Old 12-20-2014, 03:04 PM   #5783
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by dhsean View Post
I was unable to find as well. We replaced with a new OEM pulley for now but had to change the belt as well. If you still get a chirp try replacing the belt. I had about 15000 miles since the kit was installed. Everything is good now. Also check to see if you intercooler fluid is still circulating. Noticed it stopped recently - the fuse popped.
Where is the fuse located? I'm not seeing any mention of it in the intercooler install instructions.
Old 12-20-2014, 03:07 PM   #5784
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
It's on the wiring harness that connects to the small water pump and your injector.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-20-2014, 03:30 PM   #5785
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by 8686 View Post
I am living in the middle east. So i am not sure that I can find it in a local store.
Ahh. Read your post on my phone and didn't see your location.
Old 12-21-2014, 04:35 PM   #5786
stockysnail
Just the tip
Upon your recommendation I picked up the idler pulley NuLine EP075. I could only find it in Australia unfortunately as O'Reiley doesn't carry it anymore. Shipping was more than the part. At least it was still only $33. Hopefully this fixes the squeak that started a couple months ago as it's starting to get annoying. Hopefully this is the part that's making the noise.
Replaced my belt with the Gates K061015 and no more squeak. I still have the pulley coming so I guess I'll slap it on when it comes since it's supposedly a better pulley.
Old 12-21-2014, 10:00 PM   #5787
whataboutbob
AutoX-10/10ths every run
Originally Posted by Fizz View Post
Random question. Which direction does the coolant flow through the blower? Front to back or other way round?
The electric pump for the IC pushes fluid from the IC up through the heat exchanger via the front port on the manifold and out the back port on the manifold past the reservoir and back down to the IC.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Fizz (12-21-2014)
Old 12-22-2014, 11:55 PM   #5788
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Bummer....I was hoping it wouldn't require so much work.
By the way, is it possible to remove elbow without removing the blower unit itself?
I got to it after accidentally pulling it off while installing my catch can. The trick is to use a long 1/4" extension. Tape the tube to the end of the extension. Don't cut the tape. Leave a really long tail so you can remove the tape later. snake it down and push it on. Once it's on use the long tail of tape to unwrap the tube from the extension. Drink a beer and call it a win. I took a picture when I did it but it's not on my phone any more. I'll see what I can do to find it.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 12-23-2014, 12:06 AM   #5789
calispec
calispec's Avatar
There it is but I can't find the other pic.
Also on another thought. Using a check valve might get you in trouble. The idea is to get the pressure out of the crank case and vent it off. Oil comes with that. Oil will get caught at the check valve and will probably just plug it up. You might as well just remove the loop all together and plug it off but I don't recommend doing that either. Get a filtered catch can and call it a day.
It was also mentioned earlier that the elbow and in turn the PCV is always under vacuum with the innovate so there will never be reverse pressure on the PCV. That can' NOT be said for the other supercharger kits out there.
www.GT86Mounts.com
The Following User Says Thank You to calispec For This Useful Post:
Fizz (12-23-2014)
Old 12-23-2014, 12:32 AM   #5790
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
What I plan to do is to install the check valve on the PCV line after the catch can. So this way the oil and crap will (mostly) be filtered by the occ before it reaches the check valve on its way back to the manifold. I'll probably replace the check valve at every oil change interval just to be safe.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
calispec (12-23-2014)
Old 12-23-2014, 09:54 PM   #5791
8686
8686's Avatar
Drives: 86
Originally Posted by bryanj0308 View Post
Hey guys. Newly installed and tuned Sprintex 210 owner here. Want to give a shout out to the guys at Dynosty in Louisville, KY for their professionalism and butter smooth tune. I'm running the 69mm pulley on 93 pump with Tomei EL headers, Nameless downpipe combo, and Perrin 3 inch catback. The car runs great, and it definitely gave me the right bump in daily driver power that I was looking for. This thread was probably the main reason for looking into the kit. Thanks a lot for all of the detailed reviews and feedback throughout.
Interested to know your numbers with this setup
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
Scubaru (03-25-2015)
Old 12-24-2014, 07:23 AM   #5792
brianhj
Drives: 2017 Camaro 1SS
Is that tube actually connected there? Mine is just loose, the plastic fitting on the end looks broken. What's it for?
brianhj is offline   Reply With Quote
Old 12-24-2014, 07:52 AM   #5793
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Isn't that the vacuum tube for the bypass valve?
Old 12-24-2014, 08:13 AM   #5794
Dream20b
Y u do dis?
Seconded since this appears to be the route i'm going if I don't do the AVO TC
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 12-24-2014, 10:37 AM   #5795
brianhj
Does anyone know?
EDIT: Yes it's coming off the bypass value (the black cylindrical thing). I've been running with it disconnected/broken..
Old 12-24-2014, 10:38 AM   #5796
CK_Bladesmith
Drives: Raven FR-S
That's exactly what it is.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
