Old 12-18-2014, 01:03 PM   #8065
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by GerryL View Post
Is an upgrade in the OFT engine management programming required as well?
From my understanding no.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
DAEMANO (12-18-2014)
Old 12-18-2014, 01:07 PM   #8066
fenton
If you set the activation point at 72% and above no....the ecu is already in closed loop so fuel remains on target depending on how much air is being pushed in. If you set it at 50 percent then your cars fuel trims will be all over the place...I tried it at 50 percent and it wasn't good....the reason being was you had more NA power left so the transition was unnatural to boost.
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (12-18-2014), WRB5titch (12-22-2014)
Old 12-18-2014, 01:13 PM   #8067
fenton
For those wondering how to set the activation point to a precise position please follow these steps.
1. Turn car to ON position
2. Disable/Disarm the ESC
3. Connect OFT and start monitoring Thottle
4. Get in the footwell of the car and push the throttle down with your hand until you see 70ish percent thottle
5. Adjust the arm of the engagement switch by pulling forward or pushing backwards until the first 'click' happens at about 70% throttle....If your switch is installed correctly the first click being at 70ish percent will result in the second click for full boost being at 90+ percent.
The Following 6 Users Say Thank You to fenton For This Useful Post:
07jazzrs5gt86 (12-18-2014), DAEMANO (12-18-2014), Fareast auto part (12-31-2014), Gums (12-18-2014), SloS14 (12-18-2014), WRB5titch (12-19-2014)
Old 12-18-2014, 01:17 PM   #8068
fenton
Originally Posted by Sojhinn View Post
SoJhinn you should zoom your log like i have done here so people can see the point where you went "partial boost"
Here i have it set to about 1.6psi tapering to 0psi by 6500rpm.
http://datazap.me/u/fenton108/tq250?...3681&mark=3606
The Following User Says Thank You to fenton For This Useful Post:
Old 12-19-2014, 10:56 AM   #8069
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
Hey, sorry I havent been able to keep up on this thread but what is the current status/eta for kits? I have been on the waiting list since June.
yamsta is offline   Reply With Quote
Old 12-19-2014, 01:06 PM   #8070
johnnyfast11
Drives: none yet
ok so is the first page updated with the upgraded package?
I want to get the most powerful kit available today. Which is it? and what I really need to get (batteries? etc?)
Yes sorry, someone please help me out on this cause reading 367 pages is really quite confusing... =[
johnnyfast11 is offline   Reply With Quote
The Following User Says Thank You to johnnyfast11 For This Useful Post:
DAEMANO (12-19-2014)
Old 12-19-2014, 02:16 PM   #8071
DAEMANO
Time Traveller
Yep, big thread. What can we say, its an exciting new piece of tech.
The kit on the first page should produce roughly the same max WHP and WTQ as what's been mentioned on these few recent pages.
The partial throttle switch and new batteries improve the kit by allowing mid-throttle boost, simplifying and upgrading the battery array (and thus installation, and early driving power delivery), and improving thermal capacity (for longer on-boost sessions).
Personally, I love the kit with the wide open throttle (WOT) switch. Nothing wrong with it AT ALL. I am upgrading because I have really enjoyed working through the kits development.
So get the kit, and a tune. That's all you really need. You can add a catless header and e85 (if available in your area) as some of the more common power adders. You'll end up somewhere in the ballpark of 220-230WHP and 205-210 WTQ. The big thing about this kit are its' simplicity compared to "traditional" F.I. and the torque characteristics. Gobs of wonderful torque down low where you want it.
The Following 6 Users Say Thank You to DAEMANO For This Useful Post:
FingR-S (12-19-2014), GerryL (12-20-2014), Gums (12-20-2014), johnnyfast11 (12-22-2014), raven1231 (12-19-2014), Sojhinn (12-19-2014)
Old 12-21-2014, 04:25 AM   #8072
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Huge post indeed. I don't have an FR-S (Yet, fingers crossed), but the Phantom ESC is at the top of my wish list. Second to the car of course lol :-)
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Old 12-21-2014, 10:42 AM   #8073
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Send a message via MSN to alex345
Sooo, I finally got my PC680 battery with everything installed! boom the car turned on , it seemed like it was the starter battery all along, now I have a different issue, whenever i move the car like press full throttle it seems to like stall or iddle and then turn off. can that be the tune? im runing oft 93 oct tune.
thanks
FRS 10-series- OFT,OFH,PerrinOP, Tanabee Fp.Perrin MAF intake,Cusco strut bar,Grimspeed tool tray, invidia Q300, Full JL Audio sound system, YO speed plaque.
Instagram: FRS610
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous #maverick#
alex345 is offline   Reply With Quote
Old 12-21-2014, 10:50 AM   #8074
Sojhinn
Sojhinn's Avatar
thanks
Did you mess with any of the wiring? Double check your connections make sure you didn't cross any wires. And triple check everything else. If that fails reload your tune.
Installed Mods:
Old 12-21-2014, 11:03 AM   #8075
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Will do so.
Instagram: FRS610
Old 12-21-2014, 12:09 PM   #8076
TM
TM's Avatar
Drives: DGM BRZ 6MT
Wow, didn't notice all these new posts and new development. Keep up the good work! I just put my car in storage last night. Won't be driving it for about 6 months. Hopefully by the time I get back to my car, they'll be a solid upgrade path.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
DAEMANO (12-21-2014)
Old 12-22-2014, 10:15 AM   #8077
BlackMonarch
Drives: Red BRZ
Have a question about this, and I read through about 30 pages of information on it... Will leaving this set to "on" and not just turning it off when I don't want boost harm anything? I can see from the data that the more it is used in spurts it drains the batteries quite a bit, have there been tests done with just leaving it on so you have it on tap? Does it drain batteries, or does it make a difference?
BlackMonarch is offline   Reply With Quote
Old 12-22-2014, 11:03 AM   #8078
Sojhinn
Sojhinn's Avatar
This system is meant to be on all the time and it automatically shuts off when the car is shut off. It doesn't drain the batteries at all when not in use. In fact it charges the batteries when you are not at full throttle. Or in my case less then 60% throttle.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
