Old 12-20-2014, 05:16 AM   #57
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Ha Ha Ha Ha Ha Ha Ha
Went looking for a funny "gay car" pic in response to this comment and found this!!!!!!!
http://gaybreeze.com/gay-friendly-ca...ru-number-one/
"However, despite scoring high in gay-friendly brand awareness, Subaru could not match Toyota as the leading brand of cars owned by gay men and lesbians."
No other car does a better job meeting these criteria than ours.
killboy is offline   Reply With Quote
The Following User Says Thank You to killboy For This Useful Post:
Koa (12-20-2014)
Old 12-20-2014, 06:44 AM   #58
slim blanco
slim blanco's Avatar
Drives: 2017 86
I think the biggest lesson here is to not believe a word most car salesmen tell you!
the one that was trying to sell me mine pointed to the a/c compressor and told me the car had power steering haha.
slim blanco is offline   Reply With Quote
The Following 2 Users Say Thank You to slim blanco For This Useful Post:
pushrod (12-20-2014), Tcoat (12-20-2014)
Old 12-20-2014, 11:12 AM   #59
Have to keep that quote in context though: "This can be attributed to the fact that Toyota is the top automobile seller nationally. In 2008, Toyota sold cars to approximately 12.8% of the entire US car market."
But ya, no matter which you get you are screwed I just found the headline and choice of car for the picture hilarious!
Old 12-20-2014, 11:15 AM   #60
Mine said "I don't have a clue about this car so I can get sombody that does to help you"
I looked at her tight sweater and short skirts and replied "No it's ok I know all about them so I will stick with you".
jwSubMOA (12-21-2014)
Old 12-20-2014, 11:25 AM   #61
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I think it's about time someone pointed out that the Toyota GT86 is vastly superior to both the BRZ and the FRS in any way imaginable.
- The GT86 has 86mm wide exhaust tips (illegal in North America for some incomprehensible reason)
- The GT86 has the 86 logo on the steering wheel.
I could just go on and on, of course, but you've got the idea.
The Following User Says Thank You to Sarlacc For This Useful Post:
Ultramaroon (12-21-2014)
Old 12-20-2014, 11:33 AM   #62
I will have you know my exhaust tips are 86.2 wide!
And...when you turn the steering wheel to far your 86 turns into a 98 and that ain't cool!
Old 12-20-2014, 11:52 AM   #63
Chanpion
Drives: 13 FRS Satin
Originally Posted by TRD-X View Post
My 2 cents...
Subaru BRZ owners thinks all Toyota added to the car was the D-4 direct injection system oh wait a minute how did the boxer engine get the 86's > Bore and Stroke86.00mm x 86.00mm..??
That is all carry on.
To be fair, I kinda think the whole car is Subaru made except the D4S and the interior, that LED clock hasn't changed since the late 1990s, I swear. So mostly Subaru. I even flipped the Scion wheel cars and on the back, they say Subaru.
I know better, there's more Toyota in the drivetrain but still. Soft spot for Subaru even though I got the FRS.
Chanpion is offline   Reply With Quote
Old 12-20-2014, 12:16 PM   #64
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The brz sounds like a Subaru because it has a boxer and the frs sounds more like a Toyota because inline 4.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 12-20-2014, 01:02 PM   #65
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
I can't tell if trolling
WallsAndFoundations is offline   Reply With Quote
Old 12-20-2014, 01:07 PM   #66
Why do so many people like to equate assembled by to made buy? Neither Subaru nor Toyota made much of anything in these cars. The parts suppliers that did make them also make parts for other manufacturers right along side theirs.
To keep saying they are "mostly Subaru because they are assembled there" is just silly.
