Old 02-04-2013, 10:52 PM   #1
rawbz
Drives: 2013 Subaru BRZ
Slight window leak after car wash
Didn't see anyone else posting about this so I'm starting a new thread but has anyone else had a few streams of water drip down the inside of the windows after a touchless gas station car wash?
The design of the one I went to has a big frame of pressure sprays that you get pulled through so there is one going pretty much horizontal directly into the seal but I'm still concerned there's a bit of a leak anyway
If no one else is experiencing this I might bring it up with the dealer but I have a feeling getting the seal replaced will probably just make it worse?
but I am experiencing a lot of moisture build up where the window hits the rubber and with the change in temps here it does build up and then freeze. I haven't had my windows get stuck yet, just a little hesitation and it'll power through to open.. but thats probably making my seal even weaker
rawbz is offline   Reply With Quote
Old 02-05-2013, 02:56 AM   #2
psk
Drives: scion fr-s
is it the driver's side? right where the big window meets the smaller triangular window?
i turned my car in to the dealer last week when discovering the leak while washing my car. they had to keep my car for a few hours and they ordered a new weather strip for me. the weather strip or door seal was also folding upwards in the middle where the window would make contact with it. hopefully the new strip will solve both the leaking and folding issue and not return.
psk is offline   Reply With Quote
Old 02-05-2013, 10:59 PM   #3
rawbz
driver side and passenger side. The passenger side has leaking closer to the smaller triangle window, the driver side has leaking right down the middle.
I don't have any folding that I can see but would appreciate it if you can keep us up to date on when your parts come in and you have your next wash! considering talking to dealer but sometimes they have a habit of making things worse
The Following User Says Thank You to rawbz For This Useful Post:
jrodz09 (02-11-2013)
Old 02-05-2013, 11:03 PM   #4
bergyb
bergyb's Avatar
Drives: 2013 Argento FRS AT
When I went through a rail car wash here in Ottawa I thought the car was going to be ripped to pieces lol. No leaks though. Just the terror of feeling as though the doors were about to ripped off :p
bergyb is offline   Reply With Quote
Old 02-05-2013, 11:17 PM   #5
Yruyur
Yruyur's Avatar
Dealer told me a lady had the same issue and it was addressed by toyota saying that the car wash she went to was to blame. Basically any car wash that sprays from the side or up will cause this.....:confused:
Old 02-06-2013, 05:06 PM   #6
rawbz
Are you kidding me? if theres any leak when the windows are closed its an issue. if they're saying it hasn't been raised as a significant issue they're working on yet then fine but the feedback needs to go back up to Head Office regardless so once its wide spread enough they'll have to address it.
Old 02-06-2013, 05:19 PM   #7
psk
Drives: scion fr-s
that's complete BS. dealers will say anything to try and give their customers the run around. water should never EVER be able to go inside your car. call HQ and file a complaint to their location and their bogus claim.
Old 02-06-2013, 08:03 PM   #8
Ruckus
Ruckus's Avatar
Drives: Firestorm FR-S
I changed the door speakers the day after it rained and drops of water inside the door. It looked like most of it was entering through the small little triangular window. Its not getting inside the car per say but its still inside as far as I'm concerned.
Ruckus is offline   Reply With Quote
Old 02-06-2013, 08:40 PM   #9
JanLov
Drives: 2013 Raven FR-S
It says in the car manuel not to go through car washes with high pressure directed at windows. Because of this I have washed it myself.
JanLov is offline   Reply With Quote
Old 02-06-2013, 09:01 PM   #10
Skurj
Drives: SOLD...
So lets see... don't go through no touch washers because water is sprayed on windows..
Don't go through them touch washers because they can scratch the paint..
Don't go to the manual high pressure washers for both of the above reasons..
So I gotta wash it in the driveway when its -10 with my low pressure hose?
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 02-06-2013, 09:46 PM   #11
Yruyur
Yruyur's Avatar
As long as you dont spray from the side or from below. Lol.
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
Laika (02-17-2013), Sportsguy83 (02-14-2013)
Old 02-07-2013, 05:03 PM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
this is stupid. dealer should fix it. i havent gone to car wash yet but i usually car wash it myself at home. what about leak when raining? it happened to anybody?
Old 02-07-2013, 08:39 PM   #13
monkie
monkie's Avatar
Drives: 86 GTS
Noticed this same issue here with my 86 in AUS brought it up when car just got it's first service.
Service manager said they could not replicate the issue.
Happens with any type of decent pressure where the water goes behind the glass and into the door seals, did not get water into the cabin though, puddled behind the glass.
I also noticed that the door seals were wearing in 2 places from the window opening and closing when door is opened keeping an eye on this.
monkie is offline   Reply With Quote
Old 02-11-2013, 01:45 AM   #14
psk
Drives: scion fr-s
after finding this issue with my driver's side window, my passenger side is now leaking in the exact same location. sigh
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
Slow Leak, wha do you guys think could be the cause? peenut1086 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-25-2012 10:47 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
