Old 02-13-2013, 11:53 PM   #15
rawbz
Drives: 2013 Subaru BRZ
Originally Posted by psk View Post
after finding this issue with my driver's side window, my passenger side is now leaking in the exact same location. sigh
has your dealer replaced the driver side seal yet?
rawbz is offline   Reply With Quote
Old 02-14-2013, 12:34 PM   #16
Mokiki
Drives: FR-S firestorm
Originally Posted by bergyb View Post
When I went through a rail car wash here in Ottawa I thought the car was going to be ripped to pieces lol. No leaks though. Just the terror of feeling as though the doors were about to ripped off :p
same experience. my car shakes a lot, and I was afraid the radio antenna was going to fall off.
Mokiki is offline   Reply With Quote
Old 02-14-2013, 01:47 PM   #17
psk
Drives: scion fr-s
no, they had to put in an order. it's been about 2 weeks now since then. they have no ETA either.
psk is offline   Reply With Quote
Old 02-15-2013, 10:51 AM   #18
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
are your switches flashing? try resetting the auto windows.
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 02-17-2013, 05:51 PM   #19
jailbot
jailbot's Avatar
Drives: 2000 Impreza RS coupe
It's been raining a lot recently where I live and temps dropped below freezing last night. Woke up to having my windows frozen in place due to all the water building up in the door and the window switches flashing at me. I know that a new model of car will always have some teething issues in its first year, but the amount of things going wrong with my car is starting to get ridiculous.
jailbot is offline   Reply With Quote
Old 04-18-2014, 12:41 PM   #20
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Any update so far ?
Heavy rain today and i notice water leaking from the small glass
Sookainian is offline   Reply With Quote
Old 04-18-2014, 04:24 PM   #21
Skurj
Drives: SOLD...
Mine leaks there everytime I go through the touchless car wash, both driver and passenger side. Not noticed it when raining though.
See your dealer..
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 04-19-2014, 01:21 PM   #22
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
i cannot stand my local dealer.
everytime i send in my car to fix one problem, they will damage my car... either by scratching somewhere or denting some panels...
3 bad experiences...
Old 12-19-2014, 09:02 AM   #23
N234
N234's Avatar
Drives:
I am at the dealership right now, having this problem looked at.
My leak is throughout the small triangular fixed glass, and the leading edge of the movable glass, on the passenger side of my 2013.
The triangular piece is sitting about a 3/8 inch lower at the trailing edge, and requires an adjustment. *EDIT: Not just the triangle triangle; the whole piece of frame which joins the two windows is low.*
I'm waiting in the showroom at the moment where I can see the problem on both showroom 2014 BRZs. Clearly a manufacturing defect, from my perspective, which is that of a programmer of another assembly equipment.
** Hats off to the members of WILLOWDALE SUBARU in Toronto for recognizing that this is a warrantied fix, without any push from me.
Best of luck to everyone with this issue.
-Nat
N234 is offline   Reply With Quote
Old 12-19-2014, 12:04 PM   #24
vgi
Drives: frs
stop washing your cars folks!
dirty tank not seen in battle
vgi is offline   Reply With Quote
Old 12-19-2014, 01:18 PM   #25
N234
N234's Avatar
Drives:
I just ran the car through a car wash with no leaks. The black divider is mounted with adjustability in case you want to DIY... Problem solved.
Old 05-08-2015, 08:27 PM   #26
Bimble Bamble
Drives: 10 Series
As per the original post a bit of water creeps through the top of the window closest to the roof line, even with hand washing.
Would this fix that? Could you please elaborate on how you solved this problem? A picture would help too. Thanks!
Bimble Bamble is offline   Reply With Quote
Old 05-08-2015, 09:20 PM   #27
zman
zman's Avatar
Drives: scion frs
I just noticed my hood leaking today all over the back of the headlights which is the reason why my hids broke 😐 anyone else have this problem?
zman is offline   Reply With Quote
Old 05-09-2015, 01:55 AM   #28
N234
N234's Avatar
Drives:
The dealership did it under warranty. Basically the entire window assembly needed to be moved upwards.
Sorry i don't have pictures. I didn't do it myself either. The dealership said it was easy. It took them less than one hour.
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
Slow Leak, wha do you guys think could be the cause? peenut1086 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-25-2012 10:47 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
