted and now with e85 for 1k miles my clutch is slipping.
The V2 clutch set with lwfw has 6 puck disc which is what I am hoping someone has tried before.
JesseE is offline   Reply With Quote
Old 12-22-2014, 01:12 PM   #2
JesseE
JesseE's Avatar
Looks like I might be the first :-P
Old 12-22-2014, 01:24 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
[ame="https://www.youtube.com/watch?v=Fp4oAsoHyPo"]Fidanza Flywheel Sucks! - YouTube[/ame]
Good luck.
Old 12-22-2014, 02:32 PM   #4
JesseE
JesseE's Avatar
Is that a frs?
I dunno, I have had multiple fidanza flywheels and never had any issues. even on 2 of my other subarus. Oh well we shall see
Old 12-22-2014, 05:28 PM   #5
kster1
kster1's Avatar
I'm running a Fidanzda flywheel with the OEM clutch. No issues so far.
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
JesseE (12-22-2014)
Old 12-24-2014, 10:53 AM   #6
GH05T
Undercover Batman
GH05T's Avatar
Let me know how it is. Def planning on getting a clutch soon and this is interesting to see.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
GH05T is offline   Reply With Quote
Old 12-24-2014, 10:55 AM   #7
GH05T
Undercover Batman
GH05T's Avatar
Originally Posted by jsimon7777 View Post
Good luck.
This is dated from 2008 so it's def not an FRS
Old 01-15-2015, 03:44 AM   #8
JesseE
JesseE's Avatar
Well I got the flywheel and clutch finally.......... Not to happy yet, I'm waiting on Fidanza to get back to me in the morning so we can figure out why the flywheel they sent me is was not made correctly.
Needless to say, the FRS/BRZ transmission is by far the easiest transmission to remove and install... Less than 45 minutes to get it out, and not much more than that to complete the entire job. what a cake walk in terms of clutch jobs, lol.
The Following User Says Thank You to JesseE For This Useful Post:
Strife26 (07-07-2017)
Old 01-15-2015, 09:58 AM   #9
kster1
kster1's Avatar
What's the problem with the flywheel? Was there a manufacturing defect?
Old 01-15-2015, 12:31 PM   #10
JesseE
JesseE's Avatar
Well between the flywheel and the crankshaft there is what Subaru calls a crankshaft sensor plate. it has the signal for crankshaft position built into the design of the plate so that every time a specific part of the sensor plate goes over the magnet on the crankshaft sensor it picks the position up and sends it to the computer. The fidanza flywheel they sent me even though it has the correct part number stamped into it seems to be not cnc'd correctly, and it is actually recessed into the flywheel instead of coming out like the factory oem flywheel. What happened is it doesn't fit in the fidanza flywheel correctly and pushed out the crankshaft sensor plate all the way to the point of rubbing against the crankshaft sensor, and broke the crankshaft sensor.
So now I have a broken crankshaft position sensor, a bent crankshaft sensor plate (I had to special order and next day air it so I can have it by tomorrow from Subaru. (btw if you ever have this problem don't order from Toyota they are more expensive and do not allow next day air options) which has costed me an extra 160$.
I sure hope Fidanza pulls through and next day airs me a new clutch/flywheel set that is built right and pays for the sensor and sensor plate. I sent them pictures of everything this morning and they will confirm what I already know happened and then it is up to them to make it right. So far they have been very helpful I hope that continues and they get back to me quickly. The car is sitting on a rack taking up shop space at my shop and that's not good for business when 1 out of our 4 racks are down for 2+ days.
I'll let you guys know what I hear back from Fidanza
The Following 3 Users Say Thank You to JesseE For This Useful Post:
burdickjp (08-20-2015), kster1 (01-15-2015), mad_sb (01-15-2015)
Old 01-15-2015, 01:35 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
This sucks.
Old 01-15-2015, 06:17 PM   #12
JesseE
JesseE's Avatar
So Fidanza called back and they are making a new flywheel/clutch kit for me and sending me out a whole new kit! Also they said they will take care of the cost of the crankshaft sensor and sensor plate.
Kudos to them, been so easy to deal with!
It's very strange they have never had this happen before with the other kits they have sold to frs/brz people, Hopefully just a once-off kind of a problem.
The Following 2 Users Say Thank You to JesseE For This Useful Post:
burdickjp (08-20-2015), wparsons (08-31-2017)
Old 01-15-2015, 07:35 PM   #13
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Good of them to do that. Have used their flywheels for 15+ years and never an issue, but it can happen to anyone.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 01-15-2016, 11:24 PM   #14
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Any updates on how this has worked for you?
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Fidanza Qwik-Rev V2 Clutch BRZFern Engine, Exhaust, Transmission 5 11-03-2014 07:15 PM
Fidanza Qwik Rev Clutch & Flywheel kit MAPerformance Transmission and Driveline 10 01-03-2014 11:03 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