When you look at the excellent list complied by Bristecom you will see that many of the parts are in fact common to both brands even during regular production of other models:
*Not typical for Toyota
**Not typical for Subaru
Subaru Engine (With direction from Toyota)*
Toyota/Aisin Transmission (Tuned by Subaru)**
Toyota/JTEKT/Torsen Limited Slip Differential**
NTN Driveshafts/CV Joints*
Toyota/JTEKT/Koyo Wheel Bearings/Hubs**
Toyota/JTEKT/Denso Electric Power Steering**
Toyota/Denso Direct Fuel Injectors**
Denso/Kyosan Fuel Pump
Toyoda Gosei Fuel Tank Inlet and Cap**
Sakamoto Fuel Tank
Denso Iridium Spark Plugs**
Diamond Direct Ignition Coils
Mitsubishi Electric Alternator*
Mitsubishi Electric Starter Motor*
Mitsuboshi Drive Belt
Denso A/C Components (Condenser, Compressor, HVAC Unit, Filter)**
Denso Radiator
Denso Sensors
Denso ECU
Denso Airbox and Filter (Toyota Size)**
Tokyo Roki Oil Filter*
Mahle Japan Sound Creator
Subaru Chassis and Suspension*
Showa Dampers*
Sachs Dampers (MY2015)**
Mitsubishi Steel Springs*
Exedy Clutch
Nabtesco Clutch Cylinders*
Bosch ABS Pump
Toyota/Denso/Aisin ABS/EBD/VSC/TRAC Logic**
Hitachi/Tokico Brake Booster, Master Cylinder, Hose, and Calipers*
Aisin (Advics) Brake Discs and Pads**
Yokohama Spare Tire
Denso Window Motor**
Asahi Glass
Mitsuba Door Mirrors*
Mitsuba Turn Signal Lamps*
Koito Head/Tail Lamps
Denso HID Ballast**
Toshiba HID Bulb
Panasonic Battery
Niles TRAC/VSC, Display, and Brake Switches*
Alps Door Switches*
Tokai Rika Seat Belts
Toyota Boshoku Seats**
Toyoda Gosei Airbags**
Toyoda Gosei Steering Wheel
Toyota/Tokai Rika Clockspring and Multi-Function Switches**
Toyota/Tokai Rika/Denso/Yazaki Climate Control Switches**
Toyota/Tokai Rika/Denso/Aisin Immobilizer/Remote/Keyless System**
Toyota/Pioneer/Harman Sound and Navigation System (FR-S/GT86)**
Subaru/Fujitsu-Ten/Pioneer Sound and Navigation System (BRZ)*
Citizen/Rhythm Watch Co. Digital Clock*
Denso Instrument Cluster
Toyota Aerodynamics
Toyota Exterior and Interior Design (Except for the BRZ front bumper)
So ... when seen as a total, Toyota has a minor lead in the parts used no matter where the car was assembled.
If you really want too nit pick about who made what, then these cars should really be called ToyoDenSakDiaMitTokMahExeNamBosHitAisYokNilAlpCitA rus!
Chanpion (12-20-2014), hmong337 (12-20-2014), Sarlacc (12-20-2014)
Old 12-20-2014, 01:11 PM   #67
Don't think so, as it fits with the theme of Outrageous Beliefs!
Old 12-20-2014, 01:13 PM   #68
WallsAndFoundations
Drives:
I just can't believe someone out there who knows anything about the twins would think that hahahah
Old 12-20-2014, 01:21 PM   #69
I think that is actually his point he knows but others don't!
Most people out there don't know about the Twins and that is why there can be so many misconceptions!
Unfortunately, from what we see here even people that should know (sales) fall for the rumors and misinformation.
To quote myself from a previous thread:
Most people don't know it is a $25K car!
Most people don't know it is a "slow" car.
Most people don't know there are two Twins
Most people don't know squat about these cars.
We as "car guys" know these things and seem to assume that everybody else does as well. This is so far from reality it is ridiculous!
Choco (12-22-2014), FRSNewb (12-22-2014), Ultramaroon (12-20-2014)
Old 12-20-2014, 01:29 PM   #70
zkv476
zkv476's Avatar
Completely serious actually, I saw it in a YouTube comment but yea haha
The Following 3 Users Say Thank You to zkv476 For This Useful Post:
Choco (12-22-2014), Tcoat (12-20-2014), Ultramaroon (12-20-2014)
brz ,frs differences nickr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-27-2013 10:12 AM
Are most Scion dealers adding on outrageous extra fees to the price? subascion86 Scion FR-S / Toyota 86 GT86 General Forum 90 08-03-2013 06:10 PM
CDN vs US FR-S differences Sport-Tech CANADA 77 04-19-2012 02:24 PM
FR-S design differences jyoo Scion FR-S / Toyota 86 GT86 General Forum 36 09-20-2010 07:27 PM
